The NOOB ASK Questions Thread!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billas333, May 5, 2010.
  1. May 6, 2010 at 7:15 PM
    #61
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Thank you
  2. May 6, 2010 at 7:20 PM
    #62
    BigBawlzTaco
    BigBawlzTaco Wanna know how I got these scars?
    Forsyth,Georgia
    Chevy Avalanche
    Straight piped.
    What isn't a Tacoma? :D
  3. May 6, 2010 at 7:21 PM
    #63
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    :notsure:
  4. May 6, 2010 at 7:23 PM
    #64
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I don't think so...there's not really enough space for a winch that'd be capable of pulling you out in a jam :eek:
    But anything is possible I guess :D
  5. May 6, 2010 at 7:36 PM
    #65
    1980
    1980 Well-Known Member
    The Dust Bowl
    Since most people use a winch once in a blue moon, if at all, for most of their driving a removable one is sometimes a valid option.
    Google "front mount universal receiver for Toyota pickup" and "universal receiver winch mount" for an example of a relatively inexpensive winch attachment solution.
    A universal receiver mounted winch will also allow you to winch your truck backward as well as forward.
  6. May 6, 2010 at 8:54 PM
    #66
    Silva
    Silva Member
    Maryland
    06 SR5 Offroad TRD Debadged 6SPD MT
    20% tint, duel flowmaster 40 series, removed back seats for 2 10" JL Subs, kenwood head unit, viper alarm, blacked out Toyota emblem
    OK guys and gals I have a lot. I want to fit 285's, i know ill need a lift but I'm either going with a three inch or new shocks. I have a stock set up right now and I wanted to know the mods required to fit 285's. Also saying i get them to fit will I need a gear swap to compensate for the heavier tires and lift/shocks? And what size rims look better with 285's, 16's or 17's?
    And is it worth getting wheel spacers? I know I will probably need them to fit the tires but I am worried about my paint getting chipped. And no I will not be going off road. And however I lift the truck either with shocks or the three inch lift I still want to try an keep it as smooth as possible and is there any more additions to make it smooth after the lift. Feel free to PM me or email with suggestions or tips.
    Thanks,
    Silva
  7. May 6, 2010 at 9:17 PM
    #67
    billas333
    billas333 [OP] They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    Damn Noobs, j/k I asked all the same Q's about a year ago.
    Too fit 285s you will need a 3inch lift or higher set-up whatever that maybe. You can get all new coilovers or you can simply get new coils and perhaps a spacer. Recommended is to do the coilovers because I did the spacer and hated it so i went and bought coilovers.
    You will need to remove the front mud flaps to clear the 285s as well as cut some of the thin plastic fender liner. Pretty simple thing to do. Re-gearing is not necessary to run 285's. I have 17s and love them. Spacers are not required depending on your wheel setup. If you get new wheels the backspacing of them makes a difference. Check out the wheels tire thread fo rmore info on that.
    If you get it aligned right and have a good lift setup you should me good to go
  8. May 6, 2010 at 9:22 PM
    #68
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    Wheel spacers are like body lifts... :smash:
  9. May 6, 2010 at 9:26 PM
    #69
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Ok heres my idea, King replacement coilovers are a great ride, but when cranking them it becomes less desireable. Would it be possible to have Downsouthmotorsports make me a shock 3 inches too long, and have no preload and get 3 inches of lift?
    Also to inform everbody if you get a supercharger get 886s because you only get about 2 inches of lift from 885s. 100 pounds in the engine bay is about the same as a winch i believe
  10. May 6, 2010 at 9:34 PM
    #70
    wolfeye
    wolfeye Well-Known Member
    I'm running the diff drop, appreciate you steering me in the right direction. 5100's in the rear set to the top setting wont raise the rear end will it?
  11. May 6, 2010 at 10:28 PM
    #71
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Just picked some up. Works like a charm!
  12. May 6, 2010 at 10:37 PM
    #72
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 4x4> 03 SR5 4x4 total> 14 Crewmax TRD
    Had tons on the old Taco's.... new Tundra is pretty stock
    subbed so I can help out the NOOB's on here without em gettin flamed.
  13. May 6, 2010 at 10:52 PM
    #73
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    does anyone know how much it costs to regear a 4x4 taco at 4.56 gears
  14. May 7, 2010 at 7:31 AM
    #74
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    $1.27...ish
  15. May 7, 2010 at 7:37 AM
    #75
    KaoskrewPB
    KaoskrewPB -Empty-
    I just got icon CO's and have mid travel,
    if I were to get the all pro LT kit, do I have to get new CO's?
  16. May 7, 2010 at 7:37 AM
    #76
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I don't think you can raise the 5100s in the rear. It's not adjustable (maybe someone else can chime in on this). I think what most people do is install an AAL 1.5" - 2" AAL or even a custom leaf pack from Wheelersoffroad.com.
  17. May 7, 2010 at 7:59 AM
    #77
    KPT
    KPT sees what you did there.
    09 Prerunner
    Correct, the only way to raise the back of your taco is with an AAL, new leaf pack, or a block.
  18. May 7, 2010 at 8:57 AM
    #78
    LeadFootCaliKid
    Blake
    Temecula/North SD
    If you're adding more travel to your suspension, wouldn't you need a longer shock that can travel that much?
  19. May 7, 2010 at 9:09 AM
    #79
    SoCalBlack08
    SoCalBlack08 Well-Known Member
    CA
    08 PreRunner DC
    wow im impressed! this thread is actually kinda working:woot:
  20. May 7, 2010 at 9:32 AM
    #80
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Ok so here's my stupid question, what maintenance am I overlooking?
    I bought my truck at 68,XXX mi and its at about 100,8XX mi right now. I was lagging, as for as maintenance goes, for a while. I changed the oil fairly regularly, brakes jobs, new tires/balancing, and greased UCA's and leaf springs in my shop classes. Less than 10,000 miles ago I had to have the diff. seal replaced so the diff fluid is new. Within the past couple months changed spark plugs and tranny fluid. I don't think I've done anything else. Recently I've been wanting to get it running better and start taking better care of it.
    What else do I need to get done? I have looked at the Toyota Standard Maintenance Chart and found a lot of things that I know I can't do; tightening body/frame screws, tightening propeller shaft, and coolant replacement... I'm going to The Truck Shop soon to get the 100,000mi service work done, but is that all I should worry about?
