The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Dec 21, 2022 at 10:30 PM
    #6381
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    210D395A-417B-4CAD-9399-40ED308A920F.jpg You guys are bad for my bank account
    TheDan, Dr3w, 907rx7 and 1 other person like this.
  2. Dec 22, 2022 at 7:37 AM
    #6382
    Dr3w
    Dr3w Well-Known Member
    Drew
    805
    2007 White DCSB Sport
    The color on these is so good. I came from CBIs and these are much easier on the eyes at night
    Laxtoy[QUOTED] and TheDan like this.
  3. Dec 23, 2022 at 3:30 PM
    #6383
    Spike Spiegel
    Spike Spiegel Well-Known Member
    2019 Super White Toyota 4Runner TRD Off-road Premium
    Eibach Pro Truck Lift, JBA High Caster UCA’s, Falken Wildpeak 275/70/17, Spidertrax Spacers
    Another day when hot pods save the day. Headlights were of no use at 4 AM. Weather's been silly here in WA.
    (No I did not use the ditch lights, only the SS3 MAX fogs)
  4. Dec 23, 2022 at 3:38 PM
    #6384
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    The freezing rain has been brutal. At least you could use the halogen high beam on the 4Runner hybrid OEM LEDs to thaw the headlight if there is no forward traffic.
  5. Dec 23, 2022 at 3:40 PM
    #6385
    Laxtoy
    Maltby, WA
    Where are you located? We had an ice storm in the greater Seattle area, but it seems like the weather is pretty treacherous throughout much of northern US
    EDIT
    Sorry, reread, you’re here! Did you try going out in it? We’ve relegated ourselves to stay home! We’re in the foothills, we still have 3 inches of snow all perfectly preserved in a layer of iceF3EFE416-7351-4BE9-B5C0-AB514345825F.jpg
  6. Dec 23, 2022 at 3:51 PM
    #6386
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    And really at 0400 if there was no traffic you could jave been blasting the yellow ditch lights
  7. Dec 23, 2022 at 4:43 PM
    #6387
    Spike Spiegel
    That was the plan until I encountered a surprising amount of people on the road this morning.
    Darthyota[QUOTED] likes this.
  8. Dec 23, 2022 at 4:45 PM
    #6388
    Spike Spiegel
    Left for work from Mill Creek/Bothell to Everett. There were plenty of people struggling to go up the slightest incline while going straight.
    Laxtoy[QUOTED] likes this.
  9. Dec 23, 2022 at 4:56 PM
    #6389
    Spike Spiegel
    Aws123, Toy_Runner, bikerx and 2 others like this.
  10. Dec 23, 2022 at 4:57 PM
    #6390
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I just shoveled the sidewalk and driveway. Took me at least an hour, maybe 90 minutes. And I’m beat. That’s some heavy stuff. All 3 trucks are frozen up tight. It’ll take a long time if I try to drive one. Wish I could park inside.
  11. Dec 23, 2022 at 5:01 PM
    #6391
    NotATacoFC2
    NotATacoFC2 Well-Known Member
    '24 Civic FL2; '23 CX-5 KF
    Well, an interesting turn of events at Morimoto regarding LED headlights and snow.
    Edit: Added more photos
  12. Dec 23, 2022 at 5:26 PM
    #6392
    MGMDesertTaco
    Jealous of the snow and pine tree winter scenery in Washington. I'd gladly trade AZ for WA. :) Although, I take it some of you that live there aren't. Stay safe/warm! Happy Holidays and Merry Christmas! :santa:
    Laxtoy and Canadian Caber like this.
  13. Dec 23, 2022 at 5:42 PM
    #6393
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Interesting. The 2 stroke 3.0s pulled 1.6A and raised the 3rd Gen lamp lens temp by 4.5 degrees in 60 ambient. The XB v2.0 pulled 2.9A so it will have less than double the heat output to work with. Now the 2 stroke blew into the projector and not the lens, so it wasn’t optimized for lens heating. I also tried the 2 strokes in the fogs where heat is blown on the lens and the heat output was insufficient to noticeably warm the lens, though I didn’t record it with my FLIR. Compared to a true heated lens like JW speaker that runs at almost 110 degrees. Any heat directed at the lens is better than none of course. But plastic is also an insulator, and that design fills a void with warmer air which the plastic insulator lens will reduce heat transfer to the outer lens to melt snow. And also add having to overcome cooling airflow. The pod TIR filtration heating heats the plastic itself, not the space behind it, so the actual outer lens is heated. It’s exciting to see manufacturers of composite lamps looking to address this real world problem many of us face, but it doesn’t seem that this design is going to be warm enough for many if not most scenarios to clear snow/ice. I’d like to be wrong on that of course, looking forward to seeing how well it works. Maybe if an aux heater was added to the airflow for when temps fell below a certain level as a sort of heating boost. As someone who faces these conditions I enthusiastically support development into heated LED lamps.
    TacoFergie and Toy_Runner like this.
  14. Dec 23, 2022 at 5:52 PM
    #6394
    daveeasa
    David
    PNW
    Also kind lame if it’s always on, yeah? Don’t really want extra heat when you don’t need it.
  15. Dec 23, 2022 at 5:54 PM
    #6395
    Yoshi I
    Yoshi I Well-Known Member
    Yoshi
    It will have optimized recycle heat amount control system, several stage of freezer tests were run , in optimization phase. Can't deploy too much detail yet, but yes, evaluation had been in progress in wide range of freezing temp in freezer, making careful development.
    Trigger condition also being configured, when needed, heating power redirection to be controlled, heat are already there. Hopefully to share more information soon, but very much working hard on this!!! Stay tuned.
  16. Dec 23, 2022 at 6:10 PM
    #6396
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    In the case of using the heat sink output as lens heat, the heat is there regardless. It is just being redirected at the lens.
  17. Dec 23, 2022 at 7:05 PM
    #6397
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Anybody have any experience using ditchlights for on road use? I’m considering finally tackling my ‘turning light’ idea. The plan would be to use a pair of ditchlights - probably diode dynamic SSC2’s - and running them off a relay that’s activated by the turn signal when the headlights are on. I’m assuming the SAE driving combo would be the preferred focus.
    This is to address my fading night vision…. Sometimes it’s damn hard to see the side roads for turning when there are no street lights.
  18. Dec 23, 2022 at 7:15 PM
    #6398
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    not legal in any way shape or form
    crashnburn80[OP] likes this.
  19. Dec 23, 2022 at 7:17 PM
    #6399
    Spike Spiegel
    -corrected-
  20. Dec 23, 2022 at 7:24 PM
    #6400
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    nothing in the ditch light position is street legal
