The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Nov 23, 2018 at 12:58 PM
    #381
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
  2. Nov 23, 2018 at 1:20 PM
    #382
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
  3. Nov 23, 2018 at 3:17 PM
    #383
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    Ummm... Did I hear someone say Group Buy on the amber G4s?
    Can I come, too? Huh? Huh? Can I?
    :boink:
  4. Nov 23, 2018 at 4:50 PM
    #384
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    No pic comprison, but I swapped out my rigids for OR wide angle fogs before trading truck in. Wow! I could actually see into a corner I was turning into. The OR fogs are awesome for that use.
    crashnburn80[OP] likes this.
  5. Nov 23, 2018 at 5:01 PM
    #385
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Big difference between the Rigid 45 degree side projection vs the OR 75 degree side projection.
    gulzeb[QUOTED] likes this.
  6. Nov 24, 2018 at 4:20 PM
    #386
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    My 2015 Legacy comes with 19W H16 fogs like SR5 Tacoma, and apparently replacing with 55W H11 melts the Legacy fog housings. Any suggestions? The easy fix seems to be Nokya or PIAA halogen H16 bulbs, but doesn’t seem like it makes any light output improvement, just allows yellower color.
  7. Nov 24, 2018 at 5:53 PM
    #387
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Aside from replacing the housing with an SAE LED fog housing, if any exist for that make and model, you could look at putting in a 35w H8. It is a more incremental bump, output would go up from 500 lumens to over 800, so it would give a 60%+ improvement. Not double but certainly better. I’ve personally not done H16 to H8 upgrade so there may be minor trimming of the bulbs tabs to get it to plug into the connector and or housing.
  8. Nov 24, 2018 at 7:37 PM
    #388
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Great write up :thumbsup: ... in to read later ... :popcorn:
  9. Nov 24, 2018 at 7:44 PM
    #389
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    I just sold my Rigids off my Tacoma before trading in, was not a fan :p
  10. Nov 24, 2018 at 8:18 PM
    #390
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I linked the required mods to mount the Rigids in the OEM fog locations for all the Tacomas in the original post, so it should be pretty straight forward, but here it is again:
    Rigid Rage of Fabrication adapters The OEM TRD fogs have a significantly wider throw pattern, but being significantly wider pattern may not project as far as the more forward focused fogs. The OEM 3200k color temp is pretty ideal for best illumination without being overly white/blue if not looking for yellow/amber.
    I agree with both of you that the Rigids are way too blue. If going with 'white' LED, I much prefer the KC G4 color output which was the best (lowest) measured color temperature, while also having a wider pattern.
  11. Nov 24, 2018 at 9:00 PM
    #391
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The fog light assemblies are virtually the same but the front bumper facade is not, and the pod mounts have to contour into the face of the bumper and utilize it to anchor the mount.
    gulzeb likes this.
  12. Nov 25, 2018 at 9:30 AM
    #392
    readyme
    readyme Well-Known Member
    Western WA
    2017 TRD OR DCLB
    Which brighter bulbs work in the 3rd gen TRD offroad fog lights?
  13. Nov 25, 2018 at 10:25 AM
    #393
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    readyme[QUOTED] likes this.
  14. Nov 26, 2018 at 7:06 AM
    #394
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Any idea when the Amber Rigids will be on market? Also do you know what the angle of the beam will be? Was set on the KC amber lights(on sale right now) but don't know if I should wait for the Rigids? In your opinion what is the best amber Fog on the market?
  15. Nov 26, 2018 at 7:22 AM
    #395
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Rigid says the product will launch in December, unsure if that is early or late in the month. Side projection angle is the same as the white SAE pods at 45 degrees, KC has a wider projection angle for more area coverage.
    Rigids are more of a selective yellow than actual amber, whereas KC is true amber. You can see the in depth comparison in post #367 here:
    https://www.tacomaworld.com/threads...fog-light-review.554813/page-19#post-19144873
    The Rigids are brighter with a narrower pattern and more yellow color compared to the KCs that are not as bright with a wider pattern and true amber light. I view the Rigids as being a broader more multi-purpose light whereas the KCs should do better in the worst fog conditions.
    Bannerman[QUOTED] likes this.
  16. Nov 26, 2018 at 7:31 AM
    #396
    Bannerman
    Johnson
    Charlotte, NC
    Great, I need them to serve as fogs as I have other lights in grill and roof rack for truly dark conditions. Sounds like the KCs are the way to go then.
  17. Nov 26, 2018 at 11:48 AM
    #397
    m603holden
    Marteeen
    New England
  18. Nov 26, 2018 at 11:53 AM
    #398
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Purchased! Can't wait to get these installed. We've already had several days of harsh winter weather here despite it being so early in the season.
  19. Nov 26, 2018 at 11:56 AM
    #399
    Bannerman
    Johnson
    Charlotte, NC
    I just ordered them as well.
  20. Nov 26, 2018 at 12:00 PM
    #400
    MadRiverTaco
    Brenden
    Waterbury, VT
    And we have a similar lift and tire combo. Good looking rig from what I can tell :cheers:
