The *Official Photography Thread*
Discussion in 'Photography' started by THXEY, Nov 30, 2010.
  1. Jan 18, 2014 at 7:31 PM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    If your camera has Auto-Exposure (AE) lock, you can hold that button after metering to lock the exposure and recompose. Otherwise you can switch to manual and dial in the exposure from the spot metering.
  2. Jan 18, 2014 at 7:34 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Ooooh, I'll have to look into that. Probably won't work for quick-moving birds, but usually I use center-weighted metering for birds. I don't know, I'll have to play around with it some more.
  3. Jan 18, 2014 at 7:40 PM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    That little slider? That's exposure compensation and the camera will adjust the exposure settings to match what you've selected. Once the camera has determined the exposure settings (shutter speed/aperture/ISO), you can lock it down by holding the AE lock button, then when you press the shutter release the camera uses the locked exposure setting instead of metering again with the new scene.
  4. Jan 18, 2014 at 7:54 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    leftover from the weekly challenge. Had some fun stomping around the sage today shooting here. At the old Carissa gold mine near South Pass City, WY.
    14 by sconniehailer, on Flickr
    13 by sconniehailer, on Flickr
  5. Jan 18, 2014 at 8:40 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Can you not set your camera to meter the same as focusing? By that I mean meter and focus at half press and then recompose and release the shutter with a full press.
  6. Jan 18, 2014 at 9:10 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    That works for me with focusing only. Yeah I've tried that a few times with metering. Of course, maybe I did it wrong or something, so I'll give it another shot, but I'm pretty sure that doesn't work for me. I do it all the time with the focus, though.
  7. Jan 18, 2014 at 9:11 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
  8. Jan 18, 2014 at 9:48 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Took this yesterday in a coffee shop near my apartment.
    DSC_3115.jpg by AdelphosChaz, on Flickr
    D7100
    35mm f/1.8G
    100
    1.8
    1/125
  9. Jan 18, 2014 at 10:04 PM
    SconnieHailer
    Marc
    great stuff guys :)
  10. Jan 19, 2014 at 5:30 AM
    medic2230
    Murph
    Bama! Roll Tide
    Nikon's 3D matrix metering will use active focus point for metering. If the focus point is in the shadows it will lighten the scene on a landscape if in the sunny part it will darken the scene.
    From an article on Digital Camera World:
    The spot metering region is linked to the autofocus area on most Nikons, so make sure you’ve selected the single-area AF mode. Now select the AF area using the four-way selector on the back of the camera. It should match the area of the subject you want to be in focus.
  11. Jan 19, 2014 at 6:15 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Thanks, I thought the matrix metering took from several points and averaged it or something along those lines. Now I know.
  12. Jan 19, 2014 at 6:18 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Question then. If I leave it on single, center AF point for auto focusing, half press, than recompose and shoot. Did it still meter from that center point when it was focusing on my subject, or is it going to start metering the background when I recompose? I haven't had an issue yet so I assumed it was metering and focusing on the half press and then I was good to recompose.
  13. Jan 19, 2014 at 8:25 AM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    I believe if you recompose while pressing the shutter button halfway down, the metering and wb wont change until you release the shutter button
  14. Jan 19, 2014 at 9:42 AM
    medic2230
    Murph
    Bama! Roll Tide
    I believe this is true too. I haven't had a problem with mine changing. If you do you can always use the AE lock button on the back of the camera.
  15. Jan 19, 2014 at 9:46 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Just tested it out. Focusing is liked at half press but metering seems to change after I recompose. I'll play with it more between homework.
    I use the AE-L/AF-L button but it gets old using it a majority of the time ha not lazy just saying it would be convenient to be able to have that be the default at half press.
  16. Jan 19, 2014 at 10:32 AM
    medic2230
    Murph
    Bama! Roll Tide
    Some people set the AE-L/AF-L button to the AF-ON mode. That seems like it would be a pain in the ass too. That's where the camera will only focus when AF-ON button is pressed and a half press of the shutter button just turns on the metering. I never really got the point of that. I know the flagship cameras have that but why?
  17. Jan 19, 2014 at 10:33 AM
    DougDeBonet
    DougDeBonet Well-Known Member
    Doug
    Long Island, NY
    2014 TRD Off Road
  18. Jan 19, 2014 at 11:00 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I've read of people shooting that way as well but I see no reason to unless you're not trusting your cameras AF or something ha I'm sure there is a perfectly rational and good reason for it. I just don't know what it is.
  19. Jan 19, 2014 at 1:36 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Extras from the weekly challenge:
    The social sciences building (described more in my entry post in the challenge thread):
    The top of the tower in my entry:
    IMG_8221_edited_small by 92shawman, on Flickr
    IMG_8215_edited_small by 92shawman, on Flickr
    The maze of the inner halls:
    IMG_8212_blend_edited_small by 92shawman, on Flickr
    From the bottom level:
    IMG_8187_blend_edited_small by 92shawman, on Flickr
    An extra, was debating putting entering this one instead but I like the weird architecture of the death star so much more. Dutton Hall:
    IMG_8174_edited_small by 92shawman, on Flickr
  20. Jan 19, 2014 at 1:40 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Pretty random on the third pic ha I like it. Nice shots.
