The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Mar 31, 2022 at 6:37 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Couple of vendors make a transmission/power steering cooler kit that's plug and play. While the cooling fins on that pan are nice, it's the actual drain plug and elimination of the leak-prone retention dealios. Sucks I just did the service.
  2. Mar 31, 2022 at 6:48 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Adding this to your mix. B&M has been around for ever and had the oversized pans as well. I had one on my 96 tahoe years ago.
    https://www.holley.com/products/drivetrain/transmission_pans_and_accessories/toyota/parts/70393
  3. Mar 31, 2022 at 6:51 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Hafaday[QUOTED] likes this.
  4. Mar 31, 2022 at 7:03 PM
    Hafaday
    Bill
    Richmond, VA.
    Yes.. if… big IF.. I replace my clutch, I might go that route. The reason I say that is, I’m very use to the semi sloppy current shift pattern. Reading some reviews peoples say it’s a very tight shift pattern. Which is a good thing too. I will see when it comes down to it, though.
  5. Mar 31, 2022 at 7:05 PM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    Seriously. I don't jump for joy! I literally jumped up and down for 5 seconds when I did a triple backflip in this thing. Shortly after I cracked the steering servo which is a 30$ upgrade part. Yes it cost $ but the funfactor is there !!!
    got both :anonymous:
  6. Mar 31, 2022 at 7:07 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Broke a steering servo? Down the rabbit hole you gooooooo!!!
    Hafaday likes this.
  7. Mar 31, 2022 at 7:08 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    And this is exactly why I'm resisting buying one. They're worse than a real car.
  8. Mar 31, 2022 at 7:22 PM
    Hafaday
    Bill
    Richmond, VA.
    @crashdb Did your Rubi have the factory skids on it? Just wondering if so, because the cross over pipe for the trans hangs low on the auto box JK leading to the cooler. One mod was to cut it high on both sides to remove that section, double ferrule both ends, add hose and clamps to get it up out the way so it wasn’t the hanging low point.
    just throwing that out there if no skids.
  9. Mar 31, 2022 at 7:37 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    If you could call them that. I just bought an aftermarket exhaust system. Got rid of that crazy loop near the cat, crossover pipe is further back, and that suitcase muffler is no more!
  10. Mar 31, 2022 at 7:49 PM
    Hafaday
    Bill
    Richmond, VA.
    Cools. My bad on what I was trying to say.. there is a hard line for the transmission that hangs low between the trans, and engine. That is what I was to say.
    I guess I needs to work on my verbiage better.
    crashdb[QUOTED] likes this.
  11. Mar 31, 2022 at 9:08 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Is that the Losi version?
  12. Apr 1, 2022 at 4:58 AM
    08TRDOFFROAD
    Dan
    Only at first...When I switched to 3s in my basher, I was breaking something ever pack. But once I upgraded the things that were breaking, I got very reliable fun out of it. Now the only time I break something is when I send it too hard. I.e. my wheelie bar after I cartwheeled it a dozen times into the curb at nearly full throttle (50ish mph).
    EatSleepTacos[OP] likes this.
  13. Apr 1, 2022 at 5:24 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I must be harder on mine. The last two I got I would break something all the time. One of them barely even resembled the RTR I had bought it had so many hop-ups on it. I may just get this one I found. It's a cheap RTR, and it's a mini. I don't think there are many hop-ups for it, so I won't be able to spend money. And if it dies? No big deal.
    https://www.amazon.com/dp/B07YDSJF4D/?coliid=I2UV0XL5ML3XD2&colid=V2DPLUSYXPEL&ref_=gv_ov_lig_pi_dp
  14. Apr 1, 2022 at 5:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh sweet innocent summer child. The SCX24 has a HUGE following and there are endless mods you can do to it. Poke around on etsy. I have one and it is a lot of fun though, so if you want something to play around with, that's perfect.
    08TRDOFFROAD likes this.
  15. Apr 1, 2022 at 5:33 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I was born in the spring....
    Yes, I know there are hop-ups. I'm pretending they don't exist. Stop trying to make my fantasy world real life!
  16. Apr 1, 2022 at 6:22 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Felt cute, might delete later, idk
    Gunshot-6A, Rezkid, Slashaar and 7 others like this.
  17. Apr 1, 2022 at 6:45 AM
    My Name is Rahl
    What size spacers do you have on Betty?
  18. Apr 1, 2022 at 6:47 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just 1/2" on the rear. The poke just seems extreme due to the wheel specs, lack of flares, and the fact that the tire is so visible because of the bobbed bed.
  19. Apr 1, 2022 at 6:49 AM
    My Name is Rahl
    Ah. You get the spacing due to the wheel. I wondered why you would be running 3"+ spacers with all the heavy crawling you do.
  20. Apr 1, 2022 at 8:17 AM
    08TRDOFFROAD
    Dan
    I might have one of those too! Lol
