The mudrider but not offroaded or mistreated my truck is garbage superthread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mudrider300wsm, Feb 4, 2012.
  1. Feb 4, 2012 at 9:21 PM
    #41
    Order66
    Order66 Four Wheel Drive With Room For Five!
    Nick
    Georgia
    88 4Runner SR5 V6
    3 inch body lift, 33x12.50x15 Pro Comp A/Ts, Front and Rear Tube Bumpers
    If that's a 4Runner you're talking about then I can only imagine.
  2. Feb 4, 2012 at 9:21 PM
    #42
    mudrider300wsm
    mudrider300wsm [OP] Active Member
    New Orleans, LA
    08 Regular Cab Base
    235 75 R15 BFG All-Terrain KO
    I have an 08 reg cab base 4x2 auto and it seems to shift into high gear earlier than it is supposed to. The engine seems to vibrate and shake as if it struggling to keep accelerating. Does anyone else notice this?
  3. Feb 4, 2012 at 9:22 PM
    #43
    Order66
    Nick
    Georgia
    88 4Runner SR5 V6
    Ah.
  4. Feb 4, 2012 at 9:22 PM
    #44
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I'd like to know what kind of problems you're having. MOST users (like myself) never had a problem. Regular maintenance as per the service manual, and not beating the engine up, will make this truck last to at least 300k. The only thing i think that isn't built like the older models, is the interior, frame and suspension components.
    1)don't add dumb shit to the engine
    2)follow your maintenance guide
    3)drive it like you love it and want it to last
  5. Feb 4, 2012 at 9:24 PM
    #45
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Nope, pick-up
  6. Feb 4, 2012 at 9:25 PM
    #46
    Order66
    Nick
    Georgia
    88 4Runner SR5 V6
    yep
  7. Feb 4, 2012 at 9:26 PM
    #47
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    My rack and pinion took a dump at 16K... I beat the shit out of it off road and wasn't surprised.
    My battery literally exploded one day at 28K. I don't blame Toyota though. Batteries fail. Its a fact of life. BUT she sure does start up every single time I've ever asked her
  8. Feb 4, 2012 at 9:27 PM
    #48
    dYL0n
    Dyl0n
    New Orleans, LA
  9. Feb 4, 2012 at 9:28 PM
    #49
    Order66
    Nick
    Georgia
    88 4Runner SR5 V6
    Oh, apparently the people on the 4Runner web page had a lot of problems with their 2nd gen's as well.
  10. Feb 4, 2012 at 9:33 PM
    #50
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Bought this brand new back in 1988...the thing was a tank and ran great when I sold it with around 300,000 miles. It had manual locking hubs, manual transmission and the original clutch. I think these newer trucks have way too much electronics and safety bullshit.
  11. Feb 4, 2012 at 9:36 PM
    #51
    KalamaKid
    Oregon
    :drool:
  12. Feb 4, 2012 at 9:42 PM
    #52
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Please elaborate.
    Do you mean that it shifts into overdrive too soon and it feels like there isn't enough torque to propel the truck? Like if you were to start off in 3rd gear in a manual transmission vehicle?
    If so, the kick-down cable might need adjustment.
  13. Feb 4, 2012 at 9:44 PM
    #53
    KalamaKid
    Oregon
    When was the last time you cleaned your MAF and throttle body? Also disconnect the battery for 30 seconds and go for a test drive after.
  14. Feb 4, 2012 at 9:45 PM
    #54
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the truck? 9x out of 10 it's ignition related. Make sure your tranny fluid is up to level; in fact do all levels.
    Check the little VACUUM lines around the engine to make sure they aren't brittle, cracked or disconnected and fix or replace as needed.
  15. Feb 4, 2012 at 9:48 PM
    #55
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have always felt that the autos hold D too long and grab it too soon and feel like they are lugging at slower speeds
  16. Feb 4, 2012 at 9:54 PM
    #56
    mudrider300wsm
    New Orleans, LA
    08 Regular Cab Base
    The truck has just over 24,000 miles on it. It seems to not have enough power when it shifts into overdrive to keep the truck accelerating slowly. When I accelerate quickly, it shifts fine. It only happens when I slowly accelerate.
  17. Feb 4, 2012 at 9:56 PM
    #57
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If you've never done the plugs, now would be a good time.
  18. Feb 4, 2012 at 9:56 PM
    #58
    dYL0n
    Dyl0n
    New Orleans, LA
    Should have responded to me.
    You have a 4 cylinder. That's why.
  19. Feb 4, 2012 at 9:57 PM
    #59
    KalamaKid
    Oregon
    Its totaled
  20. Feb 4, 2012 at 9:58 PM
    #60
    mudrider300wsm
    New Orleans, LA
    08 Regular Cab Base
    I am an LSU guy. We can't stand Tulane.
