The *Official Photography Thread*
Discussion in 'Photography' started by THXEY, Nov 30, 2010.
  1. Apr 13, 2013 at 9:12 AM
    #9381
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Uh, it might help if I click and go to Youtube and read the description, but what is it?
  2. Apr 13, 2013 at 10:06 AM
    #9382
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    http://www.pmgadgets.net/product_info.php?cPath=51&products_id=77
    "The PatchMaster 4in1 Trigger is an extremely sensitive device to detect lightning events designed to help photographers to take lightning photos during day or night. The device has been designed based on microcontroller technology and has a response (lag) time in microseconds level. This is more than enough to capture the lightning events."
    "The PatchMaster 4in1 Trigger is an extremely sensitive device to detect sudden sound events such as breaking glasses, popping balloons, exploiding items etc. Sensitivity can be adjusted from 1 to 999. You can also set the “delay” parameter between 0 and 1000ms. So your camera can be triggered with a delay after sound event is detected. "Single" and "Continuous" modes are avaliable to decide if your camera will need to be triggered for each detected sound or need to be triggered just after the first detected sound."
    The PatchMaster 4in1 Trigger is an extremely sensitive device to detect events that breaks the laser beam. Device can be used to take water droplet photos or anything which passes in front of it. You can also set the “delay” parameter between 0 and 1000ms. So your camera can be triggered with a delay after breaking the laser beam."
    The PatchMaster 4in1 Trigger can be used for timelapse photography as well. You can set both the interval and exposure from 1 sec to 1 hour. You can also set the limit of photo you want to take. "
    • Extremely sensitive optical sensor to detect lightning events
    • Response (lag) time in milliseconds level
    • Sensitivity adjustment for Lightning and Sound modes
    • “Delay function” for Sound and Laser modes
    • "Single" and "Continuous" mode selection for Sound mode
    • 1 sec to 1 hour selection range for both interval and exposure in Timelapse mode
    • User friendly menu with color LCD screen
    • Optical isolated output to fully protect your camera from any potential harms
    • Hot shoe mount for mounting the device directly to your camera
    • Microcontroller-based design
    • 2 outputs for triggering either your camera or external flash"
    http://www.pmgadgets.net/videos.php
  3. Apr 13, 2013 at 11:05 AM
    #9383
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    damn! looks awesome!
  4. Apr 13, 2013 at 11:14 AM
    #9384
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i know right!
    will reduce my wasted photos during storms...plus the added feature of a time lapse is nice too
  5. Apr 13, 2013 at 11:38 AM
    #9385
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea and its pretty cheap..
    i think ill get one with my camera this summer. Its a good way for time lapse and other stuff
  6. Apr 13, 2013 at 2:27 PM
    #9386
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    good read. here is what I was hoping to try to tell you, in a picture format(grabbed from your link):
    basically, after 1/250s, your shutter gets in the way of exposure. what was noted in the article, was that they were using radiopopper triggers which enable the user high speed sync.
    with the camera's high speed sync speed, as noted above, the limitations are at 1/250s. the action is, the flash goes off when the shutter button is depressed so there is a little lag time for flash peak power.
    with using radio triggers(pick your brand, radiopoppers, pocketwizards, etc), the flash is fired before the shutter opens, so peak power is present when the shutter is opened. (each speedlight/monolight/strobe have different durations)
    it's still a little complicated for me(I've messed with it, but haven't used it too much), but it is great for capturing action shots and for capturing thin dof shots in the bright daylight.
    does that help explain it a bit?
  7. Apr 13, 2013 at 3:43 PM
    #9387
    Banff2007Tacoma
    Banff2007Tacoma Well-Known Member
    Dave
    Alberta
    2007 Tacoma Black Sand Pearl TRD Offroad.
    GPS Navigation System, Old Man Emu complete lift with Dakar springs. Light Racing UCA's. BFG AT tires, KMC Enduro rims, Allpro E-locker guard. ARB Portable Air Compressor CKMP12. Backflip Tonneau Cover. Wet Okole seat covers.
    So I am very much a beginner at this but I am hoping this summer I will take more time to learn more about my camera and know how to take better shots. I have a Nikon D7000 because I lost my D70. Okay I left it in a cab when I got back from Miami:eek:. Any how hopefully I will learn from reading more of this thread. Here are some of my favorite shots from past trips and feel free to help me out with suggestions. Thanks.
  8. Apr 13, 2013 at 3:47 PM
    #9388
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Nice shots, but from my amateur opinion, I think you need to work your angles more. Lots of these are dead on shots.
    Take your hallway picture. You could have made it much more ominous feeling if took it from lower and off to the side more to give the feeling of it being larger and less forgiving. Also it seems a little over exposed.
  9. Apr 13, 2013 at 6:46 PM
    #9389
    6spd
    san diego
    2023 4x4
    the statement is correct.
    However, shooting at a fast shutter speed than 1/250s, you will not capture the timing of when the flash will have peak light output if you do not have any triggers that allow higher sync speeds than 1/250s. ultimately, the flash will fire before the shutter opens(this can be adjusted via the firmware/software I believe) so when the shutter is open you get optimal flash exposure.
    yes, the x100/s has the ND filter feature built in(which I believe just compensate for the overall exposure, I could be wrong), but also Zack is using OCF to control the exposure of his subject, and in this case using some type of trigger to perform high speed sync.
    to achieve what you want(properly exposed subject with a thin DOF), you would need to install neutral density filter/s on your lens, open to max aperture, and set your flash power accordingly. this is not a set it and forget setting, but more of a feeling out process. you could get away with ND filters and using your flash, but once you get into higher shutter speeds(faster than 1/250s <-- the fastest rate foryour d300, and generally most dslr's), then you would have to invest in some radio triggers that are high/hyper speed capable.
    pocketwizard mini tt1 and tt5
    radiopopper px system
    zack arias is definitely flexing the muscles of the x100s in that instagram link you posted though
    (sheesh, so much editing of this post)
    edit: more links on high speed sync
    http://pixsylated.com/blog/smashing-pumpkins-with-high-speed-sync-gang-light-part-2/
    http://www.prophotonut.com/2009/08/17/high-speed-sync-with-the-new-pws-pictures-and-technique/
  10. Apr 13, 2013 at 6:53 PM
    #9390
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Nice I can learn from this thread! Sub'ed. I have a Cannon Rebel T3i and only a kit lens.
  11. Apr 13, 2013 at 7:50 PM
    #9391
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Some okay pics I took with the iphone 5...
    I really want a Nikon 5100! Haha
  12. Apr 13, 2013 at 8:18 PM
    #9392
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
  13. Apr 13, 2013 at 8:19 PM
    #9393
    PcBuilder14
    Brent
    Nor Cal
    I'm assuming that's a bad "wow"... :eek:
  14. Apr 13, 2013 at 9:55 PM
    #9394
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Nice, man! Keep shooting with that for practice and you'll be ready for that DSLR. Turn on the grid lines if you want to cheat with learning rule of thirds for a bit ha.
    I just switched to the i5 and I'm a big advocate of Android. I have to say, I'm still most likely going back to Android after this phone . . . but the camera is definitely what I use the most!
  15. Apr 13, 2013 at 10:01 PM
    #9395
    PcBuilder14
    Brent
    Nor Cal
    Thanks! Yeah, I just took those pics real quick. I usually try to use the grid to line my pics up prefectly...
    I had an android before this and wanted another one. But at the time the Galaxy S3 was the newest one and it had already been out for a while, so I went with the iphone. My mom bought an S3 and I compared the cameras and the iphone does better with overall and on pictures with a lot of light, but the S3 does better in low-light conditions.
  16. Apr 13, 2013 at 10:04 PM
    #9396
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    s4 is out soon :D but don't want to derail this thread with phone banter ha
    You learning yourself up on photography skills before you even get a DSLR? You can easily start now, and when the limits of your phone are holding you back and you finally get a D5100 or whatever it'll be a great relief to have more to learn and grow into again ha
  17. Apr 13, 2013 at 10:16 PM
    #9397
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Also with iPhone 5:
  18. Apr 14, 2013 at 4:30 AM
    #9398
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    I like the location... overcast,the trees, nice reflective water, beaten trail... it's a sweet location
  19. Apr 14, 2013 at 11:02 AM
    #9399
    6spd
    san diego
    2023 4x4
    I wrote a big ass post with my experience, but did not compute so here are some links that I have found regarding high speed sync. high speed sync is basically a factor when you remove your external flash from your camera. since you have yours attached, and are using super fast shutter speeds, this is not an issue. your methods are just affecting overall exposure. that said, I think you can find a more creative way, with what you have already, to make that shot the way you want it(remove your external flash and use CLS. the d300 supports this ;))
    anyway, here are some links supporting what I was saying earlier, but is clearly not what you are experiencing since your flash is ATTACHED to your camera. :eek:
    http://www.flickr.com/groups/nikon_d300_users/discuss/72157614072985740/
    http://nikonrumors.com/forum/topic.php?id=5071
    http://darrellyoung.blogspot.com/2011/10/understanding-your-nikons-flash-sync.html
    edit: I normally dont shoot with a flash or OCF normally, which is why I'm a little rusty on this subject
  20. Apr 14, 2013 at 2:07 PM
    #9400
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
