The next gen transmissions will be smarter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Marc529, Apr 30, 2017.
  1. Apr 30, 2017 at 9:41 PM
    Marc529
    Marc529 [OP] Well-Known Member
    They say your transmission will 'learn" your driving habits. But I think they missed one real important feature that could make a world of difference and cost very little.
    Current transmission are really very dumb, they just know what your asking of them at the moment you press on the gas and measure the load.
    My idea goes to the next level, anticipating what you will need it to do.
    We already know the 6 speed transmission sucks to put it politely. Shifting down seems to be the answer to generate more power but your already behind the curve and reacting to the need for power.
    What if, the transmission knows what you will want? What if it were to change shift points before you had to put your foot into it?
    So here is the idea.
    A computer can measure the pitch or tilt of the truck. We have this in our smart phones. I live in a hilly area and I would bet most of us do. Even a gentle slope will take more power to climb it.
    Unless you floor it, the truck shifts very quickly to the next gear keeping the RPMs down and thus power down.
    So here is theory. At a stop or anywhere actually, the computer knows the tilt of the vehicle at all times. As you start to move the computer tells the transmission your on a hill, maybe a steep one and moves the shift point accordingly so that you get more power/RPM starting with the first gear. So when you get to the next shift point the RPM is still up in the power range to continue to provide the power for that climb. Shift points continue to change given your tilt.
    The end result could be amazing. Smoother performance, no more downshifting to generate more power unless the driver punches it, wear and tear on the transmission goes down and post importantly a feeling of performance is restored.
    And yes, going down hill can be much safer. We get a little drag now but knowing the downhill tilt could be a game changer and a real safety feature.
    Anyone else here of such an idea?
    ChadsPride and Joe D like this.
  2. Apr 30, 2017 at 9:47 PM
    Joe D
    Joe D .
    Isn't a similar concept in use in high end European vehicles using GPS data?
    ChadsPride likes this.
  3. Apr 30, 2017 at 9:50 PM
    illogical
    illogical Well-Known Member
    2017 TRD 4x4 OR MT
    Sounds good in practice... then someone throws a leveling kit on it.
    Come to think of it... I want to say that it was mentioned once before in a thread here. Something about about leveling kits and third gen transmission issues. I'll link if I can find it.
    PvilleJohn likes this.
  4. Apr 30, 2017 at 9:51 PM
    Marc529
    I do not know why GPS would be needed, tilt would not need any external support.
  5. Apr 30, 2017 at 9:52 PM
    Marc529
    If a leaving kit were used a reset feature could reestablish level.
  6. Apr 30, 2017 at 9:53 PM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    Funny. This is what the manual transmission is for. Problem solved
  7. Apr 30, 2017 at 9:55 PM
    Joe D
    Joe D .
    It's not only tilt that is recognized in those vehicle but appropriate gear / speed when approaching / during / exiting a turn or corning.
  8. Apr 30, 2017 at 9:55 PM
    illogical
    2017 TRD 4x4 OR MT
    Yep, that would do it, duh. Hopefully they would let us do it and not make it a dealer only kind of thing.
  9. Apr 30, 2017 at 9:55 PM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    They just need to start over and figure it out. We have 2016/17 rams at work with the 8 speed transmission and they work GREAT. 90% of the time you don't even feel it shift and the only time you do is when you floor it and it gets to work. I can't understand how they jacked up the transmission as bad as they did. I test drove a 2017 last Thursday and it was horrible.
    shakerhood likes this.
  10. Apr 30, 2017 at 10:01 PM
    Marc529
    One more feature that can make a vehicle smarter. We call it a slip skid indicator in an airplane. It will tell you if you are sliding sideways per se. On ice it could cause you to let the vehicle coast to regain steering control or even alert you to a slip.
    Joe D likes this.
  11. Apr 30, 2017 at 10:08 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Cvt tranny
  12. Apr 30, 2017 at 10:08 PM
    Joe D
    Joe D .
    Step on the ball.
    Ya man yaw is measured on modern vehicles.
    I think the auto technology is about to take a giant leap foreword. Several companies (not just automotive but also auto vendors) are doing some very detail mapping for future autonomous vehicles. As this technology comes on line AND the V2V stuff (think TCAS if you're an aviation guy) and V2 infrastructure spool up, vehicles really will be able to predict the most logical thing to do...assuming the programming is correct & all systems are in the green.
  13. Apr 30, 2017 at 10:11 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Don't bother finding it. That was the most poorly executed "study" I've ever seen. :)
  14. Apr 30, 2017 at 10:52 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    scocar and specter208 like this.
  15. May 1, 2017 at 3:51 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    I don't know what shift logic Honda is using on the 2017 Ridgeline, but it shifts perfectly and is always in the right gear. My wife's BMW X3 has an eight speed and it also shifts perfectly. The right technology is out there, unfortunately Toyota doesn't have it yet!
    ToyoMann likes this.
  16. May 1, 2017 at 4:13 AM
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
    Wouldn't it better to just make the driver smarter? You know, like more training so then he/she'll be capable of driving a manual trans (among skills) and anticipating the proper gear. I swear all the car manufactures are actively trying to make drivers dumber.
    W8N41, Spare Parts and Badmotorf1nger like this.
  17. May 1, 2017 at 4:36 AM
    sjwhitaker
    Jake
    Berea, KY
    Exactly. Given the technology, R&D and funds available to car companies a transmission and or engine should never be an issue this day and time.
    Joe D likes this.
  18. May 1, 2017 at 4:39 AM
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    Was that bradwhitenikki's driveway study?
  19. May 1, 2017 at 4:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    I could go with that.
    Or another angle is the drivers are already dumb, and they are just being accommodated. Like there are several posts a week around here (and other forums for other marquees) asking questions about rudimentary automotive things, things that are in owners manuals. Like 'why is my maintenance required light on?'.
    @Marc529 while you are teching out the new trans, could you get them to return the dipstick?
    #savethedipstick #dipsticksmatter
  20. May 1, 2017 at 4:59 AM
    Yooper40
    Yooper40 Active Member
    2017 TRD Sport DCSB MANUAL 4 x 4 White
    Manual transmissions do this but requires driver input and execution. A CVT would be horrible in this application. Had a 2013 Subaru Outback with one, felt ok but completly gutless. More power and low end torque would help in these trucks, but fuel economy and programming really screwed over this design. Hopefully there will be a ECM fix this summer to help. Mine is a manual so not that big of a deal, just keep the RPM's between 2500-3000 and everything is fine.
    Joe D likes this.
