The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Sep 25, 2019 at 10:44 AM
    #1261
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    yesssss
  2. Sep 25, 2019 at 11:12 AM
    #1262
    GhostedRaptor62
    GhostedRaptor62 Well-Known Member
    Greenville, SC
    Is it warmer leds over all the 360 lights or just the sae versions? I've been doing some reading a picture drooling over some BD XL pros and Xl80s, both in combo beam for my purpose, love the color temp of them. If the 360 has a warmer led then I'll have to wait and see what people say about them, and hopefully a comparison in real world conditions.
    Edit, I was looking at the 360 lights again. Looks like they mount some what similar to D series lights. In my F150 the Rigid bracket requires you to have the D series mount facing straight back. Wonder if the 360 series will be similar. May end up switching over to the 360 sae from the BD.
  3. Sep 25, 2019 at 11:43 AM
    #1263
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I'm checking on color temp specs, but I'd speculate they are the same for all versions.
    You can compare the specs between the Baja and Rigid lights, the Baja XL Pro is higher output that the 4" 360-series by a fair amount, the XL80s and the 360-Series 6" lights are a much closer comparison, Baja comes out ahead on raw lumens, though price and looks (IMO) go to Rigid. The big advantage I see with the 360-Series is the available SAE fog pattern.
    For mounts, you can look at the docs on the 360-series page, which shows the mount. The D-series use a lower mounting bracket, the 360 series use a center mounting bracket. Vehicle mounting designs are not going to be compatible between the D-series and 360-series lights.
  4. Sep 25, 2019 at 11:56 AM
    #1264
    GhostedRaptor62
    Greenville, SC
    I'll look into the mounting, I doubt they will make another bracket for my F150. I have my D2s on my a pillar mounts, driving pattern. They are nice to flick on when I need extra lighting on back roads, I'll look more into the xl80 vs the 6in 360. I wish Rigid had a hyper spot/driving combo D pro or D xl pro, would be best of both worlds for me.
  5. Sep 25, 2019 at 6:10 PM
    #1265
    Odoyle
    Odoyle Well-Known Member
    All over
    08 SR5 Offroad
    3" Toytec Lift, TC UCAs, 4.56 gears, Black Baja Wheels, Relentless fabrication Front Bumper and Rock Sliders, Warn Winch, PIAA Fogs in Bumper, Diff Breather Mod
    Pre-ordered the SAE Rigid 360s. Now the waiting until they arrive and I have time to install them...
  6. Sep 25, 2019 at 6:30 PM
    #1266
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Nice! 2-3 weeks out. They don’t have an off the shelf mounting solution for an 05-11, but I’m working on something to put fogs behind the lower grill opening.
  7. Sep 25, 2019 at 7:12 PM
    #1267
    Odoyle
    All over
    08 SR5 Offroad
    I’ve got a relentless bumper so no issues on the mounting solution.
    crashnburn80[OP] likes this.
  8. Sep 25, 2019 at 7:28 PM
    #1268
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I’m on the same program as you but with my CBI. So exited for these things to come out.
  9. Sep 26, 2019 at 5:43 PM
    #1269
    maverick4x2
    maverick4x2 Well-Known Member
    2013 Tacoma 5 lug
    Ok gents, some beginner questions here. I just ordered a set of the off road town fog pods and plan on grabbing the caliraised adapter plate in a few days.
    1. My truck (2013) is a base, no stock fogs. What wiring/switch will I need to successfully run these lights.
    2. Secondly where can i find an install thread or somthing like it for trucks that dont start with fogs, i'm apparently inept at search-fu.
  10. Sep 26, 2019 at 6:36 PM
    #1270
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Any light wiring harness will work with 2 leads will work. I'm sure what I have isn't the greatest, but mine cost $10-15 on Amazon 4 years ago and has worked great powering my 7" spots.
  11. Sep 26, 2019 at 6:59 PM
    #1271
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    The offroadtown pods come with a wiring harness so you shouldn't need to buy one unless you want something different.
  12. Sep 26, 2019 at 7:28 PM
    #1272
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I think his intension is to hook it up like stock with the stock switch, not as an aftermarket harness with a constant power switch.
  13. Sep 26, 2019 at 8:11 PM
    #1273
    maverick4x2
    2013 Tacoma 5 lug
    didn't realize it came with a harness. didn't read far enough down. i'll probably stick with that unless the round switch is to much of a pain to get to look good enough.
  14. Sep 26, 2019 at 8:25 PM
    #1274
    65skyturbo
    Mesa, AZ
    You can always use the offroadtown harness with a oem style switch as long as you are comfortable with wiring it in. Something like this:
    https://www.amazon.com/MICTUNING-Ba...mall+toyota+push+switch&qid=1569554453&sr=8-6
    or these are even better:
    https://www.ch4x4.com/switch-gallery/toyota-push-switches/
    There are several threads on TW that show how to wire the dash switch.
  15. Sep 26, 2019 at 9:08 PM
    #1275
    maverick4x2
    2013 Tacoma 5 lug
    Thanks! that's exactly what I was thinking
  16. Oct 1, 2019 at 6:55 PM
    #1276
    maverick4x2
    2013 Tacoma 5 lug
    So...I really should have checked my measurementso_O bought offroadtown 3x3 pods and the cali raised brackets are for 2x3 pods. that was dumb
  17. Oct 1, 2019 at 6:58 PM
    #1277
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    LOL! I didn’t realize they sold a 2x3 model. CaliRaised is known for good customer service, I’d contact them and see if they’ll help you out with a simple trade.
  18. Oct 1, 2019 at 8:09 PM
    #1278
    maverick4x2
    2013 Tacoma 5 lug
    yea i didn't either, lol. I'll contact them thanks
  19. Oct 3, 2019 at 9:51 AM
    #1279
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    Just back from family vacation, patiently waiting for crashes review of the 360 SAE series!
  20. Oct 3, 2019 at 10:51 AM
    #1280
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Should be within the next couple weeks! :bananadance::dancingbacon:
