The lean and the lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Itchy Dog, Mar 8, 2010.
  1. Mar 8, 2010 at 1:09 PM
    Itchy Dog
    Itchy Dog [OP] Well-Known Member
    Duvall, WA
    03 Double Cab TRD 4x4
    Pine Tree air freshener
    So I got my OME 883 coils & OME front/rear shocks and Wheelersoffroad 5 leaf rear spring pack installed, and it's almost exactly the look I was going for on my 03 Double Cab (new tires on the wish list, but not for a long while). The front was raised up just over two inches and the rear almost 2 inches. Now the rear needs another inch to make it look just right (it's 1/2 lower than the front after the install). What's my best option to get the rear up 1/2 to 1 more inch? My local mechanic says to wait a couple thousand miles and see if the springs settle.
    Also, what of the old Taco lean? My truck seems to list about a half inch to the driver's side. Is it a body issue? What have you guys done to correct this, if anything? I can live with it, but if I can fix it I'd rather not live with it.
  2. Mar 8, 2010 at 1:14 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    yep... let the front suspension settle first...
  3. Mar 8, 2010 at 1:15 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    if it still isnt to your liking look at a shackel lift.
  4. Mar 8, 2010 at 2:13 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Fuel tank, driver and battery are all on the driver side...hence the driver side lean. ToyTec makes a 1/4" top spacer kit to compensate.
  5. Mar 8, 2010 at 3:11 PM
    Itchy Dog
    Duvall, WA
    Not saying you're wrong, but I just have a hard time believing this.
    What does a battery weigh- 15-20 pounds? Even with an empty tank, and no driver sitting in the truck, with all new springs, it still leans. That just doesn't make sense. There's got to be, in my mind anyway, something else to look at to explain the lean.
  6. Mar 8, 2010 at 7:13 PM
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    its called the taco lean and it is very common in the tacoma. it has to do with weight dist.
  7. Mar 8, 2010 at 11:31 PM
    Itchy Dog
    Duvall, WA
    Ever since I got the truck and started reading I've heard of the Taco Lean.
    But I assume it doesn't affect every truck, right? If not, why not? It's just one of those things that will plague my conscious thought until I can find an explanation :confused:
  8. Mar 9, 2010 at 9:27 AM
    sirsaechao
    Tim
    Commifornia
    It does affect every truck but varies.
  9. Mar 9, 2010 at 9:41 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    i'd say the battery is closer to 50 lbs from when i lifted it out. together with a 200 lb guy driving and 150 lbs of gas, that's about 400 lbs extra on the driver's side. i'd say it's significant...
