The never ending money pit
Discussion in '3rd Gen. Builds (2016-2023)' started by Veet-88, Feb 14, 2023.
  1. Feb 14, 2023 at 7:25 PM
    Veet-88
    Veet-88 [OP] Well-Known Member
    18 Tacoma DCLB sport
    Well figured I have been lurking on here long enough it's time to post a bit. Truck build is mainly geared towards fishing/camping trips with some light trail runs in there
    Dec 11,21 I picked up a new to me 18 DCLB sport after the third deer finally put down the old ranger. So here's the build story to now.
    The day I picked it up. So clean and stock.
    First batch of mods included.
    Leer 100xl
    Fuel kicker 17x9 +1
    265/70R17 duratracs
    Rokblok XL flaps
    Knock off heritage grille
    Trd skid
    Baja designs squadron amber fogs
    Next step was a big one at 1 year
    Elka 2.0 2-3"
    Spc uca's
    OME med leafs
    Rigid spots
    Cali raised ditch light brackets
    About a week after doing the lift the 265's just looked small so 285 duratracs went on. At the same time new lower control arms since the caster bolts had seized in place.
    Lift was set at 3" up front which I would not do again but it was done intentionally for a future step.
    Then came a couple mods I had always wanted to do. A winch and darker. Because what else says cool off road truck?
    Greenlane aluminum stump bumper
    Smitty x20 10k winch
    Arb snorkel
    Diode dynamics 30" amber combo
    Few notes on this update.
    Diodes stage series bars have awesome light output but this is more of a true amber and does not contrast well with the baja's. The stealth light bar brackets do not work with that bumper ended up building my own sketchy mounts. 20k later they are still solid.
    The snorkel install was one of the hardest things I took on. Not due to difficulty but building up the nerve to chop up that fender to mount it. Other thing I want to note is the snorkel is more so for dust/splash protection aswell as some cheap insurance if I did manage to dip that intake below a waterline. (Did this with my second gen was not a fun experience) I went from killing 3 air filters in a summer to I'm still on the same one in a year.
    I had the lift set to 3" to help compensate for the coil settle and the sag from this added weight as my target was around 2" of lift. 3" just constantly topped out on trail and was quite unpleasant.
    After having the cap vandalized I sold it off as it really didn't work as I wanted for camping.
    Bakflip mx4
    Prinsu roof rack
    Pelican v800 boxes
    Ov tune
    Diode 42" roof light bar spot pattern
    Sketchy abs fishing rod holders
    Mounting the diode light was easy with the supplied mounts, had to notch the deflector about 1/2" on each side to accommodate it being a touch wider that most.
    That ov tune smartened that transmission right up didnt really change to much up to improve fuel economy but made it alot more drivable overall especially while towing.
    After my spc's x axis joints died after 8k I made the move to much simpler uca after alot of local guys having the same failure. Also never liked the fitment of the trd skid to my bumper so that brought on a change.
    Okx engine/trans aluminum skids
    Dirt king uca's
    Diode sae fog wide amber
    At this point there was a few items showing some wear from trail use.
    Bent drivers tie rod
    Outer passenger cv boot tear
    Clamshell bearing vibration
    Everything but the clamshell bearing was replaced with oe. Took the time to install the ecgs bushing to replace that. And let me tell you that made a world of difference to smooth it out.
    This brings us to the 2 year mark with this truck. And another big dollar update.
    Cmc/pinchweld rear fender liner
    Summit offroad apex 17x9 -25 bronze
    295/70r17 yokohama G003 MT
    Ark splash gaurds
    Did I wear out my dura tracs? No. Did I have any complaints on my duratracs? No. Did I feel like trying a new tire after running them on my last 3 trucks? Yup. I had always wanted to change my wheel out due to them being quite heavy and when the opportunity popped up to score these at a good price and I was already doing a cmc to make the -25 fit hey why not cram a slightly bigger tire on there at the same time and cancel out all weight savings from the wheel change. Would I reccomend anyone do a cmc simply to fit a 295 over a 285? Nope.
    Having said that the 295 does add just that bit extra to the appearance I found, or it's just those g003's.
    The g003 has been a really suprising tire so far I have noticed no impact to drivability or fuel economy so far. Tire is very quite given how agressive it is. I barely notice it with the wind noise off the roof rack.
    Only 600km on the set up so far but 10/10 I have no complaints. See how I feel after driving them in -20
    April 23,23 update
    Few new additions to help prep for the camping season.
    Treeline 6.5x6.5 awning mounted directly to the side of the prinsu rack the misses and I are short enough Mounting it off the rack was high enough and I can still access my rack box with it pushed all the way out.
    Baja designs s2 lights set up for reverse/chase lights. Had a fun time launching the boat in the dark last year really hoping these make it alot easier.
    Lastly tossed on an auxbeam switch panel and cleaned up all the wiring in the engine bay.
    so far happy with all the new goodies will update this again with some feedback on everything once i have some hours on everything.
    Oct 19,23 update
    Didn't want to run the G003 MT's over the winter so we t ahead and mounted up a studded set of 285/70r17 yoko G017's right curious to see how they do being a rather new release from yoko.
    There will be much more to come with time as the finances allow.
    Feb 3,24 update
    Started dumping some money into improving the camp set up for this summer.
    Added Ra motorsport element bed bars with brackets to work with the bakflip mx4 and kraves in house bed stiffeners to hold up the new to me cvt mt shasta hybrid tent. Also added prinsu's awning brackets and prinsu light bar brackets.
    Next up will be a rear seat delete and mounting platform to hold the dometix cfx3 45 and ecoflo delta 220240129_195144.jpg
    Lastly scooped a set of falcon T8's to remount the G003's on for summer.
    April 4,24 update
    Got the G003's mounted up on the T8's and on the truck, have to say the look exceeded expectation. It's loud and that was the goal.
    Added some baja designs squadron pro's to replace the Rigid's for ditch lights.
    Dropped the OME mediums for Dobinsons 112's with timbren bumps and Ubolt flip kit.
    Had another maintenance item to take care of being drums and shoes.
    to top it off rear elka 2.0's have been swapped for 2.5's
    Next step will be the back seat delete for the fridge and ecoflow. Only a month left till the first trip of the year.
    May 4, 2024
    A bit of a random batch in this update.
    Fridge is mounted and ready for the summer trips.
    Added the ufo snorkel upgrade pre filter to hopefully be another level of protection on the intake.
    With all the towing this month I wanted to monitor the trans temps closer so I added a scan gauge 3 to keep an eye on everything now. Excellent unit so far highly recommend it.
    This one happened on a wim but very happy with the results. The new baja designs fogs after my diodes started flickering and an s8 30" bar to replace the diode 30" stage series bars that I was just never happy with the colour tone of. And let me say that s8 blows the ss bar out of the water the output is incredible. Having matching colour toned fogs and bar is much easier to focus on. The diode fogs had a bigger spread but I think the baja will be a better true fog the cut off is very sharp compared to my ss3 pros.
    I think this will be the last of my spending spree for awhile time to get out and use it.
    May 31,24 update
    Well the spending spree hasn't quite ended.
    Added some elka 2.5 DC's up front after my 2.0s decided to drop all the oil out of them. Finger crossed these hold up much longer.
    It really is never ending
  2. Feb 14, 2023 at 7:30 PM
    Tacospike
    Two Trucks
    Looks awesome
    got the title right
    HondaGM likes this.
  3. Feb 14, 2023 at 7:33 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    It’s looks aight…
  4. Feb 3, 2024 at 11:56 PM
    Veet-88
    Might aswell start a post to show it off in the wild over the years.
    Road_Warrior and johnny_decaf like this.
