The leaky tonneau cover issue again...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crobran, Jun 25, 2021.
  1. Jun 25, 2021 at 9:04 AM
    Crobran
    Crobran [OP] Well-Known Member
    Texas
    `21 DCSB 2.7L Silver Sky
    Trifecta 2.0, Ionic Nerf Bars, Tailgate anti theft device from @christian06, Husky Weatherbeaters, Bed lights, OEM bed mat, Derped badges and grille bezel
    Does anyone have a list compiled somewhere of all of the different methods people have used to seal their tonneau covers? I've got a Trifecta 2.0 and it leaks in heavy rain even if I'm not driving. Most of the water is coming in through the gaps on either side of the front bed rail - not the gaps right along the top (Extang gave me foam pads to seal those) but the gaps under those. How do y'all seal those? What about sealing other areas?
    Methods I've seen so far....
    • Butyl tape along the rails and even wadded up and shoved into the aforementioned gaps along the front
    • Silicone caulk
    • Expanding foam sprayed into the gaps
    What has worked best for you?
  2. Jun 25, 2021 at 10:00 AM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    I just did the wadded up butyl tape a couple days ago, haven’t had the chance to see if it works.
  3. Jun 25, 2021 at 10:23 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    If you want stuff in back to be dry it's time to just concede defeat and get a 4Runner.
  4. Jun 25, 2021 at 10:47 AM
    cop414
    Tim
    Central PA
    :annoyed:
    Mark77 and jclamdip like this.
  5. Jun 25, 2021 at 11:33 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    This or go buy Rubbermaid totes.
    Screaminpotato and ugawino like this.
  6. Jun 25, 2021 at 11:38 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    They all leak
    jayuu, Superdave1.0 and jclamdip like this.
  7. Jun 25, 2021 at 11:49 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    My OEM doesn't leak at all.
  8. Jun 25, 2021 at 11:52 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Must be nice to live in Phoenix! ;)
    Screaminpotato and Skydvrr like this.
  9. Jun 25, 2021 at 11:52 AM
    OMGitsme
    Sold
    PA
  10. Jun 25, 2021 at 11:53 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    PA... Phoenix Arizona :D.
  11. Jun 25, 2021 at 12:04 PM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i have a generic hard cover that i worked with to stop the leaks. my experience likely applies to yours.
    the most important part was using a bright light source outside the closed cover and crawling inside
    to see where the light is getting in. its been years, but i recall having to use closed cell foam blocks, cut to size,
    attached to the metal sidewalls with contact cement under the rails and bed in each front corner. toyota made no attempt to make these beds waterproof
    so you'll have to find the leaks and innovate. my result was very successful but occasionally not perfect. a few dribbles get in in the driving rain.
    i also closed the "pattern" gaps on the top of the rail (that the cover non-patterned rubber seal sits on) with some foam tape and contact cement. the cover is on and closed 99% of the
    time so it is fine but with the cover off you see these little foam patches with compression marks where the rubber seal compresses them.
    i hope this gives you some ideas.
    ps. i also keep things i care about in a rubbermaid tub just in case.
  12. Jun 25, 2021 at 12:20 PM
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    I recommend a softopper.
    I ditched my bakflip because of leaks, bought a softopper to replace it. Drove home from a trip on Tuesday in a downpour - no water whatsoever in my bed. I have sometimes gotten a little bit of water leaking thru the gap between the front and side bed walls if I am parked on a slight incline with the front end pointed downhill. I bought butyl to try and seal this but now I just park nose up so the water drains to the tailgate. No more water ingress and I've never gotten around to messing with the butyl. I have never had a drop get in while driving. And we do get some heavy downpours in my part of the country.
  13. Jun 25, 2021 at 12:25 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My OEM cover only leaks if I spray water in the tailgate jam, no leaks from the sides or the front area just under the window. I did remove the shims out of the latches, made it a tight seal.
  14. Jun 25, 2021 at 12:30 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Like stated above they'll all leak to some degree. Think about it, they are made to open. That means they have joints of one type or another. Each joint is a potential point of failure. My Peragon is pretty darned tight, especially with the tailgate seal. Still after a heavy rain there's a bit of water in the bed. Not enough to damage anything but I have no expectation that anything made to be opened will be 100% waterproof.
  15. Jun 25, 2021 at 12:40 PM
    afret
    afret Well-Known Member
    North Idaho
    2021 SR5 DCLB
  16. Jun 25, 2021 at 12:40 PM
    VaToy
    Parts Unknown
    its not the cover that leaks its because I have not added a seal in the tailgate jam.
  17. Jun 25, 2021 at 1:13 PM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    I found that Coax Seal is great for sealing up leaks. My bed stays dry.
  18. Jun 25, 2021 at 1:28 PM
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    Does Phil Swift have a Flexseal tailgate tape or foam yet?
    Skydvrr likes this.
  19. Jun 25, 2021 at 1:38 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My factory cover only weeps a few droplets on the rear driver side during hard wind driven thunderstorms or hurricane like weather, otherwise its dry inside the bed the rest of the time. It seals pretty darn good imo.
  20. Jul 12, 2021 at 8:02 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    1/8" and 1/4" thick neoprene foam tape from Amazon worked for me. Cab corners were the troublesome spot on mine.
