The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Aug 16, 2019 at 10:34 AM
    #1141
    GhostedRaptor62
    GhostedRaptor62 Well-Known Member
    Greenville, SC
    Sweet, If i had a raptor I'd run a white and selective sae and a spot or the new dually pro driving in the pocket. My 13 Fx4 just has the round fog. I'll grab the white and run covers I'd needed. I have a set of D2 driving cubes on my a pillar mounts, I do notice they are not as "white" or warm as my D3S hids, but help see deer a lot easier. Thanks for the quick reply.
  2. Aug 16, 2019 at 10:51 AM
    #1142
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    I'm going to be selling my new white set (1 of them pictured above). Had them on my truck for 1 week while @crashnburn80 had my preproduction set of selective yellow to compare against the production model. Probably have 30 minutes on them. If interested let me know.
    crashnburn80[OP] likes this.
  3. Aug 16, 2019 at 11:03 AM
    #1143
    mcm808
    mcm808 Well-Known Member
    Micah
    Kane’ohe, O’ahu
    3rd gen
    damn fine work!
  4. Aug 16, 2019 at 1:09 PM
    #1144
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    I know they were working on a warmer white model but wasn’t aware they changed the production line yet. I’ll have to ping them for details.
  5. Aug 16, 2019 at 1:11 PM
    #1145
    GhostedRaptor62
    Greenville, SC
    I'm assuming that the difference in color , warmer/cooler, when using a amber cover it would produce a different temperature of amber?
  6. Aug 16, 2019 at 1:18 PM
    #1146
    rayofsi
    rayofsi Well-Known Member
    got this back in may actually, so its been a few months. I guess most people don't notice, unless they are in a situation like me..
  7. Aug 16, 2019 at 2:53 PM
    #1147
    tony2018
    tony2018 Well-Known Member
    Guess I'm on the hunt for an older set.
  8. Aug 17, 2019 at 4:55 AM
    #1148
    GhostedRaptor62
    Greenville, SC
    So I assume if someone orders a set of rigids they should be the warmer color tone? Or is there a possibility of getting thr older set and sending them to rigid to upgrade? I recently got a amazing gift card at work and want to use it to help buy a set of rigids but I want the newer version. The seller is rigid industries so I'm hoping it's the newer revision.
  9. Aug 17, 2019 at 6:35 AM
    #1149
    tony2018
    You can ask them to verify that the one they are selling is the new version.
  10. Aug 19, 2019 at 10:51 AM
    #1150
    mobileandmonitoring
    mobileandmonitoring Member
    2005 Toyota Tundra
    Quick question, when you guys replace your OEM fogs with 2 sets of lets say Rigid D Series fogs (88 watts per side) is a relay required? I actually have a 2005 Tundra but I imagine the wiring is very similar on a Tacoma. The wire that goes to the stock fogs looks like a very small gauge of wire.
    Taco-Obsessed likes this.
  11. Aug 19, 2019 at 12:24 PM
    #1151
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    D-series are 22w each, 44w for a set. Meaning running 2 on a side is 44w per side. Stock fog circuit on a Tacoma is designed for a 55w H11, so even with 2 lights per side it is less power draw than stock. If the Tundra came with an H11 fog option in one of the models, you’ll be fine.
    w.adventures likes this.
  12. Aug 22, 2019 at 12:07 PM
    #1152
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    @crashnburn80
    Related/Unrelated - While researching Off Road use lights, not to be swayed by the "raw lumen" numbers, I should be more concerned with "lux" and "beam pattern" and "beam distance".
    Or did I learn nothing from all your hard work?
  13. Aug 22, 2019 at 9:22 PM
    #1153
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    If you are comparing across brands it can be pretty challenging. Raw lumens is a starting point, but not apples to apples, and if comparing efficient reflector based lights to pods/bars, it can be very misleading. Beam pattern needs to be the same for an relevant comparison, but even that can very significantly as demonstrated by Bajas fog light vs Rigid. Bajas covers way more area, so even though their light is higher output, Rigid is brighter in the light pattern area. Lux/candela is only helpful if you have a measurement from the same distance with the same type of pattern. Beam distance is often the max point at which 1 candela can be measured. This can be useful, but a pattern that is more focused such as hyper spot will have a better distance than one that covers slightly more area with all other things being equal, so it doesn’t tell the whole story. Some sites like KC Hilites do an excellent job in documenting their light performance with good data for each light, making it easier to compare different lights they offer to each other. But the competition needs to do an equal job presenting the data to compare brands, and realistically few present data in that level of detail, which was one of the drivers for this thread. It may be easiest to ask about which off road lights you are considering. :)
  14. Aug 23, 2019 at 6:49 AM
    #1154
    MrMccrackin
    Gilbert, AZ
    Thank you, Some how I knew it wasn’t going to be an easy answer!
  15. Aug 23, 2019 at 6:59 AM
    #1155
    MrMccrackin
    Gilbert, AZ
    @crashnburn80
    Oh I forgot to mention color temp, but here are the lights I am comparing:
    KC Gravity Pro6
    Rigid D-XL Pro
    Rigid D-SS
    BD LP6 Pro
    Greg.Brakes.Tacos likes this.
  16. Aug 23, 2019 at 10:12 PM
    #1156
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    I'll start by saying I plan on eventually adding the Gravity Pro6 LED Driving lights.
    Compare specs from KC and Rigid for Driving pattern:
    Rigid D-XL Pro - Driving: 89w, raw lumen 9504, lux@10m 638, beam distance 252M
    KC Gravity Pro6 - Driving: 20w, raw lumen 2300, lux@10m 1,310, beam distance 724M
    You can see the KCs are far more efficient due to their reflector design. Large reflectors are vastly superior in focusing and projecting light over distance than forward facing LEDs in a pod like housing. The drawback is of course large reflectors are well, larger. You'll note in this fog review the KC G4s are one of the lowest powered and lowest raw lumen output lights, yet they perform near the top of the group in projected output, because of their highly efficient reflector based design. And larger reflectors are more efficient and more effective than smaller reflectors. I personally like the round reflector look better, but that is subjective personal tastes. KCs also has a best in class color temp of 5000k. The Rigid D-SS are lower output than the XL, and Baja's LP6 Pro advertise similar raw power and wattage to the Rigid XLs, though they do not provide detailed specs like KC and Rigid who do a great job in documenting their product performance.
    The light selection does depend on your intended use and desired beam pattern though, which you did not mention. If you are looking for ditch lights for example, the Pro6 would not be a good fit due to their size.
    HawkShot99 likes this.
  17. Aug 24, 2019 at 6:41 AM
    #1157
    MrMccrackin
    Gilbert, AZ
    As always, thank you for hard work!
    No ditch lights, these would be mounted on top of the front bumper, I figured a driving pattern as opposed to a spot or wide.
    I am still not sure how I feel about roof rack mounted lights, what are your thoughts?
  18. Aug 24, 2019 at 7:04 AM
    #1158
    GhostedRaptor62
    Greenville, SC
    I have a set of dually d2 driving patter on my a pillars, work well for what I want but I'm planning on upgrading to some Baja Designs in the driving combo beam.
  19. Aug 24, 2019 at 1:45 PM
    #1159
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    have you compared them side by side with the lp9? at our last outing in the desert the gravity pro seemed to fall short. I want to say we saw farther driving distance with 4 or 5 lp6s vs a rack of 6 ks. I really wish all these top companys would put actual results on the site to compare lol
  20. Aug 24, 2019 at 6:08 PM
    #1160
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    I admittedly have not. It would be helpful if Baja published the standardized performance specs like KC and Rigid for easier cross product comparison. It would certainly be interesting to see them side by side!
    Front bumper is most ideal IMO for forward facing lights. Roof can give you better distance and the higher perspective will help reduce shadows, but it also introduces hood glare if mounted at the windshield which harms night vision, and adds wind noise.
    You want to match your pattern with the desired use use case you are wanting to achieve. Driving provides the ideal blend (IMO) of distance light with good usable area coverage, it can be helpful for both off road and on road as an aux high beam. Spot is best combined with other distance light upgrades as the area of spot illumination is very small but will extend further than driving. Wide is good for extra near field awareness off road, but doesn’t help with distance and isn’t very helpful for street driving.
