The NorthStar AGM Battery + Voltage Booster Upgrade
Discussion in 'Technical Chat' started by crashnburn80, Apr 14, 2019.
  1. Jan 23, 2020 at 9:59 AM
    #441
    gnardoggie
    gnardoggie Well-Known Member
    Hey AGM gurus - I've got 188ah of AGM batteries in my truck, but I'm noticing that they are discharging pretty damn fast - for example this weekend I was running a 1.5amp warming mat for my dog and my dometic fridge and went from around 12.4v to 10.0v in a matter of a few hours. That seems extreme from my past experience. Could this be a battery health issue?
  2. Jan 23, 2020 at 10:35 AM
    #442
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    As an aside. Carrier pigeons fly an impressive 600-700 miles a day. Australia is 10,250 miles from Florida. Meaning if a pigeon averaged 650 miles a day, a carrier pigeon could theoretically make the trip in about 16 days. Aka, pigeons would be faster.
    That isn't right at all. Even if you had one bad battery, it would seem unlikely both would drain so low so quickly. How old are the batteries? Are you sure the fridge is in proper working order? If the compressor was failing or running continuously it may draw excessive power. I'd consider measuring the power draw of your gear to see if either is faulty and drawing excessive amperage. Crunching numbers in the past a single Northstar 27F should be able to sustain a fridge overnight for well over 12 hours. To drain two batteries in a few hours is extreme.
  3. Jan 23, 2020 at 10:58 AM
    #443
    NavyDiver72
    NavyDiver72 I DO ALL MY OWN STUNTS
    Rick
    Millington, TN
    2006 DCLB TRD Sport PreRunner
    Any Mods? One. Maybe two, tops...
    I would love to!! I just don't think a straight trade would be fair... isn't the adjustable one more expensive that the 0.5v one??
    Also, not an engineer, so... I haven't really taken any readings at all, I am just making assumptions that the data that you compiled at the beginning of this tread would work for me. All I'm using is the info I see on my SCANGAUGE II. To have a baseline what do you recommend I do, and how do I keep that data for reference. Not really technical guy...
    LOL! True engineer...
  4. Jan 23, 2020 at 11:42 AM
    #444
    gnardoggie
    I agree - seemed way off. The batteries are 1-2yr old with some use prior but nothing crazy. Fridge is working fine from what I can tell, and it has not been running continuously when on. I'm wondering if there's an issue somewhere in the wiring, but when the battery sits without anything running on it I'm not seeing any voltage drop at all.
    I'm going to run a test to see if there's maybe some reason why my solar setup could be leaking power via a poor connection or something. Generally an input wouldn't cause a faulty output but who knows.
  5. Jan 23, 2020 at 12:13 PM
    #445
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Ordered from HKB Electronics 1.6.20 received today 1.25.20
    Norton likes this.
  6. Jan 23, 2020 at 5:27 PM
    #446
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    That seems pretty like a pretty low powered warming blanket. Are you sure thats accurate?
    mac_2_nite and crashnburn80[OP] like this.
  7. Jan 23, 2020 at 6:27 PM
    #447
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Suggest checking your voltages before and after changing the fuse... i was having voltage problems, had to recheck the fuse... now it works as indicated...
  8. Jan 23, 2020 at 7:37 PM
    #448
    NudeLobster
    NudeLobster Well-Known Member
    Justin
    Tucson, AZ
    2006 Lexus GX470
    I have intermittent/unusual battery draw from time to time and I have been suspecting my Dometic. most recently I had the most extreme act yet, draining from 12.8 to 10v overnight while it was 35 degrees out. I've read reviews for the CFX on Amazon where people see crazy draw after a couple months age. It can be days, weeks, or even months between behavior. I am trying to rig up a current draw monitor and will probably be exchanging the fridge under the REI 1 year no questions return either way.
  9. Jan 23, 2020 at 7:43 PM
    #449
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The adjustable one is 2x the price. I'd rather have the fixed one for my case though, so it saves me buying one.
    Confirmed carrier pigeon is faster.
  10. Jan 23, 2020 at 8:32 PM
    #450
    gnardoggie
    yup
    https://www.gundogsupply.com/hound-warmer-deluxe-12-volt-dog-crate-mat-dog-heater.html
    Hm - this is super interesting. Has it only happened once? I'm also running a CFX...this would be a pretty similar symptom as the drain that I noticed over the week. Can you PM me where you saw this described on Amazon?
    crashnburn80[OP] likes this.
  11. Jan 24, 2020 at 11:15 AM
    #451
    NavyDiver72
    Rick
    Millington, TN
    So after going through this awesome tread from beginning to end for the 4th time already, I see that @TrailYeti and @SR-71A use ScanGaugeII and @Norton uses UltraGauge.
    What I need to do now is compare the voltage reading on my SGII for accuracy against the voltage reading directly from the Northstar 27F with my Fluke multi-meter, and see if there is a difference between the two readings. See if there is a small difference, a big difference, or none at all between readings, so I can have an accurate reference and "boost" appropriately, either with the 0.5v or the adjustable one - probably set to 0.6v.
    Like, I mentioned before a couple of posts before to @crashnburn80, on colder mornings (Florida cold, so 40F to 50F) the highest I have ever seen the voltage reading on my SGII is 14.0v, maybe once I saw 14.1v. So, to get on the sweet spot mentioned by OP, I think in my case I will definitely benefit better with the adjustable booster since it will put me on the "lower" end of the 14.6v to 14.8v range.
    So like @TrailYeti, @SR-71A, and @Norton, I can rely on an external gauge like SGII or UltraGauge? Correct?
    In the mean time, I will have to wait for the boosters to arrive from Oz. @crashnburn80 got me thinking that in my specific case the 0.5v booster might not be enough, because I have really low cold start voltage reading to begin with - I order 0.5v and adjustable boosters so I can experiment with both and see which one works best for my particular setup.
    Any thoughts or feedback?
    Thanks,
    Rick
  12. Jan 24, 2020 at 11:33 AM
    #452
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    As far as I know, neither the ScangaugeII or Ultragage are directly reading the system voltage. They are interpreting data on the OBDII data bus. So either one should be as accurate at the sensors the truck is using to read the voltage.
    SR-71A likes this.
  13. Jan 24, 2020 at 11:43 AM
    #453
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Got a link for that rocker switch housing? That's nice, tight fitting blank for the switches.
    Sna[QUOTED] likes this.
  14. Jan 24, 2020 at 12:14 PM
    #454
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Just these...nothing special.
  15. Jan 24, 2020 at 12:41 PM
    #455
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Thanks! :thumbsup:
  16. Jan 24, 2020 at 1:13 PM
    #456
    NavyDiver72
    Rick
    Millington, TN
    Well, I just want to see how accurate is the SGII reading compared with a direct reading from the battery posts using a Fluke multimeter. I don't think it would matter how the data is being displayed in the SGII as long as the reading is accurate.
    I'm sure that the SGII is reading the voltage at the port, but I think that there should not be a huge difference between a reading taken directly at the battery and the reading coming from the port.
    I'll check when I get home and see at the results.
  17. Jan 24, 2020 at 1:20 PM
    #457
    xxTacocaTxx
    Best Slope CO
    What I am saying is the devices don't do the reading. They don't have sensors. They don't read engine RPM, they don't read intake air temperature, they don't read engine oil or transimisison temperature directly. Sensors in the vehicle take a reading, just like a fluke connected to the battery. The various ECU modules in the vehicle interpret the value from the sensors, and send them via the OBDII data bus to other ECU modules. The Scangauge and Ultragauge capture data from the OBDII data bus, interpret the data, and display it on the screen.
  18. Jan 24, 2020 at 1:24 PM
    #458
    NavyDiver72
    Rick
    Millington, TN
    I understand, all I want to know is if I can use the data captured from the OBDII data bus to set the booster appropriately?
    TrailYeti likes this.
  19. Jan 24, 2020 at 1:28 PM
    #459
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I'd give it a couple days to settle out. When I first got mine I thought it was set too low but after a couple of days things seemed to even out so I just left it at the recommended setting.
  20. Jan 24, 2020 at 5:32 PM
    #460
    SR-71A
    Zack
    Southern Maine
    Being in a Southern climate Id think the fixed 0.5V would be fine for you. I wish I had gone for the adjustable one to be honest. Cold starts below about 35-40*F up here in the north give me 14.8-14.9V which seems on the high end. Thats as reported by my SGII, as you said I have no idea how accurate that might be.
