The Lock Picking Thread
Discussion in 'Sports, Hobbies & Interests' started by Kwikvette, May 31, 2023.
  1. Jun 2, 2023 at 2:31 PM
    #61
    Shotgun Clay
    Shotgun Clay Well-Known Member
    I got into watching LPL's videos when I was laid off during Covid. His kits had not come out yet so I got some picks from other companies. Ended up with a bunch that I had no use for. When I did get the LPL kit I found it worked well on just about everything. I've since picked up some other goodies from there which have all been useful. His practice lock is the easiest to repin I've found.
    Are you using top or bottom of the keyway tension on that number 3? Most 3's I've encountered respond well to being raked with light tension.
    Kwikvette[QUOTED][OP] likes this.
  2. Jun 2, 2023 at 2:33 PM
    #62
    Shotgun Clay
    Great practice lock, very easy to repin, has everything you need.
  3. Jun 2, 2023 at 2:36 PM
    #63
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    Seems I'm not the only one that needed time to fill!
    I will say, immediately after using the set I purchased, I liked it so much I ordered a few more items a day or two later.
    Only thing is they don't arrive until next Monday.
    With that said, they've worked well on everything I've picked (only actual locks, no practice locks) with the exception of that number 3. My wrenches are too big to go TOK which is why I also placed an order for a set from Sparrow Picks.
    Maybe I could try using my current wrenches up top and try my hand at raking so thanks for the idea.
  4. Jun 2, 2023 at 2:38 PM
    #64
    Shotgun Clay
    https://www.youtube.com/watch?v=KHYpSERxcC4 Hate to break it to you, but they're crazy easy.
  5. Jun 2, 2023 at 2:40 PM
    #65
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fast forward a few posts; I picked the 140 easily.
    I don't have comb picks so I did single pin picking which only took a few seconds.
    But yes those picks are part of my order coming in next week!
  6. Jun 2, 2023 at 2:41 PM
    #66
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Next thread up - how to jack a Tacoma, the EASY way.
    Kwikvette[OP] likes this.
  7. Jun 2, 2023 at 2:50 PM
    #67
    Shotgun Clay
    Sparrows Wafer and Warded picks are pretty good too.
    I got an SC1 Lishi tool to use with the CI practice lock, it is very easy, but gives valuable feedback about binding order, security pins, and what pins feel like when they're set. Shame they're so pricey.
    Glad I found this place I just got my first Tacoma yesterday!
  8. Jun 2, 2023 at 2:53 PM
    #68
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ooh those look pretty cool.
    Skipped over those when I ordered my TOK wrenches.
  9. Jun 2, 2023 at 2:57 PM
    #69
    Shotgun Clay
    The case at our local Costco that has the $3000.00 Scotch has a wafer lock. My wife glares at me when I inspect it too closely. :)
  10. Jun 2, 2023 at 3:46 PM
    #70
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    when i was in 6th grade, i screwed around with 2 bent paperclips to unlock the thermostat and turn down the AC, during a detention during recess. The teacher left me inside the classroom to write 100 sentences of "i will not do ...." and i fucked around to make our classroom more cool in the spring.
    Shotgun Clay and Kwikvette[OP] like this.
  11. Jun 2, 2023 at 7:06 PM
    #71
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm definitely oversetting the pins in my new locks.
    My tension wrench takes up a lot of space working at the BOK causing my pick to push the pins too high.
    I get either a real or false set through the first 4 pins but find it difficult getting to pin 5 and pin 6 without pushing up 1-4 too high.
    These apparently have 5 spool pins and 1 serrated.
  12. Jun 2, 2023 at 7:29 PM
    #72
    Shotgun Clay
    I bought some cheap low hook picks that I could grind to an even smaller profile with a dremal tool. Masters TOLO plastic locks are strangely more pick resistant than most of their other stuff.
  13. Jun 2, 2023 at 7:35 PM
    #73
    Kwikvette
    Fresno County
    4 run, 2 don't
    I had bought a half diamond that I'm hoping comes in clutch.
    Otherwise I'll buy a duplicate of something I have already and grind it down; just didn't want to grind down what I currently have.
    Shotgun Clay[QUOTED] likes this.
  14. Jun 2, 2023 at 7:42 PM
    #74
    Shotgun Clay
    The cheap picks didn’t have a handle, I just put some heat shrink on them. I forget what I paid, but it was probably about three to four bucks.
  15. Jun 2, 2023 at 8:36 PM
    #75
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's a great idea as I've got plenty of heat shrink available.
    And yeah picks aren't pricey at all, just a matter of making a purchase worth it and loading up the cart if I'm really needing just a single pick :laughing:
  16. Jun 4, 2023 at 11:35 AM
    #76
    Kwikvette
    Fresno County
    4 run, 2 don't
    So one of my orders arrived; these are from Covert Instruments and it was an order for some comb picks, shims, and decoders.
    I don't expect to use the shims really, but they'll be nice to have 'just cause'.
    Another package I had been anticipating is the Abus 55/40.
    Have to say, I am really digging the feedback this lock gives me. I can easily hear and feel pins setting, whether it's a false set or not. But what's really interesting is the counter rotation I get at pin 3 which tells me it must be serrated.
    I honestly believe I'll be able to beat this lock with either a TOK wrench or smaller pick. I find myself oversetting pin 2 or 3 as I try to make my way to pin 4. Either that or a pin gets reset that I had already set. Rather than get frustrated, I'll wait until my other picks arrive.
    Thought I'd come back to my other Master Locks and try a comb pick for the first time.
    https://youtu.be/VPTa7PrBKdo
    Took me an average of 10-15 seconds to single pin pick these locks and now it takes me but a second with a comb pick.
    Abeyancer and TeecoTaco like this.
  17. Jun 4, 2023 at 3:47 PM
    #77
    Shotgun Clay
    The comb picks, on the right lock are fun but a bit boring after a while. The only pick that made me feel cheated was the tubular lock impressioning tool. Being into bicycles in the 80’s, the Kryptonite lock was mythically impervious. Took the tool, grabbed the old bike lock and three seconds later it was open. Ditto a Citadel lock. I need to get that Abus. A lot of the locks I have are “mushy” about feedback.
  18. Jun 4, 2023 at 6:18 PM
    #78
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fuck me.
    Picked my Abus 55/40 with my current pick set within a minute; showed the wife.
    Go to the garage to try it again and no dice :bananadead:
    Shotgun Clay and TeecoTaco like this.
  19. Jun 4, 2023 at 6:26 PM
    #79
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Been there done that
  20. Jun 4, 2023 at 7:16 PM
    #80
    Shotgun Clay
    Been there… what’s worse is a lock you can open but the binding order feels different everytime.
