The NorthStar AGM Battery + Voltage Booster Upgrade
Discussion in 'Technical Chat' started by crashnburn80, Apr 14, 2019.
  1. May 25, 2019 at 12:59 AM
    #141
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    For 3rd Gen, I'd put money the diode would go at the "10A ECU-B No. 3" fuse going to the Combination Meter- it's sensed there and communicated to the ECU along CAN.
  2. May 25, 2019 at 5:16 AM
    #142
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    There's no need for a fuse on a sense line. It's not providing any power. It's just being used to read the voltage output of the alternator, so current draw should be almost nothing.
    Why they put a 7.5A fuse on the 2nd gen alternator sense line makes no sense, especially when guys are putting 1A rated diodes in its place without issue.
    It's a possibility, but I was basing my guess on info from my WRX which is similar to the 3rd gens because it doesn't have a labelled alt sense line. There's a line that goes from the alternator straight to the ECM. If you depin it, the alternator runs full blast all the time.
    05Taco4x4[QUOTED] likes this.
  3. May 25, 2019 at 6:33 AM
    #143
    gnardoggie
    gnardoggie Well-Known Member
    If I have a standard car battery as my main and an AGM for my aux do you think upping the charging voltage for both will cause an issue? They are linked via smart isolator.
  4. May 25, 2019 at 6:46 AM
    #144
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    The higher voltage would likely cook your main battery. You'd be better off running a DC-DC charger to increase the voltage to charge the AGM.
    VE7OSR and Norton like this.
  5. May 25, 2019 at 8:58 AM
    #145
    gnardoggie
    Or just spend the same amount and double down on AGM :)
    doublethebass, VE7OSR, Norton and 3 others like this.
  6. May 25, 2019 at 11:03 AM
    #146
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Just ordered the fixed voltage booster, thanks for the info.
    whatstcp and crashnburn80[OP] like this.
  7. May 26, 2019 at 4:31 PM
    #147
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    This.
    Wiring two different types of batteries together will not work properly.
    Norton and crashnburn80[OP] like this.
  8. May 26, 2019 at 6:24 PM
    #148
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I added an arrow to the line i'll interrupt once i receive the "booster".
    Personally, I would be weary of removing the 10A fuse and replacing it with the booster which isn't capable of handling that much amperage since that particular ECU-b No. 3 circuit appears to be connected to the a battery source. Do you know how much amperage is getting pulled through there? I have no clue so I can't say.
  9. May 26, 2019 at 7:07 PM
    #149
    05Taco4x4
    2TR-FE Enthusiast
    Exactly, and since this scenario is COMPLETELY different than the ALT-S wire scenario I would DEFINITELY keep the fuse and actually consider the $50 Fuse/Diode from OZ.
  10. May 26, 2019 at 7:12 PM
    #150
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Awaiting your results for sure....
  11. May 26, 2019 at 11:46 PM
    #151
    gnardoggie
    Actually from my research that’s only really true if you wire them in parallel for use. Having and AGM and “regular” battery to charge via a smart isolator doesn’t impact a ton (they disconnect when the truck is off and the aux battery is being depleted). If they were wired in parallel for long term regular use, then your statement is accurate.
  12. May 27, 2019 at 5:29 AM
    #152
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    True. However, it's still not a good idea. The AGM will always be undercharged if you run the correct lead-acid charging voltage, which will shorten the life of the AGM. If you run the proper voltage to charge the AGM, the lead-acid battery will always be overcharged, which will kill it.
    Either way you're better off running the proper voltage to each battery.
    Norton likes this.
  13. May 27, 2019 at 11:53 AM
    #153
    gnardoggie
    Also true, but there is a difference between a deep cycle charge and a float charge. My fridge use would put me more on the float side, so I think I'm good with a regular charging voltage of 13.6 while driving. If I were to be using the AGM for deep cycle use it might be a different situation.
  14. May 27, 2019 at 1:53 PM
    #154
    Scott B.
    Scott
    Georgia
    That is what I intended to say, even though I did not articulate it.
    Given the original post, he did not mention using an isolator, so I assumed he would be using a combiner such as a Blue Sea ACR.
    Certainly, wired separately with a DC-DC charger, you can use any type of battery with any other type of battery.
    For the record, I am running an Odyssey as my starting battery, with the diode from OZ to increase the charge voltage. My second (house) battery is also an Odyssey, running off of a CTEK DC-DC charger - with the higher charge voltage.
    Both of my batteries are the same model, so that in the rare event that the starting battery croaks, I can physically replace it with the house battery, and be on my way.
  15. May 29, 2019 at 12:12 PM
    #155
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Did you get the booster yet? Curious to see if it's a solution for us 3rd gen guys.
  16. May 29, 2019 at 5:43 PM
    #156
    SC4333
    Grant
    FL
    Nope. It's coming from Australia, so the shipping is rather slow. Wasn't a cheap date, either.. $102 by the time it gets to my door :(
  17. May 29, 2019 at 9:07 PM
    #157
    ihatemytruck
    Dave
    Southern California
    Not cheap at all! Well keep us posted please.
  18. May 30, 2019 at 10:58 AM
    #158
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Have been working with Northstar to warranty a 24F AGM and the guy I've been speaking with recommended the MK3 as Toyotas are notoriously low voltage for AGMs. Funny that I find this thread right afterwords...
  19. May 30, 2019 at 11:38 AM
    #159
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, same thing the NorthStar rep mentioned to me as well about Toyota’s being notorious for low voltage, even before I mentioned I was doing this for a Toyota.
    FastEddy59 and Norton like this.
  20. May 30, 2019 at 11:45 AM
    #160
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Even with the MK3, I feel like I'd be a little low. I'm sitting right around 14V at 1500 RPM idle, so adding .5V would get closer but still seems a bit low. I guess better to be 14.5 than 14.0 though.
