The LED Rock Light Showdown
Discussion in 'Lighting' started by crashnburn80, May 31, 2019.
  1. Oct 12, 2019 at 8:13 AM
    #81
    MassAppeal16
    MassAppeal16 Well-Known Member
    Carrollton, KY
    17 TRD MGM DCSB
    crashnburn80[OP] likes this.
  2. Oct 12, 2019 at 8:48 AM
    #82
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    FYI - @Taylor@KC HiLiTES is traveling and working double duty, he is pretty challenging to get a hold of right now. There is a bit more info on their vendor thread.
  3. Oct 14, 2019 at 6:30 AM
    #83
    MassAppeal16
    Carrollton, KY
    17 TRD MGM DCSB
    Maybe someone had asked this before and would know the answer. I see online they have a jeep kit with harness. Is there anything like that for us? Would like to put 6 of these on my truck but hate piecing thins together.
  4. Oct 14, 2019 at 6:44 AM
    #84
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    a harness really isnt needed. i bought a switch to fit next to my factory foglight switch. connected it to constant power right next to the fuse box and grounded it behind the kick pannel. clean, simple, done.
    GonzoQuick likes this.
  5. Oct 15, 2019 at 5:22 AM
    #85
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  6. Nov 16, 2019 at 9:49 AM
    #86
    Taco-Obsessed
    sub for future reference
  7. Nov 16, 2019 at 5:43 PM
    #87
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i have no regrets with my difused cyclone kc's @crashnburn80 made the decision simple with all his testing. thank you:hattip:
  8. Nov 16, 2019 at 5:51 PM
    #88
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i went with clear underbody lighting. but @crashnburn80 just helped me mount up some rigid d-series foglights. i think the amber kc's would compliment it very well. maybe our lighting guru could thow his opinion out on this.
  9. Jan 4, 2020 at 5:52 AM
    #89
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    For those that started running the KC Cyclones after reading this thread, how are they holding up? I wanted to go with them but reading numerous reviews on Amazon of them failing or moisture in them has me hesitant. I wonder if that's why some of the lights in the review are injected with that plastic stuff, to help with durability from being mounted under a truck.
    https://www.amazon.com/KC-HiLiTES-1...show_all_btm?ie=UTF8&reviewerType=all_reviews
  10. Jan 4, 2020 at 6:49 AM
    #90
    Jesse
    Poulsbo
    15' DCSB OR S/C
    as ive learned Amazon often buys overstock, or b-grades, stuff out of date. im very happy with mine. would definately buy more.
  11. Jan 18, 2020 at 6:54 PM
    #91
    2barevo
    2barevo Member
    ebbs15 likes this.
  12. Feb 6, 2020 at 7:07 PM
    #92
    2BeersPlease
    2BeersPlease Well-Known Member
    @crashnburn80 - I'd be curious to know how these $13 lights perform compared to the big names. I compared (visually) the output to a BD rock light I have and they appear to be brighter.
    LUYED Super Bright 3020 6-EX LED https://www.amazon.com/dp/B075N5LTNT/ref=cm_sw_r_cp_apa_i_JSmpEb6B6PWWR
    Edit: I can send you one if you want to test it.
  13. Feb 6, 2020 at 10:43 PM
    #93
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note that Baja has some of the worst performance in rock lights as shown in the lux measurements below compared to the competition, so it wouldn't be surprising to find a light to outperform it. The light you have listed is labeled as a reverse camera 'backup light', not sure why that is a thing since the camera should just use your reverse lights. And if wanting brighter reverse lights, I'd do this. However, while even if your new found light is brighter, I bet Baja lasts longer and is a better color temp.
    I'm usually up for testing proposed products, but I currently have a major backlog after having my equipment offline for a few months and way too many products stacking up, and I also try to stick to quality major name brands so that recommended products are in it for the long haul vs the cheap Amazon chinesium of off brands with short/if any warranties.
  14. Feb 7, 2020 at 6:01 AM
    #94
    2BeersPlease
    I don't get the reverse light-specific thing. It's a light. Use it where you want light. I put one in the cap on my 1st gen. Works great. I guess I'll find out how long it lasts.
  15. Feb 7, 2020 at 8:58 AM
    #95
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Agreed, I think in this case it is just the angled mount vs a rock light that has a traditional flat mount.
    Edit: the angled mount does look to work really well in those locations though!
  16. Feb 7, 2020 at 9:15 AM
    #96
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Stupid question de jour:
    Just how many of these do you actually need? :notsure:
  17. Feb 7, 2020 at 9:28 AM
    #97
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Well depends on what/where you are trying to illuminate. Now I have cheap Amok knockoffs of the Rigids but I'm running 11 of those to get some good illumination.
    This was before I added one more on each side and one dead center in the back.
  18. Feb 7, 2020 at 10:57 AM
    #98
    Cfincke
    Cfincke Well-Known Member
    San Antonio TX
    2014 Tundra 1794 sunset bronze
    Icon front & rear shocks, icon UCA, Method Standards, Nitto Ridge Grapplers, Retrax cover, TRD sway bar
    Depends on how much light you want
    Ddeyx1KJ9QWnlyrxCBC0Hd6XbVfl9Tp35Toz7LwU_6c35515bcd00d0eaa8d95660546068a335176067.jpg
    and what you want to be able to do
    UgqPBMT6vjc3t9JhBUtSXVls1hEAMipTXOWuJckW_498bdb37bec5fd3f151fc2a82487ba424b41572b.jpg
  19. Feb 7, 2020 at 11:15 AM
    #99
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ive got 4
    FastEddy59[QUOTED] likes this.
  20. Feb 7, 2020 at 11:38 AM
    #100
    FastEddy59
    Eddie
    That's a dam Moon Landing right there. :laser:
