The nothing wrong with my truck thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by offrdmania, Jan 7, 2014.
  1. Jan 7, 2014 at 7:51 AM
    offrdmania
    offrdmania [OP] Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    I read these posts all day long of CEL demons, rusted frames, broken cv's, misfires, burned out bulbs, etc, etc and I am thankful that I havent had a single issue with my truck since I bought it. I drive it, I maintain it and I drive it some more. knock on wood that it continues. Anyone else in the same boat as I? Post up.. :D
  2. Jan 7, 2014 at 7:52 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Negative.
  3. Jan 7, 2014 at 7:53 AM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    now you will :)
  4. Jan 7, 2014 at 7:55 AM
    offrdmania
    Templeton, Ca
    I think im good for now. It is a well maintained truck, no rust and I am the second owner. The first owner had all maint. done at the dealer up until it was sold to me.
  5. Jan 7, 2014 at 8:00 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I think that a majority of ppl here have little wrong with their truck. It seems that there are a lot of issues on these forums but that's just because you only post on a "help" forum if your truck is g2g. Until now that is....
  6. Jan 7, 2014 at 8:01 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Hmmm... I had to replace my ignitors, an alternator, a wheel bearing and a P/S pump hose on mine but I consider those to be consumables. Everything else has been modding stuff.
  7. Jan 7, 2014 at 8:02 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    You also see that most vehicles that have problems are those that are modified.
    All of my "issues" with my truck are because of how I drive the truck. Mine is more or less maintenance than something wrong though as I can still drive my truck just fine.
  8. Jan 7, 2014 at 8:05 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Mine was that way for about 10yrs. Then a brake caliper froze up, u joints, the rear leafs are shot, the rack needs replaced, lower A-frame bushings are squeaking. About time for front end overhaual i guess. :(
  9. Jan 7, 2014 at 8:06 AM
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    33,000 and still very fine, including my local dealersip
  10. Jan 7, 2014 at 8:08 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I put 275k on my '98. Not one single check engine light the entire time. The frame on the other hand rotted out from under it. Still way happy.
    I tail light assembly-broke it myself, so I'm not counting that.
  11. Jan 7, 2014 at 8:26 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Nope. I beat the shit out of my truck and it's showing. I have a nice litte list of problems
  12. Jan 7, 2014 at 10:35 AM
    offrdmania
    Templeton, Ca
    Im not talking about normal wear and tear items. My truck is also bone stock so I think that has a lot to do with its reliability.
  13. Jan 7, 2014 at 11:06 AM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    My truck is finally golden. Im basically done, until something breaks.
    New wheel bearings.
    New axle bearings
    New seals
    *perfect* rust free frame, sealed with rhino-liner.
    Rebuilt/balanced drive shaft
    Rebuilt CV axles
    New Upper control arms and UBJ's
    New lower control arm bushings & LBJ's
    Engine in fantastic shape, w/ new timing belt @120k, and new accessory belts
    New plugs/wires/coils
    New PCV/IAC/TPS valves/sensors
    All fluids swapped over to amsoil
    New steering rack
    New inner/outer tie rods
    New suspension (ome), with new Dakar leafs
    Shimmed rear axle for correct driveline geometry
    New rear brakes (turned drums, fresh shoes)
    New front brakes (brembo blank rotors, rebuilt calipers, PBR xbg pads)
    Stainless braided brake hoses
    Brand new Hankook dynapro ATm tires
    Replaced all the old stuff, and it rides/performs great.
    The only real thing that can happen now, is a random fluke, like a wrist pin giving up, the tranny loosing a tooth and then eating it, or a random bearing dieing.
    But as it stands, my truck is fan-freaking-tastic. Dealerships always try to coax me into trading it in, but I always laugh and tell them my 1st gen is built better.
  14. Jan 7, 2014 at 11:11 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    I'm really surprised I have 230k on things like the alternator, starter, radiator. All things I have replaced were worn out at a reasonable mileage or my own fault for buying shit autozone parts( no longer). It's a really impressively durable truck.
  15. Jan 7, 2014 at 11:16 AM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    No problems in my 11 with 50k, my 09 with 35k had a handful, but I was able to live with em
  16. Jan 7, 2014 at 11:17 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    apart from the leaky valve gasket, i'm golden!
  17. Jan 7, 2014 at 11:30 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Not everyone is the original owner either, so some of the problems we are having are from previous owner neglect/mods.
  18. Jan 7, 2014 at 11:42 AM
    offrdmania
    Templeton, Ca
    I really do think that a lot of the issues posted on this site come from previous owner neglect. I was lucky enough to get a truck with an immaculate service history
  19. Jan 7, 2014 at 11:56 AM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    well for the amount of things my truck has been through id say its pretty reliable.. I've been in 6x accidents and I'm just starting to get it to run smooth again finally.. probably paid close to as much in maintenance (including oil, brake pads etc) and fixing things as i did for the truck itself. my truck had 155k miles when i got a valve job. has 168k now.
  20. Jan 7, 2014 at 11:57 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Agreed...like looking at product reviews for things. For every negative review, there's bunches of people with zero problems that don't post positive reviews (in general).
    And, there is nothing wrong with my truck now either...other than the axle shims I had put in still weren't enough angle to be correct. Fixed that with a few washers to drop the carrier bearing a little. And that's not even really a problem...it's a side effect of a user mod (the lift).
