The Maze - Teapot Rock to The Doll House
Discussion in 'Moab' started by pinem56, Mar 28, 2021.
  1. Mar 28, 2021 at 6:55 PM
    pinem56
    pinem56 [OP] Well-Known Member
    NE
    2018 TRDOR DCSB AT
    I have a semi-stock 3rd gen. I have full skids and sliders, currently still at stock height with stock tires, but planning on a 2" lift here in a month or two, but I'm still hesitant to take the plunge to go not OEM. Definitely going to replace stock tires with something with a Load C rating (Cooper AT3 LT or Goodyear Duratrac) before going. So that all said, any reason I should shy away from trying to make it out to The Doll House? I have full recovery gear and there will be two vehicles, so being stranded alone is unlikely.
    I've done the White Rim Trail, and that was essentially a breeze in my stock configuration truck. Fins and Things between the fun parts was a bit concerning at times, but I made it through without destroying my rear end (did have a hitch skid plate installed). I guess what I am most worried about is the stock rear bumper, I really don't want to destroy my rear radar sensors, if I can avoid it. As such, the only thing I really fear is coming down off of oddly shaped ledges that my hitch skid is not going to be able to push off of sufficiently to keep the bumper a safe distance.
  2. Mar 28, 2021 at 7:02 PM
    Parma
    Parma Well-Known Member
    Adam
    Utah
    2019 TRD Off Road
    The only problem spot is Teapot Rock. It may take some rock stacking, but you should be good. The rest is very doable.
    Durango95 likes this.
