The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Nov 28, 2018 at 9:02 AM
    #421
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    Your average SUV driver around here drives with fogs on all the time, because, y'know, more light. You get dazzled by the fogs on a regular basis if you are in any kind of sedan or sports car. They consider them to be a kind of driving light. I am pretty sure they are not designed as fogs, with a sharp cutoff below eye height. But maybe it is because the bumper height on SUVs is so high to be able to navigate Costco parking lot.
    I only run fogs when required, happens maybe twice a year. Driving around with them on all the time is pretty goofy to me. I also don't understand the people who mount non-SAE spec lights that can cook a hot dog, it is very inconsiderate to other road users.
    backcountryj likes this.
  2. Nov 28, 2018 at 9:05 AM
    #422
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    @crashnburn80
    Your write ups are phenomenal. Thank you.
    I personally like the performance of the stock 3rd gen fog lights. An amber colored would be great, but I don’t want to lose the wide throw they produce.
    Is there an ideal aftermarket fog, or bulb, you’d suggest? The KC amber G4 seems like the most likely answer. I’m curious to see what Baja Designs upcoming SAE light will be.
    Also, for general night time road auxiliary lighting, do you have any brand/model recommendations? And even truck mounting locations you find more beneficial than others? I’m not a big fan of the aesthetics of giant light bars.
    I apologize if you’ve covered those questions repeatedly.
  3. Nov 28, 2018 at 9:06 AM
    #423
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    Ah. So they CAN be switched on/off independently of the headlights, but people CHOOSE to drive around with that second set of lights on. ::eye roll::
  4. Nov 28, 2018 at 9:08 AM
    #424
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Guilty. I did the foglight anytime mod just so I could use them as DRL.
  5. Nov 28, 2018 at 9:14 AM
    #425
    Ruminator
    Mark
    If our paths should ever cross, I will cut you.
    Kidding! (...mostly)
    :D
    Bannerman[QUOTED] likes this.
  6. Nov 28, 2018 at 9:27 AM
    #426
    mrCanoehead
    Ottawa
    DRLs are a great idea, there is no doubt they save lives. Pretty sure you can just ask your dealer to program your truck to act like a Canadian one, he will probably cooperate. People used to do that all the time up here when they were importing vehicles from the States because DRLs are required to pass import inspection.
    You should write your Transportation department and demand that DRLs be law. Also get them to do something about the goofy headlight beam requirement that illuminates the birds in the sky, and make it more like the Yurp-spec lights.
    Ruminator likes this.
  7. Nov 28, 2018 at 9:32 AM
    #427
    readyme
    readyme Well-Known Member
    Western WA
    2017 TRD OR DCLB
    Do you have a link for the foglight anytime mod? I want it for use when I run high beams. Thanks
    (Oh, I have a Gen 3...not sure if that makes a difference)
  8. Nov 28, 2018 at 9:39 AM
    #428
    Bannerman
    Johnson
    Charlotte, NC
    Just google it. It’s very simple, on the second gen at least. Takes 10 minutes
    readyme[QUOTED] likes this.
  9. Nov 28, 2018 at 9:43 AM
    #429
    Ruminator
    Mark
    I like my DRLs, first vehicle I've had with 'em. I only wish I had something similar in the rear, like a red tube light (hopefully wouldn't be confused with a brake light). I've only been in 3 noteworthy accidents in my life, and in all 3 cases it was because I was struck from the rear (hence the pic in the sig line). Might be nice to get people's attention back there.
  10. Nov 28, 2018 at 10:21 AM
    #430
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Quite honestly, most of the OEM auxiliary lights one sees out there are more for decoration than useful lighting. A couple of my Ford F-150's (my 1997 and 2005 for instance) actually had very effective true fog beams. Once the bean counters figured out that "real" lighting cost more money though, both versions were discontinued and replaced with far less effective lighting in two model years.
    The sad truth is that the vast majority of drivers have no clue as to what effective lighting really is and/or how to use it correctly. And many believe that "more lighting" is the same thing as "more effective lighting." A few of us know those are two very different things. This explains why so many folks want "fog lights" on their shiny new vehicle.
    Ruminator[QUOTED] likes this.
  11. Nov 28, 2018 at 10:49 AM
    #431
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I see a lot of new cars with fogs but all they do is light up the ground 90* below the light. Like a license plate light. Ridiculous.
  12. Nov 28, 2018 at 11:08 AM
    #432
    andesite
    andesite creeper
    Brian
    Mosier, Oregon
    2.7L 5MT 2011 ACLB
    2.5” Radflo coilovers | Demello armor
    My rigid fogs are great for spotting suicidal wildlife. The wide beam is great for illuminating far into the fescue and other agricultural crops I drive through daily. Does it limit the distance I can see when I can’t use my brights? Eh, maybe. The number of deer you see just out of the beam pattern of headlights is pretty amazing. The fogs have saved my front end many times. I’d prefer to not have another reason to be pulled over when somebody deems it not foggy enough for me to use my fogs.
  13. Nov 28, 2018 at 11:09 AM
    #433
    Bannerman
    Johnson
    Charlotte, NC
    What's a wide narrow beam?
  14. Nov 28, 2018 at 11:09 AM
    #434
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Twice a Year? Really? Sure not like that on the Manitoba side. :canada:
  15. Nov 28, 2018 at 11:11 AM
    #435
    andesite
    andesite creeper
    Brian
    Mosier, Oregon
    2.7L 5MT 2011 ACLB
    Vertically narrow, horizontally wide.
  16. Nov 28, 2018 at 11:12 AM
    #436
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    I'm was most vertically wide in my middle school class :anonymous:
  17. Nov 28, 2018 at 11:14 AM
    #437
    Bannerman
    Johnson
    Charlotte, NC
    I see, I thought the ridids were a pretty narrow beam horizontally, at least for a use as a fog?
  18. Nov 28, 2018 at 12:18 PM
    #438
    FastEddy59
    Eddie
    Absolute Functional Beauty!
    Thanks @crashnburn80 & to @Taylor@KC HiLiTES for your meticulous detail & follow up. Guys, these are a must have if your Drivin in Winter.
    Sure would help out a lotta Folks if there was a Group Buy. :gossip:
  19. Nov 28, 2018 at 12:22 PM
    #439
    Bannerman
    Johnson
    Charlotte, NC
    Those amber or white? I ordered Monday but still have not gotten shipping notification.....
    FastEddy59[QUOTED] likes this.
  20. Nov 28, 2018 at 12:23 PM
    #440
    FastEddy59
    Eddie
    Definitely Amber. White is useless in a WhiteOut.
