The Nashville Thread
Discussion in 'Tennessee' started by ThunderOne, Aug 28, 2017.
  1. Feb 1, 2024 at 7:40 AM
    #981
    JuiceBox1855
    JuiceBox1855 Active Member
    2015 Tacoma
    I reached out to mill creek overland about a month ago about a few things and their response was basically “wow that’s a lot of questions” never heard back after my reply so I’ll keep looking
  2. Feb 1, 2024 at 8:04 AM
    #982
    alphaomega420
    alphaomega420 Well-Known Member
    2019 SR SX V6 RWD
    I’ve heard good things about Music City 4x4 and Total Offroad. Might give them a shot.
  3. Feb 1, 2024 at 11:22 AM
    #983
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Check with @Kerleyfries, he might be able to help you out. He's not a commercial fab shop but he has some skill with a welder.
  4. Feb 2, 2024 at 11:00 AM
    #984
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    No tube bender. Custom rock sliders is honestly going to be more trouble than it’s worth.
    @JuiceBox1855 what are you looking for that’s driving you to go custom vs. something off the shelf?
    KRAMERICA[QUOTED] likes this.
  5. Feb 2, 2024 at 10:50 PM
    #985
    JuiceBox1855
    2015 Tacoma
    I want something more tucked than 0° but still have surface area to be used as a step for my wife. This may exist off the shelf so open to suggestions
  6. Feb 3, 2024 at 8:23 AM
    #986
    Kerleyfries
    Zack
    Lebanon
  7. Feb 9, 2024 at 6:40 PM
    #987
    Nashville
    Nashville Well-Known Member
    Rich
    ‘23 SR5
    Went to the overlook. Took some pics
    KRAMERICA likes this.
  8. Feb 13, 2024 at 9:44 AM
    #988
    JuiceBox1855
    2015 Tacoma
    Hey Nashville people. I’ve posted a couple times here but haven’t really made any friends or connections. I’m planning to finally start modding my truck and will probably start with a lift. I’ve never done any suspension work but I’ve watched enough YouTube to be as much of an expert as I can but if any friendly folks in the area would want to make a friend and offer some guidance when the time comes I’ll supply you as much beer and food to go on your grill as you’d like. Me and my wife live in an apartment complex so not too sure how easy it be install coilovers and a leaf pack in the parking lot with a scissor Jack and Jack stands so I’d appreciate some help and a new Toyota friend
  9. Feb 16, 2024 at 2:10 PM
    #989
    Hutch98
    Hutch98 Well-Known Member
    Nashville TN
    22 TRD OR AG
    Had a 98 Taco SAS'd with D-60's and 42 SX-II's
    If you are not in a big rush I can help you out in the spring. Going to do my lift as well Bilstein 6112/5160. There will be beer(s)
    JuiceBox1855[QUOTED] likes this.
  10. Feb 16, 2024 at 4:36 PM
    #990
    JuiceBox1855
    2015 Tacoma
    Yea man! Tbh that would hopefully be enough time to get all parts together plus the warmer weather!
  11. Feb 19, 2024 at 10:38 AM
    #991
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Most apartment complexes won't allow you to work on your vehicles in the parking lots, so you might want to check the rules at yours. I live an hour outside of Nashville, but I've had several people come out here in the past to install lifts. I've never done a 3rd Gen, but I don't think there is much difference in the suspension setup. If you need some assistance or advice on what to get, I'll be glad to help if I can.
  12. Feb 19, 2024 at 12:43 PM
    #992
    JuiceBox1855
    2015 Tacoma
    I have a 2nd gen 2015. Even if I could get away with it I think it would be less than ideal with only a scissor Jack in a busy parking lot. I’d definitely appreciate some wisdom and advice. Mostly worried about pinion angles and vibrations after the fact
  13. Feb 19, 2024 at 1:08 PM
    #993
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I run a 3° shim under my leafpack to get rid of the driveline vibrations. How much of a degree shim you need or if you need anything at all largely depends on how much you lift the truck. I lifted mine 3" and definitely needed the shims. However, when I first did the lift I did the shim but also put a drop spacer in the carrier bearing mount. I still had some vibration so I removed the pinion bearing spacer and it fixed my vibration issue. I don't recommend my initial approach, do one or the other but not both to start out. Should you have any vibration issues there is a good thread on here to help solve them.
    https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/
  14. Feb 22, 2024 at 7:31 AM
    #994
    Hutch98
    Nashville TN
    22 TRD OR AG
    Should plan a meet and greet have a few beverages of choice and hear each other's plan's. I will be doing my 3rd gen lift in my driveway and will have my alignment scheduled also.
    JuiceBox1855 and KRAMERICA like this.
  15. Feb 22, 2024 at 8:40 AM
    #995
    JuiceBox1855
    2015 Tacoma
    I’d be down
  16. Feb 22, 2024 at 8:41 AM
    #996
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    That'd be a great idea, it's been a long time since we had a meet-n-greet for the Nashville area.
  17. Feb 22, 2024 at 9:50 AM
    #997
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    @Hutch98 @JuiceBox1855 I don't know how much either of you plan to put into your trucks, but if you have some extra coin to spend on some nice used suspension parts for your truck, Gideon just posted these on the main TN thread. They are top of the line parts, way better than Bilstein.
    Hutch98 likes this.
  18. Feb 22, 2024 at 10:34 AM
    #998
    Hutch98
    Nashville TN
    22 TRD OR AG
    The Score Board has plenty of parking and plenty of beverage/food options. I'm in south Nashville Murfreesboro pike.
  19. Feb 28, 2024 at 8:42 AM
    #999
    Sandaygo
    Sandaygo New Member
    Mid TN
    2018 Tacoma TRD Pro (Calvary Blue)
    Hey guys recently joined TW and new (6 months) owner of a taco. In the middle tn area as well. I wouldn’t mind meeting up to get to know some ppl.
  20. Mar 15, 2024 at 11:17 AM
    #1000
    Hutch98
    Nashville TN
    22 TRD OR AG
    Meet up on Sat 3/30 possibly? I know it is Easter weekend. Other weekends til end of April are shot but not in a bad way.
