The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Oct 6, 2017 at 1:38 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I would want to get a used decent one on craigslist. Im actually looking now, but the selection is poor. Ive found a welder, cart, extra wire, and gas for $400. That seems like a decent starting price to me
  2. Oct 6, 2017 at 1:39 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    That's not horrible. Then you wouldn't have to rewire your garage just yet,
  3. Oct 6, 2017 at 1:41 PM
    fatfurious2
    David
    Ashburn, VA
    I would. Because even a 110v needs more than a 15amp plug
  4. Oct 6, 2017 at 1:42 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I thought mig ran off straight gas? I haven't really looked at them at all.
    Edit: Ah, I looked a little more. Nevermind.
  5. Oct 6, 2017 at 1:48 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Monkeys can MIG. Learning stick first is helpful. Also, reading a book about the science behind it is priceless.
  6. Oct 6, 2017 at 1:49 PM
    fatfurious2
    David
    Ashburn, VA
    the gas is for shielding/cleaner welds.
    all this splatter, is from using no gas. Which you will have to clean up later with a flap disc or grinding wheel
  7. Oct 6, 2017 at 1:50 PM
    fatfurious2
    David
    Ashburn, VA
    this is true
  8. Oct 6, 2017 at 1:51 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @Mobtown Offroad said he uses some sort of spray on the metal which also helps reduce splatter. I'm curious what it is.
  9. Oct 6, 2017 at 1:53 PM
    fatfurious2
    David
    Ashburn, VA
    probably something like this. This is a known brand. They actually make Brakleen (which I love to use haha)
  10. Oct 6, 2017 at 1:57 PM
    fatfurious2
    David
    Ashburn, VA
    there is also high heat primer. Means you can prime the metal before you weld it.
    BravesRunner likes this.
  11. Oct 6, 2017 at 2:19 PM
    BravesRunner
    BravesRunner “Exploration is curiosity put into action”
    Adam
    SC
    2021 GMC Sierra 1500 Denali
    Grandpa steps//Tri-fold Tonneau bed cover
    Are the center holes of 16 and 17in wheels the same diameter? Want some flush TRD center caps for my wheels but I have 16s and the caps are for 17s.
    I assume they are but figured I’d ask.
    EatSleepTacos[OP] likes this.
  12. Oct 6, 2017 at 2:22 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm assuming they are as well
    BravesRunner[QUOTED] likes this.
  13. Oct 6, 2017 at 2:30 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    That weld appears to be done by a flux core welder, if so you cant use spatter spray and they dont use gas. Thats about as good as you get with a flux core. Weld looks a little cold but youll always get spatter with flux core. Youll need a scraper and to make the weld prettier, brush it with a wire brush.
    Kemosabe and JWROSE4 like this.
  14. Oct 6, 2017 at 2:37 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What does it mean when a weld is cold? Just bad penetration?
  15. Oct 6, 2017 at 3:05 PM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    I would take it as not enough heat. The guys in our fab shop use that spray at work. Tig isnt that bad. I never did it till I started the job Im at now and its surprisingly easier than one would think. It may not be pretty at first but that doesnt matter as long as you have good penetration and grinder and wire wheel.
  16. Oct 6, 2017 at 3:06 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Moar heat! Yes, penetration won't be the best. Have to play with voltage and wire speed to increase amps (heat)
  17. Oct 6, 2017 at 3:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just checked our target to see if they carried the pelican coolers. No dice.
    inesshell and fatfurious2 like this.
  18. Oct 6, 2017 at 4:25 PM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    I'm pretty sure Home Depot carries the pelican coolers @EatSleepTacos might Be worth a shot
  19. Oct 6, 2017 at 4:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was only trying because @inesshell posted a thread where they were selling the $200 for $59, so of course I had to check!!
    inesshell, fatfurious2 and JWROSE4 like this.
  20. Oct 6, 2017 at 4:42 PM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Well...I was planning on doing a quick run up Bald Mt this afternoon and I stopped by my parents house which is 10 mins from the trail. When I got to the house I was giving my truck a quick look over before heading out and noticed grease thrown all over the truck behind the drivers side front wheel. Did some investigating and my boot is torn on my CV shaft. I did the boot slide mod, so I am guessing I pulled it out too much. So now Im trying to decide do I buy a new cv axle and get reboot kits for this one and another one I have sitting at the house and have spares or do I reboot this one? I dont have much time to really mess with the truck with me getting stuck working every weekend. What to do? What to do?
