The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Jun 29, 2021 at 10:25 AM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    :anonymous: I'm glad I'm not the only one that bent my tool.:D
  2. Jun 29, 2021 at 10:27 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    I was putting my whole body into the torque wrench and I was like “WHY ARENT YOU CLICKING?!”
    I knew people had an issue bending them but I was like “no way I will, these are too thick”. I was wrong.
    Gunshot-6A and RobP62 like this.
  3. Jun 29, 2021 at 11:08 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I swear I think you post pics like this just to drive me crazy!!!!!!!!!!! I CANNOT wait until George is big enough to use a pressure washer. :facepalm:
    I'm already working on my rhetoric of the importance of cleanliness and evils of dirt. :thumbsup:
  4. Jun 29, 2021 at 11:12 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Better be careful, you're almost at that age when the blood vessels in your head start to thin out. Just sayin'
    Gunshot-6A likes this.
  5. Jun 29, 2021 at 11:12 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If it wasn't so dang hot out then I might've rolled the truck into the driveway and cleaned it up and then finished assembly out there. At least now I know how easy it is to remove the fan and shroud so I can do it in the future when it's cooler.
    RobP62[QUOTED] likes this.
  6. Jun 29, 2021 at 11:13 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    I only bent mine a tiny bit, but I threaded grade 10 bolts into the harmonic balancer and tightened a bolt into it to keep it stable.
    184 (or whatever it is) ft/lbs is a lot.
  7. Jun 29, 2021 at 11:13 AM
    BamaTaco56
    Trey
    was a good time to clean out the back side of your radiator real good
  8. Jun 29, 2021 at 11:18 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I did a visual inspection and it wasn't too bad, at least on the back of it. I'll still probably give it a good cleaning at some point as well as the front of the engine. The layer of dirt and oil caked on there is incredible.
    RobP62 likes this.
  9. Jun 29, 2021 at 11:49 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I feel ya Brother. Heat index here is 108!!!!!!!
    and also..............
  10. Jun 29, 2021 at 11:51 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Hilarious movie. Was on the other night. The girl and I watched it and laughed out asses off..
  11. Jun 29, 2021 at 11:51 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    FTFY :thumbsup:
    Slashaar likes this.
  12. Jun 29, 2021 at 11:52 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, we watch it over and over too Dr. Funker. Especially if it's a weekend night and we've both had a few too many. :drunk:
    geekhouse23[QUOTED] likes this.
  13. Jun 29, 2021 at 11:56 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    184 ft/lbs is nothing to #RandyFab. I once saw him do 150 ft/lbs bare handed, and I think he was sitting down. He's a beast. Have you seen his hairy legs?
  14. Jun 29, 2021 at 12:02 PM
    geekhouse23
    Question for the lair; Thoughts on going from weld on sliders to bolt on sliders?
    TIA.
    Gunshot-6A, Slashaar and RobP62 like this.
  15. Jun 29, 2021 at 12:08 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I say if you can weld like Randall then you don't need bolt on. However, if you weld like @FadedComa and don't want to add an additional 300lbs installing them, bolt on is the way to go.
    :devil:
  16. Jun 29, 2021 at 12:11 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    But seriously, I have bolted them onto both of my Tacoma's and jacked up the entire side of the truck with them so.......
    For me, bolt on is the only option. I don't weld.
    08TRDOFFROAD likes this.
  17. Jun 29, 2021 at 12:15 PM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    You live in the rust belt, correct... bolting on leaves a tiny gap with high frequency vibrations happening at all time while driving... so consider that and you won't switch to bolt on with these frames.
  18. Jun 29, 2021 at 12:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    As Justin said, it's corrosion city with bolt-ons. You'll want to remove the sliders and keep rust in check every 1-2 years.
    RobP62 and Slashaar like this.
  19. Jun 29, 2021 at 12:28 PM
    geekhouse23
    Right. Someone in the Northeast has bolt-ons and removed them to address the frame and sliders. I just can't get to all the spaces for the weld ons to address the rust on the sliders.
    Can't cut them off and reweld them either without a local welder.
    I guess that begs the question; should I hold off on the bolt ons and use that money to invest in a mid-range welder setup?...
  20. Jun 29, 2021 at 12:31 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Which areas? I can’t think of any spot on my sliders I wouldn’t be able to get to with paint if needed.
