The Lumpskie Build - '96 5-speed
Discussion in '1st Gen. Builds (1995-2004)' started by Lumpskie, May 17, 2013.
  1. May 17, 2013 at 10:49 AM
    Lumpskie
    Lumpskie [OP] Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    After seeing some of the build threads on here, I decided to make one of my own. I own a '96 with manual everything. (transmission, hubs and even windows!)
    Here's how it sits now:
    Toytec 600lb front Coilovers
    Light Racing Upper Control Arms
    ARB Rear Locker
    Garage Built Front Bumper with removable winch plate
    Warn M8000
    Vision X HID Offroad Lights (Hi/Lo beam)
    Alcan Leaf springs (Custom length and Orbit Eyes)
    Bilstein 7100 12" Short Bodies
    Custom 6" shackles
    Inchworm dual Transfer Case setup, 15º clocking
    Bushwacker Fender Flares
    CBI Sliders
    33x12.5 GY Duratracs
    Mombasa Roof Top Tent
    To Do/Wish list:
    1. Fabricate rear bumper with tire/hi-lift/fuel can carrier
    2. Redo belly skid/T-case mount for flat belly
    http://youtu.be/0hRnUBoZ9t4
    Here's my truck in '09 when I bought it. It had a NWOR suspension on it, that didn't flex too well. Other than that it was stock. It's been kind of a work truck all it's life
    _____________________________________________________________________________________________________________________________________________
    Due to popular demand, here's a few pics and a mod list for my Evo 9!
    Injen TBE
    Perrin HFC,
    Walbro 255 fuel pump,
    RC 750 injectors,
    Buschur Exhaust Manifold,
    Invidia O2 housing,
    Tactrix 3 Port,
    Samco turbo and radiator hoses,
    Tanabe Sustec Pro 7 coilovers,
    Tanabe TEAS,
    ETS Intake,
    K&N 4" intake filter,
    ETS 3.5" Intercooler,
    ETS LP2 LICP,
    PLX DM 200 MFD (boost, oil temp, OBD II),
    Gramlights 57s pro titan,
    Exedy Twin Disk,
    Rotor Pros Rotors,
    EBC Red Stuff pads,
    JDM rear bumper,
    APR CF front lip
    Questions and comments welcome!
    Boston10Taco likes this.
  2. May 17, 2013 at 10:55 AM
    Lumpskie
    New Hampshire
    So, I didn't start modding the truck till the beginning of 2011. The first order of business was to remove the Northwest Offroad HD leaf springs and replace them with a custom Alcan 8 pack. The Alcans were setup for the extra weight you'd see in the bed during expedition trips. So, the are stiffer than normal. Also, I picked up a set of CBI Sliders from a guy up in Wyoming.
  3. May 17, 2013 at 10:59 AM
    Lumpskie
    New Hampshire
    Next, I put on 32x11.5 KM2s and bilstein 5100s in the rear.
  4. May 17, 2013 at 11:02 AM
    Lumpskie
    New Hampshire
    Then I had a little boo boo on the road...
    This made me look at the front end of my truck. It was time for new suspension and a bumper.
  5. May 17, 2013 at 11:05 AM
    Lumpskie
    New Hampshire
    So, I picked up some goodies and decided to build myself a bumper.
  6. May 17, 2013 at 11:14 AM
    Lumpskie
    New Hampshire
    So, my buddy and I got down to business on the front bumper
    Before we could start on the bumper, we had to straighten out my frame. The previous owner got a little too boisterous with the front tow hook...
    Looks better now.
  7. May 17, 2013 at 11:17 AM
    Lumpskie
    New Hampshire
    Now, I decided I wanted a bumper with a removable winch plate that didn't need any tools. So we had to figure out how everything was going to fit together. We started with winch placement.
    Then we bent a couple tubes, made a couple brackets and tack welded them together. These will be the beginnings of the main hoop. They will also be cut down ~4 inches.
    Duct taped some bar on there, just to see how it would lay out.
  8. May 17, 2013 at 11:22 AM
    Lumpskie
    New Hampshire
    We designed the removable winch tray. It's designed to keep the loads in shear instead of torsion. It will slide out the front, just under the top horizontal bumper bar.
    And, we bent up the top bar for the bumper
    Tacked on the diagonal tubes.
    Front view:
    Here's a quartering view:
  9. May 17, 2013 at 12:08 PM
    Lumpskie
    New Hampshire
    Here's the bumper off the truck for some trimming
    Fairlead installed:
    And here it is with the light bar hoop
  10. May 17, 2013 at 12:14 PM
    Lumpskie
    New Hampshire
    Here are some close up shots of the removable winch setup
    No tools required to remove it, and the pins are strong enough to handle winching operations
    Here's where the plate goes. When inserting the plate, the supporting structure guides the tube into place. It's really easy and lines up every time.
    It works pretty well!
  11. May 17, 2013 at 1:30 PM
    Lumpskie
    New Hampshire
    Ok, final post of the day.
    Here's the bumper all finished up
  12. May 17, 2013 at 2:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  13. May 17, 2013 at 8:53 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    X2 :drool:
  14. May 17, 2013 at 9:11 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  15. May 17, 2013 at 10:46 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    sick man! Nice bumper too
    What kind of soft topper do you have?
  16. May 17, 2013 at 11:12 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    Likein the bumper dude good work
  17. May 17, 2013 at 11:36 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    nice job on the tube bumper
    good looking truck!
    98_3RZ_NIC likes this.
  18. May 18, 2013 at 7:23 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Also subbed. I've been looking into a duel T-case myself. How do you like the inchworm?
  19. May 18, 2013 at 7:38 AM
    Lumpskie
    New Hampshire
    Thanks for the compliments on the bumper, guys! I'm hoping to build a rear bumper late summer/early fall that will accept my winch plate. That way I can winch in either direction. (Nice feature when I'm out on expo type trips by myself)
    I LOVE the inchworm setup. Really it's hard to beat the price for their full setup too. The thing to be careful about is the front adapter plate. (transmission to crawlbox) It seems like some people have problems with oil leaking out from there. So, I was really careful when drilling my clocking holes and had a machinist buddy of mine feel and file it till he was convinced it was totally flat. I haven't had a drip yet. Hopefully, I'll get this thread caught up with weekend and will detail the process a little more.
    Thanks man! My topper is the Softtopper brand, made out here in Colorado. Since they are so close, I went to the factory and met the owners. They are really nice folks that put out an awesome product. My topper has been on my truck for 4 years now through heavy snow, hail, rain and direct sun. It has held up great! I can't say enough good things about it, but I'll end my commercial now.:p
  20. May 18, 2013 at 9:27 AM
    Lumpskie
    New Hampshire
    I forgot to show a couple of mods I made to the bumper after the initial build.
    I added some shackle hangers and reinforced the bumper with some plate steel.
    Bad job with the spray paint...
