The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Sep 18, 2020 at 10:40 AM
    #3461
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    The whole "flashing" thing is anecdotal at best. I've been flashed at least a half dozen times when my truck was completely stock with dim factory halogen low beams and no lift.
  2. Sep 18, 2020 at 1:05 PM
    #3462
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Agreed. The challenge for me has always been how to improve my night vision through better lighting without bothering oncoming drivers. Some folks don't worry about that second part very much.
    memario1214[QUOTED] likes this.
  3. Sep 18, 2020 at 3:27 PM
    #3463
    Diode Dynamics
    Diode Dynamics Automotive Lighting Experts Vendor
    St. Louis, Missouri
    Since we have many SS3 users here - you should know that your SS3 pods are IP69K rated! We just received word from a third party lab that the SS3 meets this high-durability waterproof rating.
    119529556_10200569271016272_775640487712_ff391216bb536df9c503de520d2535be524facfc.jpg
  4. Sep 18, 2020 at 3:44 PM
    #3464
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    :anonymous:Kinda like too much fog on the floor show.
  5. Sep 18, 2020 at 4:29 PM
    #3465
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    SS3s be like
  6. Sep 18, 2020 at 4:30 PM
    #3466
    FastEddy59
    Eddie
    :laser:
    mynameistory[QUOTED] likes this.
  7. Sep 18, 2020 at 10:10 PM
    #3467
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    If they are 4000k, then the best performance halogen bulb color match would be the Osram Nightbreaker Laser +150, which I've measured at a little over 3600k in post #2 of the headlight thread here. It will be closer, though not perfect. You can get whiter fully coated halogen bulbs, but there will be a significant performance penalty. If they are 6000k there is no getting anywhere close to that with a halogen, you'd need to go to LED. The best LEDs I've tested are the Hikari Ultras which have the smallest cross section for best focus in the 3rd Gen projector. Peak intensity won't match that of a performance halogen, but it will get the 6000k color match.
  8. Sep 19, 2020 at 2:27 AM
    #3468
    burnt_taco
    burnt_taco Well-Known Member
    3rd Gen Tacoma Limited 4x4
    Old Quote. Buuut I just installed DD Sports on my Limited that had OEM H16 fogs. I noticed how hot they got while aiming them. Should I be concerned? Is the stock wire gauge sufficient enough to run the DD? I usually run DRL and fogs in the morning.
  9. Sep 19, 2020 at 5:31 AM
    #3469
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The SS3s are going to get nice and hot on the back of the housing. That's a product of the design and the cooling technologies. The stock electrical system has more than enough headroom for what the SS3 is asking for though :thumbsup:
  10. Sep 19, 2020 at 8:29 AM
    #3470
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Your stock H16 bulbs were 19w, the SS3s are 14.5w, so you are actually running less power through the wires. The same wires are used for the TRD 55w H11 fogs as well, needless to say they will be fine. LEDs do produce heat, and the back of the pod is the heat sink to radiate that heat away, it is supposed to get hot. :)
  11. Sep 19, 2020 at 4:59 PM
    #3471
    Rockdpm
    Rockdpm New Member
    2017 Silver Sky Tacoma TRD
    What about these? Sorry new to projector style headlights. Just trying to get the right thing. If you have a link for what i should get, thatd be helpful
    https://www.amazon.com/dp/B06XX3ND4J/ref=cm_sw_r_cp_apa_i_WvPzFbV1J1VZ4
  12. Sep 19, 2020 at 5:27 PM
    #3472
    Too Stroked
    Tom
    Stay away from anything with a blue coating. Although it may look cool, it cuts down (significantly) on light output.
    For the best current bulbs, see here:
    https://www.tacomaworld.com/threads...11-projector-headlights.589465/#post-19689309
  13. Sep 19, 2020 at 5:29 PM
    #3473
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Definitely no. A halogen with a dark coating needed to achieve 5000k color temp will have very low output. If trying to match 4000k, the Osram Nightbreaker lasers are about 3600k by my numbers:
    OSRAM NIGHT BREAKER LASER H11, next generation, 150% more brightness, halogen headlamp: https://www.amazon.com/dp/B07FXRDJW2/ref=cm_sw_r_cp_api_i_ogQzFb511KMWE
    If wanting to go higher in color temp, output will be reduced. You can look for some bulbs near 4000k that are fully coated, they will be more of a ‘styling’ bulb than a performance one regardless of what the package says. The higher the color temp in halogen after the mid 3500k range, the lower the output.
  14. Sep 19, 2020 at 5:36 PM
    #3474
    Rockdpm
    Rockdpm New Member
    Gorcha. Thanks for the tips guys. Will check those out.
  15. Sep 19, 2020 at 9:42 PM
    #3475
    burnt_taco
    Sweeeet. Thanks again Colton for the fogs. They arrived a day earlier than the estimated delivery date and just had time to install them yesterday. Love em.
    Thank you sir for the info, appreciate all the work&info you contribute to TW. Bought the Hikaris based on your testing.
  16. Sep 20, 2020 at 4:18 AM
    #3476
    snahfu
    snahfu Member
    Sorry very off topic but finally got my ss3s but stuck on the wiring portion as my car did not come with fogs.
    This guy tapped into 12v using a male/female adapter but I can't tell if I need to use 2 prongs or 1. (Red cable) Will I damage my car if 2 prongs are used?
  17. Sep 20, 2020 at 6:24 AM
    #3477
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    You have an SR without fog lights and you want to add in your ss3’s?
    Take a look a these two threads for some good info:
  18. Sep 21, 2020 at 7:18 AM
    #3478
    snahfu
    snahfu Member
    Just wanted to say thank you for everyones help. I was finally able to install the ss3's (sport model) over the weekend. Since there are no available brackets for my vehicle, had to do some rotary work on the inside of the bumper to make them fit. Yes, it looks horrible but happy they are finally secure in place.
    FF6xhCMaR7HZY0qgFnyBYDCCI0F7sCPXmiHnmTfN_ead503340c5155936c2569f491845dd76b8cc60a.jpg
    M4IQJUnaf3NjKsxkWYiOu0lDbIRCwEh7xCasd50t_124288a3b4a932cbc4b73ff5481ad43784b53aac.jpg
  19. Sep 21, 2020 at 11:22 PM
    #3479
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Might look rough from the back, but a typical truck motto is function>form. Props for being innovative and making it work. :thumbsup:
  20. Sep 22, 2020 at 8:31 AM
    #3480
    Diode Dynamics
    St. Louis, Missouri
    If you shoot this over to us at contact@diodedynamics.com, our service team can help you troubleshoot the install and make sure you have everything you need! They typically respond pretty quickly.
    -Collin
    Greg.Brakes.Tacos likes this.
