The mysterious Bump - Jolt - late downshift - etc.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matthewlost, Mar 25, 2011.
  1. Mar 25, 2011 at 3:02 PM
    Matthewlost
    Matthewlost [OP] Active Member
    Louisiana
    2003 Prerunner SR5 X-Cab, V6
    Just bought a 2003 tacoma pre-runner 3.4 v6 auto (119k). I wish I would have noticed the bump before I purchased. You know the one - coming to a stop then *bump*...Letting off the break, then *bump*.
    After reading probably every thread available related to this mysterious issue, I've formed an opinion on the bump, and I do believe it is a transmission issue, although I don't think it's a serious transmission issue - though certainly a design flaw.
    I just drove over to the toyota dealership and spoke with the senior technician who giggled to himself when I told him the issue. He said, and I quote, "your transmission is doing what it was meant to do - relieving built up pressure." He says the tacomas and tundra's have been doing it for years. He also joked that the problem would only last for 500,000 miles - funny guy, but it did make me feel better.
    It just seems so wrong. BTW, many of you think this issue is axel wrap and I'm not sure you're wrong, but in my case, I don't think its axel wrap as the vehicle doesn't jolt when I put the car in neutral and come to a stop.
    No real question here, but if anyone cares to add their two cents, please chime.
  2. Mar 25, 2011 at 3:05 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Fluid change?
  3. Mar 25, 2011 at 3:09 PM
    Matthewlost
    Louisiana
    In the process of a scheduled drain and refill, once every two weeks for the next two months. I've already drained and refilled once. The old fluid wasn't that bad, but it did need to be changed.
  4. Mar 25, 2011 at 3:10 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Most that I have read said it is jsut a hard shift down to first gear. One thing I noticed is if you put the truck in "1", take off, then slam on the brakes. No thump. Put it in "D", take off and let it get out of 1st gear, then slam on the brakes. Thump. Def shifting back down to 1st gear
    As for the axke wrap, even if it was, it would not do it in neutral because the drivetrain is not "pushing" the vehicle as you try to stop. That is what loads the spring causing axle wrap.
  5. Mar 25, 2011 at 3:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If those are the original springs, at 120K they are done. Regardless of the doublsspeak from the toyota rep, the tranny is not the cause of the thumps.
  6. Mar 26, 2011 at 7:31 PM
    Matthewlost
    Louisiana
    No offense digi, but you dont know what ur talking about. My springs are most definitely original and without question in perfect working order. Probably best not spout pure speculation when people need to learn about their vehicle. Ive been around trucks all my life and it does this site a disservice to imply knowlege when it isnt there.
  7. Mar 27, 2011 at 11:22 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well maybe you should just get some new ones anyways! get in on the wheelers group buy! :D haha
    weird problem man, hope you figure it out...unless it is suppose to do that?
  8. Mar 27, 2011 at 5:50 PM
    Turp
    Turp Well-Known Member
    Virginia
    02 PreRunner SR5
    K&N panel/ snorkel removed Keyless
    My Taco does this and I have noticed it is not present when I come to slower or easy stop. And, I believe my 4Runner did it as well but I can't be sure. Regardless, it's not a big issue to me. If it is springs, I'll post it in a year when I replace my springs and shocks.
  9. Mar 27, 2011 at 8:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    No offense taken Lost.
    If your springs are originals, at 120,000 miles +, they very much past their prime and can be the root cause of a lot of what you have complained about.
    Not to imply that your experience isn't of value, but if your truck experience lies elsewhere, in other makes and models, it is deceiving you when dealing with stock tacoma leaf springs.
    If you are willing to invest a little time, do some searches for some of the terms you used to describe the issues. There have been hundreds of similar examples documented on this site.
  10. Mar 28, 2011 at 5:24 AM
    Matthewlost
    Louisiana
    Yes, I think that is sound advice. Thank you.
  11. Mar 28, 2011 at 12:26 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    It's not a problem caused by worn out stock springs. I have OME springs that are less than a year old and I have the same issue with my truck. Could be a transmission issue but I'm still suspicious that it might be some axle wrap not caused by worn soft springs, but by frame flex. I am planning on adding some rear frame plates soon to see if it improves the problem. The rear plates should take care of any of the frame flex that might be happening.
  12. Jul 15, 2012 at 9:50 PM
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
    Whatever became of your issue Matthew?
    I have this going on like many others. Definitely does not happen if I stop slowly. It seems to me that the trans doesnt downshift to 1st until you let off the brake and begin to move again. It doesn't seem healthy but I suppose I can ignore it after a while.
  13. Jul 16, 2012 at 12:18 AM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    Wouldn't Axle Wrap only occur under acceleration? The way i understand the phenomenon, i don't see how it could occur under braking.
  14. Jul 16, 2012 at 12:43 PM
    jaunty
    i think axle wrap term is a bit misleading for this issue. i'd describe it more as driveline binding or something.. i think thats why many say greasing their zerks solved the problem. I'm just hoping its definitely something like this and not a trans issue, but the fact that it doesnt downshift doesn't seem right.
    I took this from another thread, its a good description of the issue
    http://www.tacomaworld.com/forum/2n...akes-disengaging-after-fronts-jolt-lunge.html
  15. Jul 16, 2012 at 12:48 PM
    jaunty
    i am quite surprised toyota hasnt resolved the issue yet...
  16. Jul 16, 2012 at 1:12 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    GM had a similar issue as well. Put gear in Drive, drive vehicle, decelerate to stop, "bump". Release brake pedal and accelerate, "bump". The problem in that case, which may be the same here, is that when you are coming to a stop, using the brake pedal, the axle will "wrap" for lack of a better term, as the rotational force is transferred into heat (from braking) and longitudinal force. (when the momentum of the truck wants to continue, but the brakes are saying 'no')
    What this does is causes the leaf springs to wrap up, and alters the angle of the pinion. When the pinion angle is altered, it slightly pushes/pulls on the carrier bearing. When this happens, the slip yoke going into the back of the transmission can bind if it lacks lubrication.
    The way we would fix this, which lasted anywhere from 30k miles to 100k depending on the truck, was to remove the driveshaft, then apply a generous amount of silicon sealer (RTV Silicon) around the "teeth" of the slip yoke (not the transmission side, but the driveshaft itself) then reinstall the driveshaft, and allow about 2 hours to cure.
    What this does is it fills in the minute amount of "free play" between the yoke of the driveshaft, and the output shaft of the transmission.
    Now this of course assumes that your "bump" is the same feeling.
    I know there is a lot of belief that the transmission is at fault, but I have years of experience in transmissions from all manufacturers, and I have never seen this bump condition be the fault of the transmission. I seriously doubt that is your condition, but again, without actually looking at your truck, I wouldn't swear to it.
    That being said, I would be willing to bet that you will fix this problem with my above suggestion.
  17. Jul 16, 2012 at 1:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Axle wrap/spring wrap primarily occurs during braking. The weak stock springs actually allow the axle to rotate a few degrees. The thump happens when the brakes are released, as this releases the stored energy in the wrapped spring.
    edit: Ha, beat me to it Bama.
  18. Jul 16, 2012 at 4:04 PM
    nico
    nico New Member
    san diego
    03 tacoma prerunner TRD
    my truck does the same thing 03 3.4 v6 prerunner with 94000 mi.
  19. Jul 16, 2012 at 4:31 PM
    feebs03
    feebs03 Well-Known Member
    Nebraska
    2003 TRD
    okay well i have this same problem with my truck (03 4x4 trd 120xxx miles stock leafs) the only thing i have not yet heard that i may think could be the issue for me is the trans fluid used.... i really dont know anything about transmissions so feel free to call me out but in the winter when my truck is cooler i have no problems at all. But in the summer and the truck is hot it is unavoidable. Is there grades of fluid like engine oil?
    just my 2 cents.
    edit: fluid levels check out in the correct range too. thought i was just low at first.
  20. Jul 16, 2012 at 7:25 PM
    jaunty
    I need to put the square u-bolt on to clamp the rear springs in hopes of fixing this issue.
    Does anyone know where i can find 2.5" square u-bolt with the plate? Ace had 2 and 3 inch but i'd like to go with 2.5'' for a nicer fit. i checked 5 autoparts stores today and home depot and none had it!
    I will probably end up fabricating my own just using two long bolts and two metal plates if i cant find any.
    EDIT: gonna pick this up today,. it is 2.5"
    http://www.autozone.com/autozone/ac...ries-and-Parts/Leaf-Spring-Clamp-Kit/_/N-25fq
