The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Oct 10, 2018 at 8:07 AM
    #261
    neverenoughdirt
    neverenoughdirt Well-Known Member
    Brian
    Los Angeles County, Calif.
    2018 DCSB OR AT 4x4
    Very interested in this info and looking forward to your findings!
    If you're able to also include recommendations for:
    "top of the line type"
    "bang for the buck type"
    "tight budget type"
    This will be helpful.
  2. Oct 10, 2018 at 8:16 AM
    #262
    Rebelman21
    Rebelman21 Well-Known Member
    Cleveland
    2021 SR5 DCSB Super White
    None yet, several planned
    Ok, thanks for the information.
  3. Oct 10, 2018 at 8:16 AM
    #263
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    That info is the the first post...Cliff Notes section.
    crashnburn80[OP] likes this.
  4. Oct 10, 2018 at 8:59 AM
    #264
    neverenoughdirt
    Brian
    2018 DCSB OR AT 4x4
    Thanks for the reminder. I either forgot or missed it entirely. I will revisit the first post after the next review.
    @crashnburn, thanks a bunch for your work. I learned so much. I don't want to blind others and have used your info on a purchase decision. (Got philips halogen low beam instead of HID). Now looking at fogs next. Thanks again!
  5. Oct 10, 2018 at 10:18 AM
    #265
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I took this to mean recommendations for amber SAE pods. But yes, I’ll put together a section in this thread devoted to just amber lights with recommendations.
  6. Oct 10, 2018 at 11:41 AM
    #266
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  7. Oct 10, 2018 at 7:32 PM
    #267
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    70 people on the thread. I’d say there is a little interest in the Rigids.
    Edit: ok 90+
  8. Oct 10, 2018 at 7:47 PM
    #268
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    o_O
  9. Oct 11, 2018 at 12:30 PM
    #269
    Lanayru
    Lanayru Well-Known Member
    2016 Quicksand Tacoma OR
    @crashnburn80
    In the comparison of the two Rigid versions, the new prototype appears to have a shorter beam. Was that the case? The original Rigid looks to cover more vertical space.
  10. Oct 11, 2018 at 12:57 PM
    #270
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Good question.
    The pictures in the spectrometer screen shots are not relative. You can see that the lights using the cover appear brighter in that photo, which is overexposed. I think I was trying to capture the cut offs in that one where as the other I was trying to capture color without overexposing the shot. Really a DSLR would be more appropriate.
    But in short the beam pattern width is the same for both lights.
  11. Oct 11, 2018 at 7:53 PM
    #271
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Updated Rigid SAE amber post with a lens temp IR reading after running for 40 min.
  12. Oct 12, 2018 at 4:31 PM
    #272
    Vjtrey1
    Vjtrey1 Well-Known Member
    Richmond, Tx
    2018 Super White Tacoma TRD OR DCSB
    Simple mods
    Hi can I please have a link to where can I order rigid sae amber color fog lights and mounting brackets thanks
    xxTacocaTxx and crashnburn80[OP] like this.
  13. Oct 12, 2018 at 4:39 PM
    #273
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    They aren't available yet. That is a pre-production unit he was testing.
  14. Oct 12, 2018 at 5:19 PM
    #274
    DirtJumper14
    SoCal
    2005 TRD OR
    @crashnburn80
    Just curious but have you tested the older version of the Rigid Dot pods compared to the newer version? I am running the first version and was told by sidetracked that the new ones are brighter, although not by much. Do you have any info between the two by chance?
  15. Oct 12, 2018 at 5:39 PM
    #275
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    As @DirtJumper14 mentioned, these are pre-production prototypes, production has not started. But they are coming soon.
    The LEDs did not change at all, it is just the optics. Claims are wider, brighter and smoother pattern. Makes me curious how much of the amber gains were due to the new optics as I did compare it to the previous SAE model I had on file. I'll have to ask Rigid's engineering team.
    DirtJumper14[QUOTED] likes this.
  16. Oct 12, 2018 at 5:41 PM
    #276
    DirtJumper14
    SoCal
    2005 TRD OR
    Thank you. I have been thinking about upgrading them if that is the case. I patiently await your response. :cheers:
  17. Oct 12, 2018 at 9:19 PM
    #277
    SaphiraTaco
    SaphiraTaco Well-Known Member
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    About halfway done...
    Wow I really didn’t think the performance would be that great. Do you think the lens could be backwards compatible? For the people that have the clear rigid currently?:boink:
    Now the race for amber options has upped the ante.
    Excited to see the Amber KC G4’s
  18. Oct 12, 2018 at 11:35 PM
    #278
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Optics and lens are swappable with the current SAE pod. However getting just those parts may be a challenge.
    And don’t forget Morimoto is launching an amber SAE pod too. I’ve got them on order as well.
    SaphiraTaco[QUOTED] likes this.
  19. Oct 13, 2018 at 5:00 AM
    #279
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    I ordered a set of KC G4 ambers for C$330 a few days ago, so I rushed to compare your G4 test results with these new Rigids. G4 white tested out at 296 lux, and according to KC website output of the amber is the same (doesn't seem correct). To me, the Rigid construction looks bomb proof but output is not that much more than the G4s (318), and the Rigids are likely to be way more $. So G4 looks to be slightly better value for money?
  20. Oct 13, 2018 at 8:19 AM
    #280
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    KC shows the same lux numbers for the amber G4 as they do their white G4 on their website, which I agree doesn’t seem accurate but if so it would be an impressive feat. Rigids use a filtering lens over a white LED which is less efficient than KCs true amber LED source, and KC uses more efficient reflectors on top of that. If the KC ambers are indeed the same output level, then the Rigids would be just slightly higher in output (almost a wash at 7%) and their color temp will be a little more yellow vs KC which will be a bit more amber according to the specs. I personally like the near stock stealthy look of the KCs far more than the pod look which also requires adapter plates. The one real advantage to the Rigids would be the heated lens caused by filtering out the short wavelength light. I should get the KC G4 ambers next month for a better comparison.
