The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Nov 11, 2021 at 2:04 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    True.. but you know how he is with trees, right? Throw the RTT into the mix. Not to wish bad karma/juju on Randy, at all. But???
    At least with the camper on the tundra in the parking lot. He’d have a place to lay his head.
  2. Nov 11, 2021 at 3:24 PM
    My Name is Rahl
    Definitely. Then it will look like a bigger version of that camper Taco that Toyota recently made.
    And even some A/C so Mrs. Randy can tag along.
  3. Nov 11, 2021 at 3:26 PM
    Hafaday
    Bill
    Richmond, VA.
    Now yer talkin..
  4. Nov 11, 2021 at 3:27 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    If I could have that camper bed on the tundra and still tow Betty and stay within GVWR, I would be all for it. That would be freaking sweet. Couldn’t happen though, those are just too heavy.
  5. Nov 11, 2021 at 3:32 PM
    My Name is Rahl
    Fiberglass shell, or more to your tastes....carbon fiber shell.
  6. Nov 11, 2021 at 3:41 PM
    Hafaday
    Bill
    Richmond, VA.
    Rite rite. I’m with yea. Just thinking out loud.
  7. Nov 12, 2021 at 10:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I had a pretty productive day today. The main thing was cleaning up the bed and tent wiring. I previously had a cigarette lighter in the bed for the fridge and just used a cigarette power extension cord ran into the tent to power stuff. It rusted apart being in an open bed, so I needed to fix it.
    Installed a 6 gang blue sea fuse block and hard wired in a 4 usb block into the tent. Covered the fuse block in dielectric grease in an effort to prevent corrosion.
    I also swapped out my cracked tail light for a good one.
    50B92ED9-778E-467F-9DBF-F719E390A133.jpg 31FAB842-780B-4C49-9C15-A53609DEEE82.jpg 01BD520B-362A-4D13-BFCB-FA8FFBF68B0B.jpg 07F07F5F-5E5B-4327-A945-CB043CE1DF5B.jpg
  8. Nov 12, 2021 at 11:46 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    How does the LED strip and everything hold up in the tent when folding it up? That's one of those things that's been on my list for a long time but never bothered to get to haha
  9. Nov 12, 2021 at 11:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So far it's been just fine. I just leave a little slack at and of the bend points. Definitely recommend it, it makes a nice difference. This one is just a lumenoodle because I had it laying around.
    6 gearT444E[QUOTED] likes this.
  10. Nov 12, 2021 at 12:03 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Thanks, that makes sense. Maybe this winter when I run out of house maintenance items, other higher priority vehicle maintenance, I get to do this. I want to put an aux fuse box back there for the very reason you stated, I know that if I just put a 12V socket it'll be smoked in no time with the bed and wheel wells being open.
  11. Nov 15, 2021 at 10:15 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Chirp...chirp...chirp....chirp
    EatSleepTacos[OP] and y=mx+b like this.
  12. Nov 15, 2021 at 6:52 PM
    Dayman Karate
    Dayman Karate Ruffling feathers and turning eagles into vultures
    Clay
    Central Alabama
    2001 4Runner, JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Dear Mr. Randy,
    :typing:
    I seent you in a Baja Designs thread. I gots a question.
    Where did you mount your wide cornering lights? I picked up a pair of Squadron pro combo/driving and a pair of sport wide cornering. Not sure how to angle and place them for maximum ass blasting.
    Gunshot-6A likes this.
  13. Nov 15, 2021 at 6:58 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They’re all pointed dead straight forward. I have the outer two as WC and the inner four as spot. Creates a fairly good spread of lighting. I used to have them all as WC and the lightbar up top as all spot, but I found a more even spread with the outer lights WC and inner lights spot, both down low and up high.
  14. Nov 15, 2021 at 7:19 PM
    Dayman Karate
    Clay
    Central Alabama
    Very nice. I’ll follow suit. I’m curious to see if the WC overpowers the driving lights or if I can run both on the backroads. I went with the higher powered driving combos so hopefully not. I just want to be able to see a bit more wide than the fogs and add a bit to the mid range.
  15. Nov 15, 2021 at 8:31 PM
    y=mx+b
    y=mx+b Station Wagon
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    want lights, must resist!!
    Have secured an internship for the summer though, so maybe its gear and locker time. Then it can be light time
    but even before that is finish slider time. Have a week for thanksgiving, so gonna try to knock them out and possibly fabricobble a skid for the trans and tcase area
  16. Nov 16, 2021 at 6:54 AM
    My Name is Rahl
    That's not enough looomens!
  17. Nov 16, 2021 at 8:23 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Psh, we all know the overland conversion rate of 40,000 lumens = 1 locker. Ain't nobody got time for a re-gear and break-in :rofl:
  18. Nov 16, 2021 at 8:25 AM
    Gunshot-6A
    Conner
    Everett, WA
    @Rome604 really needs to take him to loomin skool.
  19. Nov 16, 2021 at 9:53 AM
    y=mx+b
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    Whats the conversion between number of rotopax and lumens?
  20. Nov 16, 2021 at 10:01 AM
    My Name is Rahl
    .003 to 1 rotopax to lumens.
    y=mx+b[QUOTED] likes this.
