The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Sep 12, 2020 at 8:27 AM
    #3421
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  2. Sep 12, 2020 at 9:09 AM
    #3422
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    eclane and Toy_Runner like this.
  3. Sep 12, 2020 at 9:11 AM
    #3423
    memario1214
    Colton
    Missoula, MT
  4. Sep 12, 2020 at 9:15 AM
    #3424
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Some reason I always think of Walmart when someone mentions Rough Country :notsure:
    tattooedsnake and memario1214 like this.
  5. Sep 12, 2020 at 1:43 PM
    #3425
    snahfu
    snahfu Member
    Anyone know if the supplied ss3 screw is a m3 or m5. Thanks!
  6. Sep 13, 2020 at 8:00 PM
    #3426
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I was surprised how dark the Rigid covers are in person. I have the Pro lamps (which I know didn't do all that great in your testing) as I purchased them pre-test and I dig how they look (I know, I know). Since I've had yellow fogs on every single vehicle I've owned over the years, I wanted to see how the covers performed. The end result at night is the correct color hue that I don't believe a lighter cover would get me, but the output to my eyes is definitely significantly reduced. Maybe it's simply changing from lots of foreground light with a brighter Kelvin rating compared to the lower Kelvin rating (apparent) with the covers, but it feels like my foreground light is heavily reduced. That being said, I like the color change and will live with these for now.
    I typically change out my fog lamps for winter so they don't end up getting destroyed by snow / ice, and I run yellow Hella bulbs per one of your recommendations. Maybe if I ever see a set of second hand DD lights cheap I'll jump on them. I like that they're not cubes now.
  7. Sep 14, 2020 at 7:10 AM
    #3427
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    @Diode Dynamics
  8. Sep 14, 2020 at 7:15 AM
    #3428
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Diode Dynamics support is awesome answering stuff like this.
  9. Sep 14, 2020 at 8:13 AM
    #3429
    Diode Dynamics
    Diode Dynamics Automotive Lighting Experts Vendor
    St. Louis, Missouri
    Quite a few screws used, which one are you referring to exactly? For the base set of lamps:
    It mounts up to the fog bracket with these:
    2x HW0054 Nut Nylon Lock 10-32 18-8 SS (McMaster: 91831A411)
    2x HW0055 Washer #10 18-8 SS (McMaster: 92141A011)
    2x HW0069 Screw 10-32x1/2 Socket Head 18-8 SS (McMaster: 92196A269)
    These are used to mount the bezel to the lamp:
    4x HW0059 Screw Torx M4x0.7 8mm Button SS w/ Nylon Patch T10 Drive (McMaster: 90991A121)
    It mounts up to the universal brackets with these:
    2x HW0053 Screw 10-32x7/16 Socket Head 18-8 SS (McMaster: 92196A268)
    These are included to bolt the universal bracket to your application:
    1x HW0030 Washer 5/16 0.344 ID 0.75 OD 18-8 SS (McMaster: 92141A030)
    1x HW0048 Bolt Short Neck Carriage 5/16-18x1" 18-8 SS
    1x HW0049 Washer Split Lock 5/16 18-8 SS
    1x HW0050 Nut 5/16-18 Hex 18-8 SS
    If there's one you need above you can't source, just give us a ring. Thanks!
  10. Sep 14, 2020 at 7:37 PM
    #3430
    HenrikBP
    HenrikBP Well-Known Member
    Henrik
    SF, New Mexico
    2010 DCSB TRD Off-road
    I'd hoped DD was using the 4000 Kelvin LEDs in their amber light bars as well so I could've swapped for a clear lens, but that's not the case. I'm not a fan of the high Kelvin "cool" color lights. I don't like the color rendition and feel they strain my eyes. 4000 Kelvin high CRI led lights would be great (hint, hint).
    Maroon96 and Hayrider like this.
  11. Sep 14, 2020 at 8:21 PM
    #3431
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    I agree. The Stage Series bars are older and do not have the new advancements that the SS3 has brought to the table. They work fantastically but I would also love to see the one-piece optics and color optimization incorporated.
    For what it's worth, there is actually a sizable color temp delta between the bars and the Pro SS3. I believe the bars use the same chips (P̶h̶i̶l̶i̶p̶s̶ LumiLED Luxeon Z ES) as the sport SS3 pods. Crash measured those at about 5500K, while the chips in the Pro SS3 (Cree?) measured at about 6400K. So while they're each close to the advertised 6000K, there is a 900K delta. It's certainly noticeable when viewed side by side (or over/under like I have here). The bar is on the roof rack, pods in between the headlights.
    Please don't trust the color in this photo, the true color of the bar is not quite this warm. I would say that the white of the bar is very neutral, maybe a touch blue. The Pro pods, on the other hand, are much more noticeably blue- and that is why I switched.
    Keep in mind that other brands that have been measured here (like KC gravity series etc) are usually a little higher than 5000K (like 5200K). So the difference is not as big as you might think.
  12. Sep 15, 2020 at 8:03 AM
    #3432
    HenrikBP
    Henrik
    SF, New Mexico
    Thanks for the additional information and color numbers. I have a BD light bar and pods with an advertised 5000 Kelvin color temperature and I like them well enough, but they're still too "cool" for my taste.
    I use LED headlamps and flashlights regularly (volunteer Search & Rescue), and "Neutral White" (around 4000 Kelvin) high CRI LEDs provide a very useful and comfortable light. Light output is slightly lower than the cooler LEDs but not enough to be noticeable in use.
    Sorry for the thread-drift - back to the regular programming :)
    mynameistory[QUOTED] likes this.
  13. Sep 15, 2020 at 8:52 AM
    #3433
    Diode Dynamics
    St. Louis, Missouri
    Thank you for the output comparison image. Our Sport Pods and Light Bars use the same LED Chips- Luxeon Z ES. The Pro pods do use Cree XP-L LEDs. With our SS3s, you can put a clear lens on a yellow SS3 for a nice warm white output. Unfortunately, since our Light Bars use the same temperature LEDs for both the amber and white, you cannot do this by switching lenses.
    -Collin
  14. Sep 15, 2020 at 4:15 PM
    #3434
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    Thanks for the clarification, Collin. I've edited my post to reflect. Does Diode Dynamics have any long range future plans to retool the Stage Series line to incorporate the improvements made to the SS3?
    Greg.Brakes.Tacos and HenrikBP like this.
  15. Sep 16, 2020 at 8:02 AM
    #3435
    Diode Dynamics
    St. Louis, Missouri
    We don't have any updates on a Stage Series Light Bar redesign at this time. However, we do have some pretty awesome new Stage Series products that we plan on releasing very soon. Be on the lookout for those updates!
    -Collin
  16. Sep 16, 2020 at 2:51 PM
    #3436
    IPT
    IPT Well-Known Member
    Lou
    SS3 fog SAE version - Sport vs pro - $100 more, and presumably brighter. Still both street legal? Why would someone want the tamed down version? Are the pro's bright enough that they still would be a distraction or issue to oncoming traffic? Can they be used around town? I'm looking for function particularly in snow and or rain. These are not going to be just for show :).
    Also, what is the overall height mounted? I found the height of the light itself, and the bracket, but not the height to the top of the light while in the mounting bracket. I'm guessing they are about 3.75 inches..
    http://images.diodedynamics.com/doc...Stage_Series_3in_Worklight_Pod_Info_Guide.pdf
  17. Sep 16, 2020 at 3:15 PM
    #3437
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I think the Sport vs Pro is personal preference. I get what I need from the sport and saved some coin. My headlights take care of the rest of my lighting needs.
    Toy_Runner likes this.
  18. Sep 16, 2020 at 3:26 PM
    #3438
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Snow aspect the pros will be hotter for snow melting purpose.
    I've had the pros since they hit the market, though have be a fog lights for nasty weather driving. Never been flashed for what it's worth, even when running them in fair weather driving the first few weeks after installing them.
  19. Sep 16, 2020 at 6:28 PM
    #3439
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can see my full review and comparisons of the SS3 Sport vs Pro here, in post #2725. The Sport meet the modern F3 spec which requires much sharper cut offs, the Pros meet the old F spec. Both are street legal. I think it is great that Diode Dynamics has given buyers options at different price points, and many color options with the available 4000k. Whereas most other brands only offer typically 2 different fogs, Diode Dynamics effectively offers 6 different options between Sport/Pro and selective yellow/4000k/6000k.
    xxTacocaTxx likes this.
  20. Sep 16, 2020 at 6:33 PM
    #3440
    snahfu
    snahfu Member
    Too much foreground light constricts the pupils and can take away from what you can see in the distance. (certain driving situations)
    Has anyone personally experienced this?
