The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Sep 17, 2020 at 1:19 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I'm not opposed to welding anything. I just wanted to know your thoughts on using 1/4" square tube before I begin, or should I re-buy something thinner?
    Then I just wanted to know if you had a better idea for attaching the wheel to the support. I would definitely like to use real lug nuts, and if possible a locking lug nut.
    If I have to I can use the cable lock I am using to keep it secured in the bed.
    I am just already done with the tire in the bed thing, and I don't want to mount it under the truck. I haven't stood it up yet to see if I'd like that any better. I already had that flip up receiver collecting dust and the tube cost me $23 bucks. I expect a bracket to be a lot less.
    It would be exactly like the setup above except it will be as close to the truck as possible without wobbling and hitting the truck. I can buy a cheap rear view camera and mount it to the cap, below the 3rd brake light and just tie it into the wiring going to the existing one with a plug. I would just disconnect the one in the tailgate. The tire would be high enough to see the tag so I wouldn't have to do anything to relocate it.
    Greg.Brakes.Tacos likes this.
  2. Sep 17, 2020 at 4:57 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    what about one of these? https://www.tacomaworld.com/threads/2-spare-tires.262903/
    RobP62[QUOTED] likes this.
  3. Sep 17, 2020 at 5:01 PM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
  4. Sep 17, 2020 at 5:23 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  5. Sep 17, 2020 at 5:25 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Buenos Dias Señor!
  6. Sep 18, 2020 at 6:15 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    I feel this on a spiritual level.
    119394762_10158508397882567_383756281497_26187f1158968d566ed229dc2bcf25c4f574789a.jpg
  7. Sep 18, 2020 at 6:17 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    1/4" will be fine, just overkill. 1/8" wall would have been sufficient. The only downside is the extra weight of the 1/4" but it's not going to be detrimental. You have it, I say just use it. You'll get more of a workout when lifting the tire back up.
    As far as attaching the tire, check this out. You can use actual wheel studs on it meaning you'll be able to use lugnuts.
    https://www.4xinnovations.com/Tire-Carrier-Wheel-Mount-Plate-and-Support-Gusset_p_163.html
  8. Sep 18, 2020 at 6:18 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    My wife
  9. Sep 18, 2020 at 6:18 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I agree with this.
  10. Sep 18, 2020 at 7:22 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Well damn Randejo, thank you very much! This is exactly what I need! $32 shipped. I guess this is a good price? And then studs would just be a press fit or would they need to be welded to this as well?
  11. Sep 18, 2020 at 7:23 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    When I get like this on either account, Deb calmly says "Haste makes waste". Drives me freaking insane!!!!
  12. Sep 18, 2020 at 7:27 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I have their rear bumper and the studs are tacked on. I'm guessing it's the same assembly.
  13. Sep 18, 2020 at 7:27 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It depends on what size they cut their holes to. If it is the same size as a Tacoma wheel hub, then you could just press-fit the studs in. You just slip the stud through the hole, stack some washers on it, then tighten a lug nut, pulling the stud through. It's very easy.
    Alternatively, you could get some M12x1.50 bolts (same size as Toyota wheel studs) and just bolt those on.
    https://www.youtube.com/watch?v=zFZBmu_rLTk
  14. Sep 18, 2020 at 7:35 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Bronze Oxide
    I want to know more about this short bed, looks awesome! I don't see anything in the links on the first page, and there's no way I'll find it in 3800 pages. Any info?
  15. Sep 18, 2020 at 7:39 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    totally.
    But I do enjoy people blazing past me on I-15 and I-70 on holiday weekends. Let them be the rabbit for the PoPo.
  16. Sep 18, 2020 at 7:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    RobP62 and Bigdaddy4760 like this.
  17. Sep 18, 2020 at 7:44 AM
    Charvonia Design
    Keith
    Huntersville, NC
  18. Sep 18, 2020 at 8:35 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So I'm pretty over having my lunchbox locker in the rear. In an auto, it's not a huge deal but in a manual, it makes it real clunky and lurchy. I've gotten used to it for the most part but lately I've been wanting to go to a selectable, even though they're a little more prone to having issues. Since mailing in my front recently and adding the ARB, I've seen that additional labor really isn't much, so it would be $1,150 all said and done, and the locker itself is $900 of that.
    I'm just hesitant because of all the ARB seal issues. I know ECGS would take care of me, but it's still a hassle. I would like a TJM like @jowybyo but they don't seem to offer that anymore. I will ask about it when I email for a quote.
    08TRDOFFROAD and RobP62 like this.
  19. Sep 18, 2020 at 8:37 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Thanks Dave! Yea, with all the other welding going on if the studs need to be tacked not a big deal. Something has to keep the studs from spinning.
  20. Sep 18, 2020 at 8:37 AM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    Pony up for the Harrop and call it good.
