The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Apr 11, 2020 at 1:43 PM
    #3041
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    The sports definitely have sharper cut offs, they meet the more modern tight F3 spec whereas the Pros do not, they meet the older F fog spec. Keep in mind the BD wide cornering lights are in no way a fog light and don't have cut offs, they will emit drastically more light above the horizon than the SS3 Pros. Even Baja's low output SAE lights emit more light above the horizon than the Pros. So you will see a huge improvement over what you are running now either way. I haven't yet had the opportunity to run the Pros in the snow or heavy fog to comment on real world performance in poor weather, but with selective yellow and in an actual fog pattern I'm sure it wouldn't be an issue.
    Tibetan Nomad and Taquitoma like this.
  2. Apr 11, 2020 at 2:21 PM
    #3042
    Taquitoma
    Taquitoma Well-Known Member
    2017 OR DCSB M/T
    Thanks to all the work you've put in this thread, I'm very aware now :)
    Last question along the lines of poor weather performance, would you say there's a point where brightness of the light does more harm than good? Just trying to avoid the mistake of buying the Pro's when they might be overkill, simply because they're the baddest and brightest!
  3. Apr 11, 2020 at 3:15 PM
    #3043
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I'll let @crashnburn80 answer, but I can offer some thoughts based on more than a few years of experience too. Brightness / power is not as big of a problem in poor weather as poor beam discipline. Said another way, focused light is your friend. Unfocused light is your enemy. That's why it's so important to match the beam pattern of a light to your use / need. Unfortunately, many folks think all lights are the same. Well, many cheap lights are the same. And those are generally the lights that cause the biggest problems. A fog light with a good cutoff - properly aimed - should not cause problems for either the driver or oncoming traffic. This thread will give you some more information on beam patterns and uses:
    https://www.tacomaworld.com/threads/automotive-lighting-101.534393/
    Getting back to your question of SS3 Sports vs Pros, I can personally attest to the fact that the Pros are not "too powerful."
  4. Apr 11, 2020 at 5:46 PM
    #3044
    Willyummk
    Willyummk Well-Known Member
    Will
    HA TO CA
    2011 DCSB TRD Sport
    Following all of this, if/when DD comes out with a 05-11 bracket I’m selling my selective yellow rigid’s. Going to pick up a set of their pros in amber.
    SAR Taco likes this.
  5. Apr 11, 2020 at 5:56 PM
    #3045
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I was one day late for the 15% discount,
    I emailed them and hoping they’ll help me out lol!
  6. Apr 11, 2020 at 6:06 PM
    #3046
    Taquitoma
    2017 OR DCSB M/T
    crashnburn80[OP] likes this.
  7. Apr 11, 2020 at 10:17 PM
    #3047
    mblume7
    mblume7 2017 Cement TRD Pro
    Mitch
    Salt Lake City, UT
    2017 Cement TRD Pro
    I would recommend reaching out to Roman @ Neo garage. Has a website or you can reach him through Facebook. He will hook you up with a good deal and free shipping. That's who I got mine through.
    rdpoe likes this.
  8. Apr 12, 2020 at 5:06 AM
    #3048
    TegoTaco
    Ontario, Canada
    I tried, they want to charge $281usd to ship.
  9. Apr 12, 2020 at 5:08 AM
    #3049
    TegoTaco
    Ontario, Canada
    where did you play your order?
  10. Apr 12, 2020 at 9:51 PM
    #3050
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    @crashnburn80 I figured you would be the person to ask. You seem to be the resident expert when it comes to fog lights.
    I found a pretty awesome deal on a set of white ss3 fog lights. I would prefer the yellow version. Is the lense what makes it yellow? Or are the led's itself also yellow? This will decide whether I pull the trigger or continue to wait for a yellow set. Thanks a bunch!!
    Edit. Found my answer. Looks like the yellow fogs have a lower temperature than the whites. You do awesome reviews on these lights. Thanks for doing all that for the TW community.
    Biscuits likes this.
  11. Apr 12, 2020 at 9:52 PM
    #3051
    Spike Spiegel
    Spike Spiegel Well-Known Member
    2019 Super White Toyota 4Runner TRD Off-road Premium
    Eibach Pro Truck Lift, JBA High Caster UCA’s, Falken Wildpeak 275/70/17, Spidertrax Spacers
    The Yellow variant uses a different k emitter. Get the Yellow. Trust me.
  12. Apr 12, 2020 at 9:57 PM
    #3052
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The white lights use 6000k emitters, the yellow lights use 4000k emitters in addition to the yellow lens. Using a yellow lens on a 6000k emitter light is going to have a more green colored hue and sustain larger filtration losses than a 4000k emitter light. If you want a yellow fog light, you definitely want to get the yellow SS3 and not try to use a yellow lens on the 6000k light. For poor weather use I highly recommend going with the selective yellow.
  13. Apr 13, 2020 at 12:03 AM
    #3053
    Taquitoma
    2017 OR DCSB M/T
    Prolightz. Definitely your best bet if you're in Canada too.
    Also, pro tip: add the lights to your cart, enter in your email address, then don't check out. You'll get an automatic e-mail with a 10% off code
    Cementhead 2020 and IanB like this.
  14. Apr 13, 2020 at 5:41 AM
    #3054
    TegoTaco
    Ontario, Canada
    Not working with me...damn lol!
  15. Apr 13, 2020 at 6:45 AM
    #3055
    TegoTaco
    Ontario, Canada
    Thanks man! Saved me about $100!! Got my myself the yellow SS3 PRO’s. :D
  16. Apr 13, 2020 at 6:47 AM
    #3056
    Too Stroked
    Tom
    Prepare to be astounded. Just make sure to aim them carefully.
    Philrab and FastEddy59 like this.
  17. Apr 13, 2020 at 6:57 AM
    #3057
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    So aim selectively, like a Pro then.
  18. Apr 13, 2020 at 6:45 PM
    #3058
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    SOB, I was about to place my order for the yellow SS3 Pros and of course the sale is no longer valid. Anyone know of any other deals going on right now on these?
    @crashnburn80 Amazing thread you have put together here. Your research and postings are some of the best and most informative I have ever seen on an automobile forum. Thank you!
  19. Apr 14, 2020 at 6:14 AM
    #3059
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Wait for Memorial Day.
    Sandman TRD[QUOTED] likes this.
  20. Apr 14, 2020 at 7:05 AM
    #3060
    Sandman TRD
    Indy
    So is there any reason, if cost wasn’t a factor, that one would go with the SS3 Sports over the Pros? From what I gather, the Pros are brighter and give off more heat, but the Sports have a more direct cut off. If cost was the same, why would one go with the Sports over the Pros? I believe I am sold on the yellow Pros but just want to make sure I am not missing anything.
