The mystery of loose steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Mar 1, 2019.
  1. Mar 1, 2019 at 3:15 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    I have a TRD Sport and always loved how tight the steering was, for a truck. I just replaced the whole suspension with a stock 3rd gen Sport suspension and the now the steering feels much looser. It has a couple inches of play in the wheel before the wheels start to turn which im thinking is one or both of the steering shaft u joints, but apart from that the steering overall is looser. It's as if it takes increased rotation of the wheel to turn the wheels as much as it used to.
    I really don't think it's any suspension part because all of them are new- struts, lower control arms with ball joints, upper control arms, inner and outer tie rods. Rear leafs and shocks also new. I had an alignment and it didn't help.
    Any ideas??
  2. Mar 1, 2019 at 3:19 PM
    tcjacado
    tcjacado Well-Known Member
    Rack and pinion ... how much play is there before turning.
    Meaning does the wheel just turn or is the rack following before engaging
  3. Mar 1, 2019 at 3:35 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Probably 1.5-2 inches. I'd have to get under it to look if the lower shaft is turning in acccordance with the steering wheel
    Why would this issue start after installing a new suspension?
  4. Mar 1, 2019 at 3:38 PM
    tcjacado
    Every thing is turning except the rack.... yes it can happen if the rack gets tugged on to much. Are you having VSC issues.
    Did you do upper and lower control arms too?
  5. Mar 1, 2019 at 5:07 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Yup, both upper and lower.
    What's VSC?
    Are the steering racks on these trucks adjustable? Like, by loosening the lock nut then tightening the larger nut inside, etc...
    tcjacado likes this.
  6. Mar 1, 2019 at 5:30 PM
    tcjacado
    That I do not know. The vsc is vehicle stabilization control
  7. Mar 1, 2019 at 6:38 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Gotcha. Nope, stabalization is fine and the suspension itself feels great. It doesn't jostle over bumps or drift. Just the loose steering
  8. Mar 1, 2019 at 6:42 PM
    tcjacado
    I hope others can give you better tips
    @gearcruncher @mechanicjon @BartMaster1234
    BartMaster1234 likes this.
  9. Mar 1, 2019 at 6:45 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Is the steering wheel sloppy? 1st gen fix is to tack weld the steering column.
  10. Mar 1, 2019 at 6:46 PM
    tcjacado
    2nd gens had the zip tie mod
    Key-Rei likes this.
  11. Mar 1, 2019 at 6:48 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Probably won't fix actual input slop but still worth doing. :thumbsup:
    tcjacado[QUOTED] likes this.
  12. Mar 1, 2019 at 8:12 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Yah, it's a bit sloppy now. Why would that start after the new suspension?
  13. Mar 1, 2019 at 10:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the big nut under the airbag on the steering wheel. Its rare but those things can come loose
  14. Mar 1, 2019 at 10:22 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Get somebody to move the steering wheel while your looking at the steering stuff. Maybe the tie rods didnt get torqued down right. You should be able to tell if something is loose.
    Make sure your steering rack isnt moving.
    But I'd bet the alignment messed with your caster and it's just barely in spec enough for the quick change tire place to let go.
  15. Mar 2, 2019 at 3:55 AM
    gearcruncher
    Canadain bumper technician
    A couple inches of play in the steering wheel after all new front end components seems a bit much . I agree with the guys who posted above me .
    Have somneone sit in the truck and move the steering wheel from side to side while you look for play .
    It may be possible that your original suspension was so worn out , that you never noticed how much play was in the steering . Now that everything is tight and new , another problem sticks out like a sore thumb .
    Let us know what you find
  16. Mar 3, 2019 at 8:39 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    This is what i was wondering- if all new components made visible something else that is worn. Is play in the steering shaft u joint a common problem on these trucks? Thats where I'm going to look first
  17. Mar 3, 2019 at 11:09 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I just looked at everything in the steering shafts, it all looks fine. No play in either the upper or lower u joint, nor in the joint that ppl zip tie. Rack and tie rods are tight
    The only thing that had any play was the foam or rubber insert that insulates the shaft where it travels through the firewall. As i turned the wheel the shaft would compress the rubber a bit side to side but I'm not sure if that would matter in regards to the tightness of the steering. I'll have the shop take a look at it when i bring it back to get the alignment fixed, hopefully they have an opinion
  18. Mar 3, 2019 at 11:15 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are the steering rack bushings soaked with oil? Does the rack move side to side instead of the wheels
  19. Mar 3, 2019 at 11:21 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Rack doesn't budge. I didn't check the bushings though, didn't want to lay in the snow. I'll do that next though. How many bushings are in the rack?
  20. Mar 3, 2019 at 11:38 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the rack isn't moving then the bushings should be fine, they hold the rack in place
