The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Oct 22, 2020 at 6:16 AM
    #3601
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Do the ss3 pros mount in the stock housing?
  2. Oct 22, 2020 at 6:37 AM
    #3602
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    If you get the fog light "kit", then yes it will come with all of the bezels and brackets necessary for a clean install
  3. Oct 22, 2020 at 6:41 AM
    #3603
    Iwilltaco
    Under development
    Perfect, I’ll take a look. I was just browsing their site and saw the pods, figured there was something fog light specific
  4. Oct 22, 2020 at 7:05 AM
    #3604
    memario1214
    Colton
    Missoula, MT
    I've got 'em on hand too if you want to look over this way :wave:
    If you definitely want to purchase through DD directly just input your truck's info into their vehicle selection area and it'll guide you there :thumbsup:
    daveeasa likes this.
  5. Oct 22, 2020 at 7:07 AM
    #3605
    Iwilltaco
    Under development
    You do? How do i look your way :D
  6. Oct 22, 2020 at 7:09 AM
    #3606
    memario1214
    Colton
    Missoula, MT
    www.hotshotoffroad.com and head over to vehicle specific kits (site still under construction and build out, but I think you'll figure it out :D)
    And I don't know what you have for sure or I would guide you to your specific rig!
    Iwilltaco[QUOTED] likes this.
  7. Oct 22, 2020 at 7:29 AM
    #3607
    Iwilltaco
    Under development
    Cool, I’ll check it out
    memario1214[QUOTED] likes this.
  8. Oct 22, 2020 at 8:34 AM
    #3608
    Iwilltaco
    Under development
  9. Oct 22, 2020 at 10:03 AM
    #3609
    memario1214
    Colton
    Missoula, MT
  10. Oct 22, 2020 at 1:54 PM
    #3610
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Are there any negatives to getting the SS3 Pro vs the SS3 sport (yellow fog for both)? I like the additional brightness and ice repelling capabilities of the pro, but want to make sure there aren't any drawbacks vs the sport.
  11. Oct 22, 2020 at 1:58 PM
    #3611
    chetterthecat
    chetterthecat Well-Known Member
    OR
    13 sport
    Most say the pros shouldn't be run all the time because of on coming traffic. So if you plan to only use them as you would high beams... Go pros. If not, sports.
    dilbert[QUOTED] likes this.
  12. Oct 22, 2020 at 2:07 PM
    #3612
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    The Pros have more glare than the Sport but still with the legal compliance limit of an SAE fog. I run the Pros in selective yellow.
    xxTacocaTxx and dilbert[QUOTED] like this.
  13. Oct 22, 2020 at 2:10 PM
    #3613
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the cut off isn't a sharp.
    However for bad weather I think it's worth it. I just grabbed pro C2s to make sure the ice won't build up....hopefully. See how that pans out.
  14. Oct 22, 2020 at 2:12 PM
    #3614
    dilbert
    dilbert AI Member
    PNW
    I do like to run my fogs on auto with the headlights, but I don't want to piss off other drivers. Even if properly aimed (4" drop @ 25') is the glare an issue for other drivers? I don't want to be "that guy".
  15. Oct 22, 2020 at 2:19 PM
    #3615
    memario1214
    Colton
    Missoula, MT
    They're on the road :thumbsup:
  16. Oct 22, 2020 at 2:20 PM
    #3616
    memario1214
    Colton
    Missoula, MT
    If aimed properly I personally feel as though you'd be just fine. The proper beam pattern helps A LOT
  17. Oct 22, 2020 at 2:21 PM
    #3617
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The glare is in legal limits, and yellow glare is less harmful to oncoming drivers that 6000k glare. But note that excessive foreground light from fogs when not needed reduces your eyes ability to see distance at night. If you are always driving with them on, I would recommend the Sports. If used appropriately as a fog I would go with the Pros.
  18. Oct 22, 2020 at 2:32 PM
    #3618
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Technically, $300 vs $200 is 50% more.
    I believe if I read things correctly, 14-15w for sport vs 35-36w for pro so twice the current draw.
    For 3000k, 352 lux sport vs 458 for pro is 30% increase in [EDITED] peak [/Edited] output?
    I don't see any of these as drawbacks really, just some of the key numbers for my decision.
  19. Oct 22, 2020 at 2:33 PM
    #3619
    dilbert
    dilbert AI Member
    PNW
    That's a good point about appropriate use. I had been using the OEM fogs to supplement the OEM headlights, but I just replaced the headlight H11s with the Phillips Pro150 H11 bulbs, which is a big improvement over stock.
  20. Oct 22, 2020 at 2:34 PM
    #3620
    Blackdawg
    Monte
    Wyoming/St. Louis
    yep saw the tracking! Thanks.
