The Magruder/Lolo Motorway BS Thread
Discussion in 'North West' started by Digiratus, Jun 18, 2012.
  1. Jul 30, 2012 at 10:27 AM
    #181
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yay for Joe! :woot:
    Lisa did you rotate yours often?
    I'm noticing mine are just getting wore out haha they have a ton of miles on them tho both on and offroad
  2. Jul 30, 2012 at 10:52 AM
    #182
    Digiratus
    Digiratus [OP] Adventurer
    Roaming the PNW
    The RedHead
    You are running Duratracs now aren't you? Are you going to stay with an all-terrain tread with the next set?
    Magruder/Lolo will probably be my last big wheeling adventure with my KMs. They took quite a beating at Moab. Tread depth is still reasonable but I have lots of chunking in the outer tread blocks and also a few gouges in the sidewalls. :eek:
  3. Jul 30, 2012 at 10:58 AM
    #183
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mine are cut up bad too from my fenders. Left a lot of them on the slick rock haha
  4. Jul 30, 2012 at 12:10 PM
    #184
    MTgirl
    Weesa
    Bob's secret mod lair
    rotate every 5k, balance every 1k or so.
    i got a cut in one sidewall at the august meet last year. its not deep but the sidewalls of these tires is known to be a problem so that tire is one I keep an eye on.
    i do need an alignment. i had one done when i had my suspension work done but not after i had my ball joints replaced. the UCA sits at a different angle now than it did before but I didn't think anything of it. my front tires are really worn on the inside edge AND the leading edge of each lug is worn down more than the back edge. I can get a pic later to show you guys....
    yep I have Duratracs. For traction they are great and they've worn surprisingly well as I have almost 30k on them (the uneven wear is my bad for not getting an alignment, won't blame that on the tires). They are a pain to keep balanced and I'm at hte tire shop about once a month. That plus the amount of noise that these things generate I don't think I will buy them again.
    I'm deciding between BFG KO's or General AT2's . Only one shop can get the Generals in though so its looking like KO's for me.
  5. Jul 30, 2012 at 12:18 PM
    #185
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    BFGS lisa!
  6. Jul 30, 2012 at 12:30 PM
    #186
    MTgirl
    Weesa
    you have them too I see. They've gotten pretty good reviews both here and on tirerack. Seems like they handle well in winter (priority #1) and offroad and have a decent tread life.
    Are they quiet? That's my new concern....
  7. Jul 30, 2012 at 12:46 PM
    #187
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I sell the General AT2's at my shop here and they're a great AT tire! One of the best AT tire, studdable, long lasting, and they even have the snowflake
    Tough choice, but i would go General because of the price
  8. Jul 30, 2012 at 12:52 PM
    #188
    Digiratus
    Roaming the PNW
    The RedHead
    I agree with Mark, the BFG All-terrains are a solid choice, though I've not used them myself. Based on what I have observed, they are a proven tire with excellent construction and have a reputation of a long tread life and quite ride. Though they do look like they are a bit heavier than the duratracs. What size are you getting? 32x11.5-15 265/75-16?
  9. Jul 30, 2012 at 12:56 PM
    #189
    MTgirl
    Weesa
    Price is important too...and getting the Generals would be a savings of about $30 per tire. The only shop that will order them though is one place I really don't want to take my truck to....they messed up my suspension install. I'd rather get the more expensive tire at a more reputable shop
    31x10.5R15 I'd like to go skinnier but can't get them for a 15" wheel
  10. Jul 30, 2012 at 1:16 PM
    #190
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, both brands in that size have virtually the same stats
    http://www.tirerack.com/tires/tires...hite Letters&partnum=105SR5ATAKORWL&tab=Specs
    http://www.tirerack.com/tires/tires...GRAT2OWL&vehicleSearch=false&fromCompare1=yes
    for comparison:
    http://www.tirerack.com/tires/tires... White Letters&partnum=105QR5WDTOWL&tab=Specs
  11. Jul 30, 2012 at 1:32 PM
    #191
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    One thing to keep in mind when ordering is to make sure your size has the snowflake
  12. Jul 30, 2012 at 1:39 PM
    #192
    MTgirl
    Weesa
    31X10.5 in both brands have the severe winter rating
    Just called another local shop....they can get Generals. Plus there is a $50 rebate on them right now :) I could get them for about $800 including mount, balance and lifetime upkeep of rotations etc.
  13. Jul 30, 2012 at 1:56 PM
    #193
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Nice! I know the Generals have 60,000 miles guaranteed. What do the BFG's have?
  14. Jul 30, 2012 at 2:32 PM
    #194
    Digiratus
    Roaming the PNW
    The RedHead
    New info posted in the OP.
    Meeting up on Monday, August 13th at 10:00 am in the parking lot of:
    Asker's Harvest Foods
    415 West Main Street
    Graingeville, Id
    Please plug this into your GPSs.
  15. Jul 30, 2012 at 2:52 PM
    #195
    MTgirl
    Weesa
    the 60k warranty isn't valid on LT tires :rolleyes:
  16. Jul 30, 2012 at 2:56 PM
    #196
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
  17. Jul 30, 2012 at 3:04 PM
    #197
    MTgirl
    Weesa
  18. Jul 30, 2012 at 3:14 PM
    #198
    Blackdawg
    Monte
    Wyoming/St. Louis
    I vote BFGs. Best tire brand out there IMO.
    Thanks mike.
    Okay I have another question about lolo. Would we be leaving on Wednesday or Thursday? How long would it take? Be done on Friday? Trying to get the ride home logistics figured out. If I have time I might do independence pass alone or with jon
  19. Jul 30, 2012 at 3:21 PM
    #199
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Dammit! I thought it said Includes :pout:
  20. Jul 30, 2012 at 3:23 PM
    #200
    MTgirl
    Weesa
    BFG's will cost me about $1000 and the Generals are actually ranked higher on tirerack.
    Nope. I don't think anyone warranties truck or offroad tires....they consider them too high of a risk.
