The LED SAE J583 Fog Pod & Fog Light Review
Discussion in 'Lighting' started by crashnburn80, Jun 20, 2018.
  1. Dec 5, 2019 at 4:23 PM
    #1841
    AssQuake
    AssQuake Unknown Member
    A.J.
    Washington
    4runner
    Made in Japan
    inserts to make the BajaDesign "SAE" :duh:
    Supa White Taco likes this.
  2. Dec 5, 2019 at 4:30 PM
    #1842
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I mean this is pretty much how they would have to do it. They aren't going back to the drawing boards on an 'SAE' design that isn't really in any of their product lines.
    Get it sorted asap and put the BD teams back on the lasers please..
  3. Dec 5, 2019 at 4:31 PM
    #1843
    Jnull
    Jnull Well-Known Member
    4 cummins trucks!
    I have 2 sets on order so I’ll likely have them by the time you do your tests but I’ll still be eager to see your results and input.
  4. Dec 5, 2019 at 4:41 PM
    #1844
    Onwarrds
    Onwarrds @onwrrds
    Tyler
    Southern California
    2017 Black TRD OR 4x4 DCLB
    Fox 2.5 DSC Adjusters (Extended Travel), Camburg UCA, RCI Rear Bumper, Cali-Raised Zero Degree Step Rock Sliders (with filler plates), Softopper, TRD Pro Skid, Rigid, Baja and KC lights, H9 Headlight Upgrade.
    For what it's worth I sent my White D series SAE Rigids in to have them swap the lens and the LEDs to selective yellow. Pretty easy process and their turn around time was really good. I think just over a business week until they were back in my hands. They handled that really well so I imagine a warranty claim would be painless enough too.
  5. Dec 5, 2019 at 4:51 PM
    #1845
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    "In more understandable terms, that is the equivalent of 1.19 candles at 10 meters."
    I'll politely admit that this didn't make it more understandable. Can a resident lighting engineer dumb it down a little for me?
  6. Dec 5, 2019 at 4:56 PM
    #1846
    AssQuake
    A.J.
    Washington
    4runner
    Made in Japan
    hopefully there is NO glare over the cut off line.
    other manufacturers are getting it right the first fucking time.
    next time don't advertise something that isn't
    Slickestwilly likes this.
  7. Dec 5, 2019 at 4:56 PM
    #1847
    Onwarrds
    Onwarrds @onwrrds
    Tyler
    Southern California
    I'm curious as to how the D series mount for a Third Gen compares with the 360. My Third Gen mounted D series don't seem to point as much into the shoulder as your second gen with the rago mounts. I do have the Rigid mount kit for them in the stock fog lamp location on my truck.
  8. Dec 5, 2019 at 5:00 PM
    #1848
    Slickestwilly
    Slickestwilly Well-Known Member
    Will
    NH
    25 Pro
    Leaked prototype SAE inserts
  9. Dec 5, 2019 at 5:40 PM
    #1849
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    Actually not that bad.
  10. Dec 5, 2019 at 6:30 PM
    #1850
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    In English, They blind oncoming vehicles. But don't worry the @Baja Designs engineers drove around with them and nobody flashed their high beams, so they gave it the all good.
  11. Dec 5, 2019 at 6:32 PM
    #1851
    HawkShot99
    Kingston, NY
    Removed to stay on topic...
  12. Dec 5, 2019 at 6:33 PM
    #1852
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I'm really exited to get my SS3 Pros mounted up. If only they shipped sooner! They look mighty fine.
  13. Dec 5, 2019 at 6:33 PM
    #1853
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Light intensity is measured in Candela (cd), which is roughly "1 candle". You'll notice that some lighting companies include this unit of output measurement in their specs cited as Cd, like KC and Diode Dynamics. (Which I always appreciate more spec data). So they are saying their lights emit 1.35 candela (cd) or 1.35 candles worth of light above the legal limit, above the horizontal cut off. This doesn't match the numbers I have. However they are using one of the major well know compliance test agencies, and have run the original lights and the modified prototype lights to validate compliance for light above the cut off, and then to be extra sure they were running the production unit through compliance testing. I'm aware of another lab that has compliance tested these lights and have been looking to get ahold of the test data as a 3rd data point for comparison.
    Greg.Brakes.Tacos and 6inaRow like this.
  14. Dec 5, 2019 at 6:48 PM
    #1854
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    3rd Gen D-series Rago mounts point straight forward, only the 2nd Gen 12-15 mounts benefit from the side angling D-series mount for the ultra wide pattern. While the D-series have the highest intensity output, in a forward facing mount you'd likely benefit more with something using a wider pattern for better shoulder illumination. In the 3rd Gen the KC G4s use a flush mount which will angle to the sides and will give you a far wider area of coverage, although they are not available in selective yellow. However, if you are currently running the white version, the KC G4 offers a much better 5000k color white than the higher color temp Rigid D-series whites.
    Edit: just realized you had the lens swap to selective yellow.
    Onwarrds[QUOTED] likes this.
  15. Dec 5, 2019 at 9:52 PM
    #1855
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    I'm trying to do a quick crash course on units of light measurement, and I think I'm confusing myself. I don't see a lot of references to measuring light in candles- the more common American unit I'm seeing is foot-candles. Like- the difference between miles and miles per hour. If the case is that the lights are 1.19 candles above threshold at 10 meters, does that mean they are (32.8 feet * 1.19 candles) = 39 foot candles above threshold? Measured in lux, that's 420 lux over threshold?
  16. Dec 5, 2019 at 10:12 PM
    #1856
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    @Diode Dynamics
    Quick clarification please. Are your candela ratings for a single light/pod, or for a pair of lights?
    For both your white and selective yellow options, you list the "Sport Spot" as having a higher max candela rating than the "Pro Spot," this is due to the smaller, more intense emitters, correct?
    You mentioned a few times the possibikity of swapping the selective yellow optic over 4000k led for the clear white optic. Do you sell the clear white optic separately?
    I'm interested in picking up a set of fog lamps (selective yellow) and potentially a set of spots or driving beams, if you make the optics available separately. I'm very interested in having a set of neutral white auxiliary lamps. I currently have a set of LED Cibie Super Oscars on the front of my '99 4runner, which are extremely blue, which limits their usefullness.
  17. Dec 5, 2019 at 10:59 PM
    #1857
    Onwarrds
    Onwarrds @onwrrds
    Tyler
    Southern California
    Interesting. Yeah I am running selective yellow now and they are noticeably better than the white color I had previously. I would like to swap to the 360 series but feel like it’s too much of a hassle at this point as I’d have to sell my current setup and brackets and try to source original fog lamp bezels as I sold my stock ones. Gonna stick with what I got for now. Really cool that Rigid keeps improving upon their tech in this category though. Good on them!
  18. Dec 5, 2019 at 11:12 PM
    #1858
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I’m beyond impressed with the Rigid SAE pods mounted up into the ARB bumper SLEE inserts. Light output blows away folks I overtake on two-lane roads and it has made me re-think my “need” for ditch lights.
    crashnburn80[OP] likes this.
  19. Dec 6, 2019 at 4:33 AM
    #1859
    GhostedRaptor62
    GhostedRaptor62 Well-Known Member
    Greenville, SC
    If you use Gmail check the Promotions folder, that's where my email was at. I sent on off to Baja Designs. Will see what happens.
  20. Dec 6, 2019 at 5:21 AM
    #1860
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    How do the SL1 Headlights work in the 4 Runner set-up?
