The NorthStar AGM Battery + Voltage Booster Upgrade
Discussion in 'Technical Chat' started by crashnburn80, Apr 14, 2019.
  1. Oct 28, 2022 at 8:49 PM
    #1101
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    FYI the booster that plugs into the fuse box WILL NOT WORK on a 3rd gen truck.
    the ECU flash works from a tune i here.
    crashnburn80[OP] and wi_taco like this.
  2. Oct 28, 2022 at 8:52 PM
    #1102
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    ^This is correct. 2015 and earlier only have the necessary alt-s fuse. 3rd gen needs to be done in an ECU flash.
    wi_taco likes this.
  3. Oct 28, 2022 at 8:54 PM
    #1103
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    D'oh! Of course you are correct, it's Friday and I forgot how simple addition works. Math is hard!
    Regarding the 0.5v booster I'll let you know but it will be a while before I part with it. MK4 going to take a while on that boat across the ocean. Don't you have a stockpile of every single version from your previous testing? I always picture your garage to look like the wardrobe to Narnia with endless lights & electro-gizmos as far as the eye can see.
    Double D'oh! Again you are right, I am wrong. Apparently my reading and maths comprehension are shot for the day. I'll edit my post then go crack a beer and stop typing before it turns to complete gibberish lol.
  4. Oct 28, 2022 at 9:22 PM
    #1104
    BlackRoan
    BlackRoan Well-Known Member
    2018 White TRD PRO
    Still working on it
    Which Noco would do the job best and most Efficient. Secondly how often would you think I should be charging to full capacity? 2-3 months?
  5. Oct 29, 2022 at 9:11 PM
    #1105
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Oh, it definitely is for lighting products and test gear and a lot of other vehicle parts. But I didn't hang onto the boosters.
    wi_taco[QUOTED] likes this.
  6. Nov 1, 2022 at 8:12 AM
    #1106
    scoomas
    scoomas Well-Known Member
    Scott
    2006 Silver Tacoma TRD/OR
    just the micro blade fuse replacement. Ordered back in June and got it in October
  7. Nov 1, 2022 at 11:02 PM
    #1107
    scleaf
    scleaf Well-Known Member
    Torrance, California. USA
    2013 Silver Tacoma TRD 4x4
    SaBellCo's Tailgate Lock :), Cable mod
    Revisiting my setup with the charge voltage and trickle voltage.
    Modified my current setup where I use a timer to switch in my diode for 30 minutes after I start the vehicle then cut the diode out to go to float charge voltage.
    Used one of these https://timers.shop/6V-28V-10-Amp-Timer-Wi-Fi-configurable-via-phone_p_44.html
    It has multiple functions you can use and handles multiple voltages and functions. I have to go back in and document my circuit, but you can certainly adjust the timing to reprogram with the app. Just have to turn off the ignition, short the programming pin and use the app to set the delay and function. I wanted something to monitor the voltage better and not always charge at 14.23v. so
    Here is my scenario
    Start my truck 14.23-14.37v for 30 minutes
    Cut out the diode 13.83v for the duration of my trip
    Turn off my truck resets the timer.
    Anyone have any scientific phenomena that tells me to charge longer or shorter :)
    After looking through this thread again I may make the timer more like 2 hours as that is the length of a frequent trip I take. and that would also cover me for the around town runs. so any longer trips would eventually cut the voltage to 13.8 after two hours of running.
    Now I remember I used two of the wires, one is high while the timer is engaged and then drops out, this is the one with a 3A diode on it, then when the timer drops out the regular voltage is pass through to the charge fuse and the diode blocks any voltage going back into the timer. My failsafe is if the timer messes up I always have the voltage pass through and if both mess up I get a battery light.
    6 gearT444E likes this.
  8. Nov 5, 2022 at 3:56 PM
    #1108
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Weird. 2nd NorthStar battery is to do in less than 10yrs... first one is dead before the end of the warranty, prorated then the current one is dead in less than 4yrs. Guess ill settle for a AGM from Costco.
    davidstacoma and Ridgewalker1 like this.
  9. Nov 5, 2022 at 4:01 PM
    #1109
    Ridgewalker1
    Ridgewalker1 Well-Known Member
    Philip
    Longmont, CO
    2003 Tacoma TRD OR, 2015 Tacoma TRD OR
    2003 1 5/8” lift, 235-85r16 BFG KO2, ARB Bull Bar, Warn M8000, sliders, Snugtop; 2015 Hefty Fab al bumper and sliders, Warn Zeon 10k, Rago bed stiffeners,
    That’s not encouraging!
  10. Nov 5, 2022 at 4:53 PM
    #1110
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Technically that was my 3rd that died. The 2nd one is in my current daily driver. It was in my FZJ80 previously. SOLD the TLC, replaced with flooded battery. The daily driver is a Mits Evo X. Knock on wood it's still going well..... But I totally charged it at a different voltage... than what the Taco set it at... I have the same HBK Voltage booster in my Evo X but it bumped it to a higher voltage. Then the one in the Taco.... I dunno what's going on...
    Ridgewalker1[QUOTED] likes this.
  11. Nov 5, 2022 at 6:11 PM
    #1111
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That’s a major disappointment.
    Norton likes this.
  12. Nov 6, 2022 at 12:25 AM
    #1112
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Agreed, but it differs from my and my son's experience with our Northstar batteries. My 27F is still running strong, almost six years since I installed it and his 24F also remains solid at (as I recall) about five years since he installed it.
  13. Nov 6, 2022 at 10:22 PM
    #1113
    scleaf
    Does anyone monitor their voltage over a few days when parked? I installed a LVD on one of my batteries but seems like my batteries are not holding 13v when off. Not sure what the discharge is when no load should be but feels like the LVD may be draining draining the batteries over time. Also I am going to adjust my charge voltage to be for 2 hours after an engine start or maybe 4 hours, but unless I take a longer trip it will no ever hit the limit. Since I used my winch to pull out some trees this weekend I need more charging. Possibly going to hook up a small solar panel to maintain the batteries better. Or install a charger on the truck so when it is sitting for a few days I get a full charge in the driveway.
    Had one fail after a year but more my fault because I was running a small computer with a stereo camera installed. (experimental or just mental)
    Ridgewalker1 likes this.
  14. Nov 15, 2022 at 12:47 AM
    #1114
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Costco didnt have any AGM batteries.... Ended up with regular flooded acid...:(
  15. Nov 26, 2022 at 11:03 AM
    #1115
    BlueCollarNerd
    BlueCollarNerd Member
    Maine
    2015 TRD OR
    Has anyone had issues ordering through HKBs website?
    When I try to check out it says paypal is currently unavailable try another method. I don't see any other way to pay or input a credit card number. I'm new to paypal but know I'm logged in on this device and have allowed cookies and such for their website thinking it was an issue with that, but I'm still unsuccessful.
    I tried last night via mobile and then again today on my laptop. Also sent them an email and waiting for a reply.
  16. Dec 3, 2022 at 4:38 PM
    #1116
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Posted in my 1st Gen thread, but thought I’d share here too. Picked up the X2Power Northstar 24F today and installed the HKB +0.5v voltage booster in my 1st Gen.
    Booster swapped into the Alt-S circuit
    This has been on my to-do list ever since picking up the 1st Gen this summer. I googled for a Batteries Plus coupon and found AUTO10 to get $40 off the battery with buy online and pickup in store.
    I had the same issue. Couldn’t get it figured out, so I ordered off of eBay instead and payment went right through.
    Boosters are back in stock:
    https://www.ebay.com/itm/3226507128...JW2BIbGQi6&var=&widget_ver=artemis&media=COPY
    Green Jeans and wi_taco like this.
  17. Dec 4, 2022 at 7:45 AM
    #1117
    BlueCollarNerd
    Maine
    2015 TRD OR
  18. Dec 6, 2022 at 10:28 PM
    #1118
    Dusty T.
    Dusty T. Well-Known Member
    Portland, OR
    2002 Tacoma 4x4 TRD; 2003 Honda Element
    Has anyone used the MK4 unit with a CS144 alternator and if so, wondering if it works with the sense-ignition-lamp harness adapter needed to make the 4-pin CS144 compatible with the 3-pin Toyota harness? https://store.alternatorparts.com/w...cs-style-plug-to-toyotal-oval-style-plug.aspx
    With the CS144 I typically see between 14.0 and 14.3 volts with the engine on (depending on outdoor temps) and a resting voltage of 12.6 volts on both the main and aux battery- both are AGM. Certainly better than the upper 13 volts some are reporting, so maybe it's not needed for my setup?
  19. Dec 6, 2022 at 11:33 PM
    #1119
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The alternator nor adapter help. You need 14.4-14.8 runtime voltage per Northstar specs. You are 0.5v low, which is exactly what the +0.5v booster is designed to correct.
  20. Dec 7, 2022 at 6:12 AM
    #1120
    Dusty T.
    Portland, OR
    Understood, I just don't know how the adapter is wired which allows the GM CS144 (4-pin/wire) to be compatible with the Toyota charging system (3-pin/wire) configuration. I'd assume the fused "sense" circuit still performs the same regardless and the MK4 would not cause any issues though it'd be nice to know if anyone with the CS144 alternator has tried this. Most everyone in this thread seem to have a completely stock charging configuration.
