The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Oct 16, 2022 at 10:21 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    edit: I found some DOM for cheaper instead of using 4130.
    I'm trying something a little different since I have an extra driveshaft on hand. This lands somewhere in between the Wide Open Design DIY driveshaft and a homemade square tube driveshaft.
    My idea is I'll have a driveshaft for the trail and a driveshaft for the streets. To swap it, I'll just need to undo the 4 bolts at the rear axle and cut a zip tie on the slip yoke boot.
    The OD of the slip yoke is 1.105" and I'll weld on a 3" section of 1.75"x0.313 wall DOM, with an ID of 1.125 ID. This'll act as a sleeve to accept the driveshaft. That'll be 2"x.120 wall, ID of 1.76".
    The tail end has a 1350 spicer weld yoke meant to accept a 2"x.120 wall tube. I'll use a 1330 to 1350 conversion U joint for the end connection.
    $46 for a 3' section of DOM.
    $33 for a 3" section of DOM.
    $80 for the weld yoke and U joint off of Amazon
    $159 for everything.
    I just purchased all of the parts so hopefully I'll have everything on hand in about a week.
  2. Oct 17, 2022 at 7:45 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    AZ? So now Betty really can be a dried out raisin. :rofl:
  3. Oct 17, 2022 at 4:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  4. Oct 17, 2022 at 5:02 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
  5. Oct 17, 2022 at 5:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You think I can afford meth AND this hobby? No way.
    08TRDOFFROAD likes this.
  6. Oct 19, 2022 at 7:42 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Got my inspiration for my new rear bumper that I'll be building once the shackle flip arrives. I'll essentially just marry these two together. Build the one off of the silver truck @Evergreen_Offroad and add the wings off of the red truck @gtrotter07 since my bedsides are already cut.
    How it all mounts is tbd but I'm thinking I'll just weld this bumper on vs making it removable. I'm tentatively thinking I'll weld in a crossmember to the rear of the frame with a hitch coming out of that and then build the tubes off of the hitch. Then add end supports over near the wheel wells. We'll see how it looks once I get the bumper off and actually start this build process.
  7. Oct 19, 2022 at 7:59 AM
    Gunshot-6A
    Conner
    Everett, WA
    I'm loving the idea. Really like the swingout and use of blurple!
    Im sure @Justanotherhemi will have glowing reviews as well.
  8. Oct 19, 2022 at 8:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm quite impressed at the dedication to make that drawing.
  9. Oct 19, 2022 at 8:13 AM
    Gunshot-6A
    Conner
    Everett, WA
    I'm on a conference call I REALLY don't want to be on, and clearly it shows.
  10. Oct 19, 2022 at 9:01 AM
    gtrotter07
    gtrotter07 Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Mine has a crossmember welded in, and all welded to the frame. I can get more pics if you need to see anything. Credit for the bumper goes to @BigRedToy
  11. Oct 19, 2022 at 9:21 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm always down for more pics if you don't mind. I'm still somewhat new to the fab stuff and I'll take any inspiration I can get. After looking at pics more I think I'm going to do it a little differently than what I was originally thinking. Since my frame ends at the back of the shackle hanger, there's not a lot of extra room. I'll cap the end of the frame with 1/4" plate and have some 1/4" legs coming up (red) to hold the round tube where I want it. Since everything will be welded, the bumper will essentially act as a crossmember. I still want to put a hitch in the center for recoveries and will figure out some way to tie that into something else so I don't tweak anything on a good tug.
    Slashaar likes this.
  12. Oct 19, 2022 at 12:00 PM
    Gunshot-6A
    Conner
    Everett, WA
    By crossmember, he means swingout :D
  13. Oct 19, 2022 at 12:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh man oh man, these tolerances are so perfect. I’m so excited to get this welded up.
  14. Oct 19, 2022 at 2:14 PM
    gtrotter07
    It also has scab plates on the side, and of course the shackle flip bolted through. I'll try and get more pics later.
  15. Oct 19, 2022 at 2:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This is helpful! Thank you.
    08TRDOFFROAD and Slashaar like this.
  16. Oct 19, 2022 at 6:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Bringing this over here to stop spamming that thread lmao
    step 1: Unbolt driveshaft from axle
    step 2: slide rear portion out of slip joint
    step 3: cut off splines
    Step 4: use those splines to make the splined portion on the new driveshaft.
  17. Oct 19, 2022 at 6:34 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Alright I follow you there. Where’d that other piece come from with the spicer number you referenced? Haha I’m guessing it’s in the first section of driveshaft
  18. Oct 19, 2022 at 6:38 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This is what the spline section looks like when you buy from spicer. Driveshaft tube gets welded onto that left side plug, which I cut off.
    I was trying to source this so you could avoid cutting up your driveshaft but I can’t find it on its own DAEECEAA-D791-42CF-A402-B9E615580C45.jpg
  19. Oct 19, 2022 at 6:48 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Ahhh I gotcha now. I’m a little slow in the head.
  20. Oct 19, 2022 at 6:49 PM
    My Name is Rahl
    This truck stuff is boring. Can we please get back to the boxes wine?
    Gunshot-6A, Slashaar and geekhouse23 like this.
