The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Aug 14, 2020 at 10:23 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Wait until it breaks....there isn't a single repair joint in town here that will even touch a CVT, except the delearship. And we all know they like to take your $$$$.
    Justanotherhemi likes this.
  2. Aug 15, 2020 at 5:16 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    SxS action updates Daniel?
  3. Aug 16, 2020 at 1:47 PM
    08TRDOFFROAD
    Dan
    Zero...haven't been out in a couple months. Wife was uncomfortably pregnant...now we have a newborn. Doesn't help that we sold the trailer when we finally sold the two atvs. Planned to buy an all aluminum 7x12 or 14 to haul it and just haven't gotten around to it.
  4. Aug 16, 2020 at 1:59 PM
    Justanotherhemi
    Rick James
    Word to the wise, buy a 16 or 18 footer even if not aluminum. Gives you room to grow the toy hauling & even tow a car on it if need be. I learned this lesson the hard way.
  5. Aug 17, 2020 at 7:15 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    He's a deadbeat for sure.
  6. Aug 17, 2020 at 11:31 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    @EatSleepTacos I heard you were running something called TacoTabs? Eliminates the cam hardware and cheaper than replacement parts anyway.
    Any feedback? I'm planning on chopping out my seized hardware and arms and doing a refresh like @08TRDOFFROAD and if I can save $130ish and not have to deal with wonky alignments ever again, I'm sold.
    mcharfauros likes this.
  7. Aug 17, 2020 at 11:36 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Yes, so far they're fine. Takes a little trial and error to get it where you want it. For example I added them when I had 650lb coils. When I went to 600, I lowered the front end so I wanted to change out the tabs. Took a couple tries to get it right. Other than that though, no complaints. Your alignment numbers won't be perfect though since you don't have all the adjustability.
  8. Aug 17, 2020 at 11:38 AM
    Gunshot-6A
    Conner
    Everett, WA
    Well considering how abysmal they are right now "good enough" would be a marked improvement. You def wheel your truck harder than I do, so if they're acceptable for your purposes, I should be good to go.
    Do you do your own driveway alignments or take it somewhere? I know a lot of euro cars have a similar setup, just didn't want to blow my favorite tech's mind if I bring it in.
  9. Aug 17, 2020 at 11:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I do my own. I have the rear tab all the way out, front all the way in, and adjust toe myself. I haven't a clue what my actual caster/camber numbers are. I just know my caster is maxed out, and my camber is good enough, measuring with a piece of flat bar stock and an angle finder. It seems to be within the acceptable range.
    edit: You'll want to pair them with the total chaos alignment tabs for a really rock solid front end to beat on.
  10. Aug 17, 2020 at 12:01 PM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    I still have that complete setup just staring at me Everytime I walk in my door. I really need to get to the post office.
  11. Aug 17, 2020 at 12:39 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  12. Aug 17, 2020 at 1:49 PM
    My Name is Rahl
    Justanotherhemi and RoughRder like this.
  13. Aug 17, 2020 at 1:52 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Smdh
  14. Aug 17, 2020 at 2:02 PM
    08TRDOFFROAD
    Dan
    Spend the money and get the demon heavy metal blades to cut the hardware.
  15. Aug 17, 2020 at 2:04 PM
    Gunshot-6A
    Conner
    Everett, WA
    For sure. Not making that mistake.
    Justanotherhemi and mcharfauros like this.
  16. Aug 17, 2020 at 2:05 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    What?! I heard you were a Tacoma Beast. :notsure::notsure::notsure:
  17. Aug 17, 2020 at 2:35 PM
    Ubaderb
    Ubaderb Well-Known Member
    15 Tacoma TRD OR
    We all know we didn't buy these trucks for the gas mileage but I am curious what kind of real world mileage you are getting. You are considerably lighter than me but ECGS recommended 4.88 to me.
  18. Aug 17, 2020 at 2:43 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  19. Aug 17, 2020 at 3:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you a manual as well? Surprisingly I get 15 mpg on the highway. And that’s calculated manually and accounting for the increase in tire size. I’m cruising at 65mph at 2700 rpm on the highway when I’m on my way to go wheeling.
  20. Aug 17, 2020 at 3:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I labeled my locker switch and ran the source and exhaust lines as well in prep for the front diff to arrive. Tested it out and it works great.
    A8AEE6DD-6C2F-453D-9712-885FF5365EF5.jpg 8BC4A399-2C40-4AB2-933E-3B55166F55EE.jpg
