The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Jun 21, 2018 at 3:38 PM
    bikerx
    bikerx Member
    Vancouver BC
    Awesome job Ryland! now to add more lights to the taco ;) LOOOL!
    crashnburn80[OP] likes this.
  2. Jun 21, 2018 at 5:11 PM
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Well that is up to you/your budget. They have clean cut offs but they are among the lowest output and have a thinner beam than some of the more expensive alternatives. If you really want amber, I'd recommend the KC G4 in amber as that uses a true amber light source peaking at 580nm which is the transition point from yellow to amber while also providing double the illuminated area.
    There is a lot of info in the thread, but the links are in there. :) Here is the list of mounts for Rigids.
    Rigid Rage of Fabrication adapters
  3. Jun 21, 2018 at 6:53 PM
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    Thank You!
    Wonderful right up BTW.
    You should offer (sell) it to C&D or Popular Mechanics!
  4. Jun 21, 2018 at 7:01 PM
    JeffB
    Jeff
    N.E. CT
    2017 TRD Sport
    BTW,
    How do you feel about white vs Amber/Yellow?
    SOLID and crashnburn80[OP] like this.
  5. Jun 21, 2018 at 7:23 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    i dont think they will work in my 2010 tacoma as website says 12-16
  6. Jun 21, 2018 at 7:46 PM
    SaphiraTaco
    SaphiraTaco Well-Known Member
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    About halfway done...
    This may be a basic question but how do the covers on say the Rigid SAE Fog Pods affect the light output? I saw in @ChadsPride photo the clear covers and was curious how these or the amber covers would affect the lumen/lux or wavelengths.
    ChadsPride and crashnburn80[OP] like this.
  7. Jun 21, 2018 at 8:28 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Amber is going to do better in extreme rain/snow/fog/dust penetration but white is going to be more generally useful for illumination. If going with amber, I'd suggest a true amber light source like the KC G4 in amber vs a filtering lens which reduces effective output, though amber light sources are going to likely be lower output than their white counterparts.
    ? I linked mounts for 05-11, 12-15 and 16+. You must have not clicked on the correct link. Rage of Fabrication makes Rigid mounts for all 2005+ Tacomas.
    Clear lenses should have very minimal effect. Amber lenses will depend on the light source, but any color filter lens is going to filter out light and reduce output. How much depends on how much of the spectrum is being filtered compared to the light source. If you look at the Rigids, they have a very high amplitude of short wavelength light in relation to their longer yellow/amber spectrum (spectrometer graph shown in the thread). Filtering out blue light will will have a larger effect on output with a light source that is relying more on short wavelength light for its total intensity than a light source that relies on longer wavelength light for total intensity.
  8. Jun 21, 2018 at 8:35 PM
    TRD2010SpeedwayBlue
    Brandon
    the KC G4 wouldnt work in my 2010 i dont believe. there listed as 12-15 on kc’s site
  9. Jun 21, 2018 at 9:43 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    My bad, I didn't notice you had a 2010. I believe Morimoto is coming out with an amber version soon, which should then fit your 2010 Tacoma. Alternatively you could get some Rigids and put the amber light covers over them. While covers do filter and reduce output, the Rigids are at the highest output in the pack and the Morimotos are at the bottom performing part of the pack, so the Rigids have output to spare and would very likely still out perform the Morimotos while also provide 2x the illumination area coverage.
  10. Jun 22, 2018 at 2:32 AM
    TRD2010SpeedwayBlue
    Brandon
    i know about the amber version. TRS said no for amber for the tacoma. pretty dissapointed
  11. Jun 22, 2018 at 7:58 AM
    TRD2010SpeedwayBlue
    Brandon
    i had yellow led fogs and i liked em. they just glared A LOTTTTTTTTT. but i love how the xb morimoto looks installed.
    my friend is getting the baja design but i dont need crazy amount of light like that.
    was thinking bout getting the 1800 lunen ones. but would they be too bright to drive like at night and stuff bc i tend to use my foglights while driving at night.
    or are they strictly for offroad use only. i think they make brighter ones which are off road only?
    help me out with my decision!
  12. Jun 22, 2018 at 8:13 AM
    LadyRed
    LadyRed Making all the right wrong turns
    Leah
    Florida/Mississippi
    2016 4x4 TRD OR DCSB
    OME Lift Total Chaos UCA SCS Ray 10s
    Thanks for this write up! Definitely looking to get some KC G4s for my Tacoma. Wondering if they will fit my 5th Gen Outback too???
    crashnburn80[OP] and ChadsPride like this.
  13. Jun 22, 2018 at 8:36 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Glare is typically due to the beam pattern or using an improper light source for the housing.
    All of Baja's lights are off road only or for high beam use, they do not make any streetable lights. It is not because how bright they are, it is due to beam pattern with lack of cut off as demonstrated in the beginning of the post. The model shown in the original post is the 1800 raw lumen model, which is blinding to oncoming traffic and not ideal for fog, that model has now been replaced by a 2260 raw lumen model. For cut offs you need to look at fogs/pods with SAE J583 compliance, which is what is covered in this thread.
    If you want maximum output then Rigid SAE pods are the way to go.
    I think outback lights are larger than the 4" G4s, so even if you could make it work that might look funny. There is a universal mount G4 that uses C shaped carrier bracket similar to a pod which allows for mounting directly above or directly below the light assembly.
  14. Jun 22, 2018 at 8:39 AM
    LadyRed
    Leah
    Florida/Mississippi
    Thank you!
  15. Jun 22, 2018 at 8:41 AM
    #35
    LadyRed
    Leah
    Florida/Mississippi
    Any thoughts on the amber v. white G4s? I am thinking of going amber...
  16. Jun 22, 2018 at 9:36 AM
    #36
    Fresh6390
    Fresh6390 Well-Known Member
    TN
    17' Super White Tacoma DCSB SR5
    Absolutely awesome read while bored at work this morning!
    But you might have messed up my plans of using the Baja amber wide cornering fogs for my 3rd gen. They look awesome but don't want to blind oncoming traffic as I commute a lot. Hhhmm the dilemma
    Rick_Taco and ChadsPride like this.
  17. Jun 22, 2018 at 11:17 AM
    #37
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Amber is going to do better in extreme rain/snow/fog/dust penetration but white is going to be more generally useful for illumination. However, amber is likely going to be lower output than their white counterparts. The amber KC G4s have a peak color spectrum at 580nm, which is the transition point from amber to yellow, which seems like a fairly ideal color for the purpose of poor weather visibility.
    I just helped you make a more informed evaluation. :)
  18. Jun 22, 2018 at 12:44 PM
    #38
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Very nice info and great testing.
    I have Baja Squadrons with combos used as driving lights.. wouldn't trade them for anything.
  19. Jun 22, 2018 at 3:26 PM
    #39
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Updated with a few charts to better help summarize the results.
    SaphiraTaco and ChadsPride like this.
  20. Jun 22, 2018 at 4:28 PM
    #40
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Great work...I own the RIGIDS, and they just always do an excellent Job. I've cheaped out before, and always have regretted. Buy once, Cry once.
