The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Sep 10, 2021 at 2:50 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Thanks.
    Some big life changes all at once. This diabetes, counting carbs to dose insulin is all a bit overwhelming.
    Greg.Brakes.Tacos and Slashaar like this.
  2. Sep 10, 2021 at 2:53 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    That's scary! Diabetes runs in my family so it's always something I'm worried about popping up. Glad to hear you're doing better.
  3. Sep 10, 2021 at 3:04 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Oh man, does this mean no more dr peppy???
  4. Sep 10, 2021 at 3:07 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    FIFU
  5. Sep 10, 2021 at 3:20 PM
    Slashaar
    Josh
    Kansas City, MO
    :puke:
  6. Sep 10, 2021 at 3:21 PM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    That's probably what caused it. Dr Pepper is the devils bath water!
  7. Sep 10, 2021 at 3:22 PM
    Slashaar
    Josh
    Kansas City, MO
    :mad: You take that back!
  8. Sep 10, 2021 at 3:37 PM
    Jim=2015 TRD PRO
    Jim=2015 TRD PRO Well-Known Member
    Jim
    MD
    2015 TRD PRO
    Switch to Cheerwine
    Greg.Brakes.Tacos likes this.
  9. Sep 10, 2021 at 3:40 PM
    08TRDOFFROAD
    Dan
    Diet Dr peppy...
  10. Sep 10, 2021 at 3:41 PM
    08TRDOFFROAD
    Dan
    If you start having weird issues peeing, run to your dr. Don't ignore it.
  11. Sep 10, 2021 at 3:41 PM
    Slashaar
    Josh
    Kansas City, MO
    :pout:
  12. Sep 10, 2021 at 3:42 PM
    08TRDOFFROAD
    Dan
    I feel the same. Will probably just not drink it.
    Slashaar[QUOTED] likes this.
  13. Sep 10, 2021 at 3:43 PM
    Slashaar
    Josh
    Kansas City, MO
    I've been doing water mix powder mostly, but the ol' Dr. P was a treat I'd get on occasion.
  14. Sep 10, 2021 at 4:56 PM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Dr. Pepper zero...it might make it easier to transition
  15. Sep 10, 2021 at 7:10 PM
    08TRDOFFROAD
    Dan
    Which mix you using?
  16. Sep 10, 2021 at 7:16 PM
    Slashaar
    Josh
    Kansas City, MO
    Great Value. I use the caffeinated for work and the non-caffeinated for home. Tons of flavors, most are pretty good. Only one's I don't care much for are the pink and regular lemonade since they seem to make me more thirsty than quench it. I really like the non-caffeinated flavor pina colada and melon. They also have electrolyte mixes which are nice for after sweating a bunch like after mowing.
  17. Sep 10, 2021 at 7:33 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Holy shit Dan.....so sorry to hear what you went through.....glad everything came out ok.
  18. Sep 10, 2021 at 10:26 PM
    TacoTuesday1
    FL
    If I am not mistaken you have a Softopper and KBvoodoo bed rails
    I have the same
    How do you manage this combo?
    I'm struggling to make them work but believe there may be a way
    So far I have shaved down the mounting clamps a bit, so they can tighten, to try and clamp the Softopper rails flush/flat.
    I might not have grinded them down enough material shaved off so I will try some more again.
    It's kind of a pain because the fine dense aluminum they are made out of
    1. clogs the bench grinder wheel fast
    2. heats up fast, hard to hold in your hands
    3. kind of difficult to get a perfectly level smooth shave on it; maybe I need to clamp it in a vice and use an angle grinder + 40 grit flap disc wheel by eye to try and get a nice finish and sacrifice/ruin 1 wheel (worth it, they're cheap)
    I really hope there is a way to get the fantastic Softopper that was designed to clamp over the factory garbage plastic rails, to work with KBvoodoo awesome rails/bedside tops
  19. Sep 11, 2021 at 4:27 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Kinda but not really. I made some similar bedside caps myself out of 1/8” steel. I also used to have a softopper on them. I didn’t need to modify anything to get the softopper to bolt on.
  20. Sep 11, 2021 at 6:22 AM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    How’s the tundra rack going? Are your new motor mounts taller to clear the rack? Did you go with a solid (more solid/uranthane bushing) mount?
