The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Jun 28, 2021 at 3:01 PM
    My Name is Rahl
    Sounds like you better go shopping. :boink:
  2. Jun 28, 2021 at 3:16 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Honestly these are fine. Better than the upside down bullshit that was on there. No ones gonna be looking that closely or even care these aren’t perfect.
  3. Jun 28, 2021 at 3:21 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Those are so horrible.
  4. Jun 28, 2021 at 3:23 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Looks better without stickers
    Taco-Obsessed likes this.
  5. Jun 28, 2021 at 3:24 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Worse: You'll know they aren't quite right :rofl:
    LOLLY and geekhouse23 like this.
  6. Jun 28, 2021 at 3:27 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Should've painted blurple
    y=mx+b, Slashaar and Gunshot-6A like this.
  7. Jun 28, 2021 at 3:27 PM
    geekhouse23
    I think you should have some stickers made of custom white claw cans;
    Label says "RandyFab"
    Logo is a mullet and mustache..
    Cahnge my mind...
  8. Jun 28, 2021 at 3:51 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    mcharfauros, pdenajim, RobP62 and 4 others like this.
  9. Jun 28, 2021 at 3:55 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    yes.
    geekhouse23[QUOTED] likes this.
  10. Jun 28, 2021 at 4:10 PM
    geekhouse23
    Slashaar[QUOTED] likes this.
  11. Jun 29, 2021 at 2:53 AM
    UntamedTaco
    UntamedTaco Formerly: Montauk17
    Jerry
    Myrtle Beach, SC
    2017 Tacoma OR DCSB Barcelona Red
    Armor - Mobtown Offroad Front Bumper - Mobtown Offroad Rear High Clearance Bumper (with swing out) - Mobtown Offroad steel rock sliders - Mobtown Offroad steel IFS skid plate - Mobtown Offroad steel transfer case skid plate - Mobtown Offroad steel transmission skid plate - Mobtown Offroad steel fuel tank skid plate (currently not installed) Winch: - Smittybilt X2O COMP - Waterproof Synthetic Rope Winch - 10,000 lb. Load Wheels/Tires: - Toyota Black TRD Pro SEMA Wheels - Cooper ST Maxx Tune -OV Tune Installed Shocks: - Rear Shocks: Kings Racing with adjusters - Front shocks/coilovers: Kings Racing - UCA's: Dirt King Rear leafs: - Icon RXT Roof Racks: - Martin Offroad cab and cap racks Lighting: - Baja Designs floods - Baja Designs ditch - Baja Designs reverse lights Light controller: - sPOD 8 Switch Snorkel: - Dobinsons Cap: - Leer 100R with Premium Line-X Other Goodies: - On board air compressor with hose and nozzle - On board fresh water pump and water can. - Midland – MXT275VP4-15 Watt GMRS radio - Recovery gear (Shackles, Tree Saver, Snatch Block) - Ratcheting farm jack - Krazy Beaver Shovel - First World Problems Fabrication H-Lift Jack mount - First World Problems Fabrication Universal Mounts (Shovel/Axe) - Hondo Garage Un-holy Dashmount - Hondo Garage radio knobs - Other stuff that I am sure I forgot
  12. Jun 29, 2021 at 6:22 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I like the fake color better.
  13. Jun 29, 2021 at 6:24 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Like my wife always tells me, it's ok to be wrong.
    geekhouse23 and RobP62[QUOTED] like this.
  14. Jun 29, 2021 at 6:25 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    ............if not Conner @Gunshot-6A I have an extra I bought that I can send you :stirthepot:
  15. Jun 29, 2021 at 6:28 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Gunshot-6A and geekhouse23 like this.
  16. Jun 29, 2021 at 6:29 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  17. Jun 29, 2021 at 6:41 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    One outta two ain't too bad :notsure:
    Unless the good one was by someone else :boink:
    Gunshot-6A likes this.
  18. Jun 29, 2021 at 9:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I swapped my front main seal today and it was easier than I expected. The only difficult part was keeping it from spinning while I torqued it down. If I were to redo it, I would loctite and ugga dugga it on.
    I removed the fan and shroud and it gave me so much room to work. It was easy too. Two bolts for the shroud and 4 for the fan and I lifted them out together.
    That gave me enough room to get an impact on the bolt and it backed it right out. The pulley came right off too, I didn’t need a puller.
    Getting the seal out took a little finesse but it came out and to put the new one in I pushed it in my hand as much as I could and then tapped it in with a 35mm socket and a hammer.
    Used my homemade tool to torque the pulley to 180 ft lbs and man, that was difficult. You can see why the tool bent. Back together and runs fine. Time will tell if the leak starts again.
    E5EE2EF2-CDF7-4345-81C0-BB46DC9C5BC2.jpg 6CAE1DAF-A386-4E36-BFC6-6987E74C2812.jpg D2E94B02-04A3-40FB-9AC7-AF143AFF09FF.jpg 8B84A3FB-DED7-4A05-A5C3-70320950D0A4.jpg 30919772-345E-488A-A7FE-C1BE69B2B259.jpg CE801C3E-5CE3-4A0D-AE22-13D329458C2D.jpg 47109937-2C75-4A79-B39A-436A0A0DED91.jpg
  19. Jun 29, 2021 at 9:47 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Here’s where I landed with the resi sticker. I decided a small legit one is preferred for me. So @Gunshot-6A if you have a small one, I would love to trade you.
  20. Jun 29, 2021 at 10:22 AM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    :rofl::rofl:this is every weld I've done since having cataract surgery. Usually get it on the second try. :anonymous:
    RobP62 likes this.
