The NorthStar AGM Battery + Voltage Booster Upgrade
Discussion in 'Technical Chat' started by crashnburn80, Apr 14, 2019.
  1. Nov 8, 2019 at 8:36 PM
    #281
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    The fact that I won’t google something for you isn’t proof against it. There’s plenty of reviews of NoCo tenders burning up. Take your reddit ‘any peer reviewed article’ nonsense elsewhere. I’m not here to daddy you, I’m telling you what I’ve read, used, and trust. Don’t like it? Mute me.
  2. Nov 8, 2019 at 8:39 PM
    #282
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    They’ll both tow my old Tacoma in :(
    NoCo is just the marginally more expensive Walmart brand. IP65 isn’t exactly cutting edge, either. I’ll trust the old stuff that every shop uses :hattip:
  3. Nov 8, 2019 at 9:07 PM
    #283
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    SR-71A, Beerpayzdabillz and Norton like this.
  4. Nov 9, 2019 at 5:57 AM
    #284
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    an·ec·dote
    /ˈanəkˌdōt/
    noun
    1. a short amusing or interesting story about a real incident or person.
    All I'm seeing is opinion, not anecdote.
  5. Nov 9, 2019 at 6:01 AM
    #285
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Of people burning them under their hoods or in their boats? Sorry, I’ll go get court filed papers. Or you can read stories online yourself. I’m glad they work for some folks, but it’s not for me. You all invested in NoCo to get so wildly but hurt about my opinion I’d rather have a real battery tender? Lol.
  6. Nov 9, 2019 at 6:07 AM
    #286
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I'm not butthurt, and I don't own anything from NOCO. I'm just pointing out that you said you were going to "raise [his] anecdotes with [your] own", but you gave no anecdotal evidence, only opinion.
    If you don't like tenders like what NOCO sells and are set in your opinions, why are you here, besides to start shit?
  7. Nov 9, 2019 at 6:16 AM
    #287
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Actually....
    an·ec·dote
    /ˈanəkˌdōt/
    Learn to pronounce
    noun
    plural noun: anecdotes
    2. an account regarded as unreliable or hearsay. <------------------- (ie. He provided anecdotal evidence)
    3. the depiction of a minor narrative incident in a painting.
    Norton likes this.
  8. Nov 9, 2019 at 6:36 AM
    #288
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    This isn’t a NoCo thread. Anecdotes form opinions. Multiple reviews I dug up prior to me deciding not to buy the tender (I have the jumper) led me to not buy one of those.
    And no, your attempt at failed journalistic prose doesn’t lead me to believe you’re shit posting yourself. Get real bud.
    Don’t correct him. He won’t stand for it until I post pics / links to reviews. LMGTFY.
  9. Nov 9, 2019 at 7:37 AM
    #289
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Some form of evidence to backup your statements would be good. I googled NOCO fire, battery tender fire, battery maintainer fire, battery charger fire, and trickle charger fire, and I found exactly zero links that mention a specific brand or model that was responsible for the fire. There are a number of reviews of devices not shutting off and boiling batteries dry, but no mention of them starting fires. All the reviews/news stories that mention a specific brand/model are positive.
    Rome604 and Norton like this.
  10. Nov 9, 2019 at 9:15 AM
    #290
    TrailYeti
    TrailYeti Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
    Great thread! Bought the Northstar battery and am now waiting on my adjustable voltage booster...which is currently stuck in customs, of course.
  11. Nov 10, 2019 at 9:55 AM
    #291
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    I’ve been reading the threads about AGMs in newer vehicles and and looking to clarify something. Having added a ham radio and compressor, and having the winch and front a rear lights installed this week, I figured it was time to upgrade to an AGM. An X2Power 27F is on order (I get commercial pricing from the battery place). I have a few questions:
    1. Has the TW hive mind figured out a good way to voltage boost the llatter model 3rd gens?
    2. If not, should I just install this replacing the stock battery and install the charging boost when it’s figured out?
    3. Should I do a 27F, or the smaller 24F? (Weight reduction)
    Thanks for any feedback.
  12. Nov 10, 2019 at 10:58 AM
    #292
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    1. Not yet. In theory if you found the wire feeding voltage to the ECU and added an inline fuse, you could then add the booster. But to my knowledge nobody has done that yet.
    2. Alternatively you can use an occasional wall charger to keep the AGM in peak performance.
    3. If I was to do it again based on my needs today I’d likely go with the 24F. I don’t have a winch, even if I did it wouldn’t be heavy use. And the 24F is plenty for my overnight camping needs.
  13. Nov 10, 2019 at 1:03 PM
    #293
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I’m curious as to how the boosted voltage from my alternator will affect the charge rate of my slide in camper via 7-blade trailer connection.
    Ideally when I’m on the road with my camper on the truck I don’t have the connecter plugged in, unless we are traveling at night to candle the running lights.
    Reason being that the solar charge controller on the camper boosts the voltage of the single AGM house battery in the camper to a float charge (using two 100-watt solar panels) opposed to the power coming from the 7-blade that only brings the 12v battery to a high charge of ~13.2v.
    Where the battery for the camper is located is less than ideal. Not a great place to have to stick your head and arms into to constantly connect / disconnect the house wiring while traveling.
  14. Nov 10, 2019 at 2:32 PM
    #294
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    I have a Deltron charger/tender, would that work? http://products.batterytender.com/Chargers/Battery-Tender.html
    I’m about to get a 27f but thinking now it’s just overkill and added weight. Don’t have a winch either, yet, or a ton of lights either so sticking with stock might be better?
  15. Nov 10, 2019 at 3:17 PM
    #295
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    And that extra weight makes Taco lean worse. If you have no need for the extra capacity, I’d go with the 24F.
    I’m not an expert on chargers, but keep in mind the goal of the external charger is to charge at a higher voltage than a flooded battery is capable of, which is why you need the charger in the first place. The higher voltage is to breakup sulfation on the AGM battery plates. So a charger should have an AGM setting, or be specific to AGM batteries. If it just ‘can charge both flooded and AGM’ but isn’t settable (which appears the case with the one you link) it is likely charging at a standard flooded rate of of ~14v. You can technically charge an AGM at 14v so their claim isn’t wrong, your truck is already doing that though so it doesn’t serve the purpose. You want to charge at a higher 14.5v-14.7v, which would not be good for a flooded battery, so it would need a separate setting or be AGM specific. Optima makes a line of chargers specifically to support AGMs, I’m sure others must as well. I haven’t spent much time looking into it since I run the voltage booster.
    Norton and TRD493[QUOTED] like this.
  16. Nov 10, 2019 at 5:28 PM
    #296
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    The battery terminal on the factory 7-pin comes straight from the battery through the 30A Batt Chg fuse, so boosting the alternator voltage to the starting battery will boost the charging voltage to the trailer plug.
  17. Nov 11, 2019 at 1:09 AM
    #297
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  18. Nov 11, 2019 at 6:49 AM
    #298
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have an older CTEK 3300, which use with my AGM batteries. It has never let me down. In fact, someone from Optima recommended it to me - before they had their own line of chargers.
    I think you will be happy with the CTEK charger, and it should fine for you.
    BenMara[QUOTED] and Norton like this.
  19. Nov 11, 2019 at 7:10 AM
    #299
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Cool idea. Got any pictures?
  20. Nov 11, 2019 at 7:52 AM
    #300
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1. I've run a CTEK MULTI US 7002 universal charger for years. Very versatile - a fully-automatic 8-step charging curve; desulphation function; low ripple; and dedicated AGM, Supply & Recondition modes, make it suitable for just about any 12V lead-acid battery. Designed for safety, it's protected from reverse-polarity connections and is short-circuit proof.
