The LED Rock Light Showdown
Discussion in 'Lighting' started by crashnburn80, May 31, 2019.
  1. Aug 30, 2021 at 12:58 PM
    #141
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    KC has a new and improved Cyclone.
  2. Aug 30, 2021 at 1:37 PM
    #142
    xMaverickx
    xMaverickx Well-Known Member
    Jeremy
    New Brunswick, Canada
    2016 MGM Limited V6 4X4 DCLB
    I don’t imagine that lens is backward compatible is it.
  3. Aug 30, 2021 at 1:45 PM
    #143
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I’d highly doubt it, I believe the v2s are slightly larger in diameter.
  4. Aug 30, 2021 at 4:35 PM
    #144
    xMaverickx
    Jeremy
    I think I seen 2.2” diameter on both.
    Grossomotto likes this.
  5. Aug 30, 2021 at 7:25 PM
    #145
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    IIRC talking to KC a while back before they released, the said the v2s were slightly larger. Maybe it wasn’t diameter. I’ll get my hands on some to compare being the previous cyclone was the best performing light in the thread.
    xMaverickx[QUOTED] likes this.
  6. Aug 31, 2021 at 4:29 AM
    #146
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    I've got 6 of the old ones on now. I have 2 of the V2's that should arrive Friday. KC_Rocks.jpg
    Toy_Runner likes this.
  7. Sep 1, 2021 at 7:15 AM
    #147
    xMaverickx
    Jeremy
    Awaiting measurements from either you or Crash. I have a KC5 that I just bought two clear V1’s for but I can’t find any red’s in V1. I still have 2 old red v1’s that aren’t cracked but that still leaves me shy one. I have 4 total cracked cyclones, 2 died from moisture 2 are still okay. Probably just going to cut up some lexan to make new lenses and use the good ones as rock lights.
  8. Sep 14, 2021 at 12:33 PM
    #148
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  9. Sep 14, 2021 at 12:35 PM
    #149
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    DSIM has one too, we had a few compare-and-contrast discussions between the two options in his thread.
  10. Sep 14, 2021 at 12:37 PM
    #150
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Nice, I hadn’t seen that. Need one for the JT so I’m not hacking up my wiring. :)
    daveeasa[QUOTED] likes this.
  11. Sep 15, 2021 at 10:18 AM
    #151
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Posted in another thread but want to document for posterity here so I don’t have to dig through my Amazon purchase history for reference.
    Here are the neodymium magnetic I purchased to mount my cyclones under the truck. I went with the 92lb units. These are absurdly strong and difficult to remove once attached.
    Without having the Cyclone attached to the magnet, It would be almost impossible to remove from the toolbox.
    MUTUACTOR 4Pack Super Powerful Round Cup Magnet with 1/4''-20 Male Threaded Stud, 92lb Vertical Pull-Force Non-Shattering Neodymium Magnet with Nut and Washer for Lighting, Camera and Other Brackets
    $16 MUTUACTOR 4Pack Super Powerful Round Cup Magnet with 1/4''-20 Male Threaded Stud, 92lb Vertical Pull-Force Non-Shattering Neodymium Magnet with Nut and Washer for Lighting, Camera and Other Brackets
    https://www.amazon.com/dp/B0837WY4MJ?_encoding=UTF8
  12. Sep 29, 2021 at 10:52 AM
    #152
    Cfincke
    Cfincke Well-Known Member
    San Antonio TX
    2014 Tundra 1794 sunset bronze
    Icon front & rear shocks, icon UCA, Method Standards, Nitto Ridge Grapplers, Retrax cover, TRD sway bar
    received this email today
  13. Sep 29, 2021 at 11:26 AM
    #153
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    12w is pretty extreme! That would get blisteringly hot, curious on how much output drop will occur for it to stabilize as there isn't much mass as a heat sink for that power level. $200 though... Based on power level that would be about 2 cyclones, which would cost $60. And obviously you typically run many rock lights if using for ground illumination under the truck.
    ovrlndkull and BrandX like this.
  14. Sep 29, 2021 at 1:39 PM
    #154
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Wonder if it's for a kit or pair or something. Also they could be relying in mounting to help aid in cooling. Lastly if they'll really warranty for me smashing them on rocks I'm in!!! Not really I want to see your testing first for that kind of money and how much spread its got etc
  15. Sep 30, 2021 at 12:12 PM
    #155
    2013XSPX
    GA/FL Border
    2013 XSP-X
    The output on the V2 is fantastic. The color is slightly different. More deeper of a color than V1.
  16. Oct 1, 2021 at 5:56 AM
    #156
    Cfincke
    San Antonio TX
    just looked at the web site, $40 for a single 12W pod or $200 for a kit of 4.
  17. Oct 1, 2021 at 10:53 AM
    #157
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is certainly far more reasonable.
  18. Nov 6, 2021 at 2:15 PM
    #158
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I can't wait to see the testing on the DD rock lights they announced at SEMA! If it's anything like their other lighting I'll for sure be a convert!
    patdeezy and crashnburn80[OP] like this.
  19. Nov 18, 2021 at 6:21 PM
    #159
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    This!
  20. Nov 19, 2021 at 3:55 AM
    #160
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    For anyone looking for specs, the cyclone V1 and V2 are the same diameter and depth. The back of the V2 is a bit different and center hole is slighly smaller and comes with a rubber plug.
    Although, I like the V1 look much better. The outside edge of the V2 is an eye sore, but you can change lenses with other V2 lights (not backwards to V1).
