The *Official Photography Thread*
Discussion in 'Photography' started by THXEY, Nov 30, 2010.
  1. Feb 9, 2014 at 9:54 PM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Leftover from the weekly challenge. A drop of grenadine into a pool of milk, stopped by a short pulse of light from a flash at 1/32 power.
  2. Feb 9, 2014 at 11:01 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Damn it! Just found a bird picture I should've used for symmetry...it wasn't taken for the challenge, but it has some good symmetry in the bird's body shape and positioning in the frame. I'll post it here later.
  3. Feb 10, 2014 at 6:16 AM
    medic2230
    Murph
    Bama! Roll Tide
    I've been wanting to try doing this for a while now. Did you use a drip set to do it or any of the timing devices? What was your set up like, such as backdrop and all?
  4. Feb 10, 2014 at 6:40 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    My setup was pretty simple other than a wireless flash trigger. I didn't use a drip set or any timing device and actually I was surprised at how bright the room could be, which was good because otherwise I couldn't see what I was doing. For the "dropper", I just repurposed an old travel size contact lens solution bottle. I had to create a foam seal for it though, otherwise the liquid just came out in a steady stream. Then it was just pre-focusing the camera, try to get the drops in a specific area, and guessing at the timing for when to release the shutter.
    Here's a pretty good tutorial on a basic setup, and the embedded video has tips on how to change the "color" and look of the photo. I'll probably give this a shot this weekend if I have time:
    http://strobist.blogspot.com/2009/05/how-to-photograph-water-drops-with-one.html
    It suggests using an off-camera flash, but I don't see why an on-camera unit won't work as long as you direct the flash beam to bounce off the background.
  5. Feb 10, 2014 at 8:19 AM
    medic2230
    Murph
    Bama! Roll Tide
    That's pretty cool. The setups I had seen they used 2 strobes to eliminate the shadows. Some even used a diffusion material on the sides to soften the light.
    I guess they suggest off camera to deal with the shadows. You could use something white opposite the flash to reflect light back also.
  6. Feb 10, 2014 at 8:27 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    Yeah, I took the pic before watching that tutorial video so now I have new things I want to try for next time. I do have another flash that I can use off-camera so I can try that also.
  7. Feb 10, 2014 at 3:19 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    awesome
  8. Feb 10, 2014 at 6:33 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  9. Feb 10, 2014 at 10:13 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Challenge is for current pics. Must be taken after the challenge is issued Monday.
  10. Feb 10, 2014 at 10:18 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    No, I know. I took it on Sunday before the symmetry challenge ended, but was just taking photos of birds, not actually challenging myself to take a photo of symmetry, if you get what I mean. I like to set up and take a photo specifically for the challenge, and this bird one wasn't, so I didn't even think of using it until after I submitted my other photo. It actually isn't the best for symmetry anyways, but whatever, the red-tail's wings are symmetrical. I s'pose I could have cropped it in a bit to make it better...but here it is without any cropping:
    Red-tailed Hawk by 92shawman, on Flickr
  11. Feb 10, 2014 at 10:27 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
  12. Feb 11, 2014 at 1:57 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    sooo..... Just got lightroom installed. what settings do you guys use to export your pics//where do you guys usually export to?
    I'm playing with it but my export to hard drive pics look like shit, so im doing something wrong. lol
  13. Feb 11, 2014 at 7:03 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    What specifically is lacking in the exported image? Dull colors, not very sharp, lack of contrast? Exported images should look the same way that they do in Lightroom so if they look bad then it probably needs some additional post-processing.
    When I export as jpeg, I set the quality to 80. There's a section in the export dialog about sharpening that by default is set to None. I set that to Screen (Sharpen for screen), and set the amount to High. It makes a huge difference if you're downsizing the image.
  14. Feb 11, 2014 at 8:12 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Get a Flickr account.
    Then use the Flickr app in light room to export. It'll do all the work mostly for you. And save your hard drive space so you won't have multiple copies of the same thing. As LR is non destructive it doesn't actually alter the RAW file.
    If you want stuff to go to your hd. You'll just have to pick depending in what you need.
    Tiff will have the highest quality with no compression selected. Jpeg will look good at highest quality setting. Wouldn't use any other formats really.
    Size wise..take your pick
    I use sRGB
    then you can make your own water mark too that'll get added.
    But the easiest way is just use Flickr.
  15. Feb 11, 2014 at 8:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I keep the quality at 100 and also do sharpen for screen. But not at high. Can't remember what it's at.
  16. Feb 11, 2014 at 9:27 AM
    jeremy1ns
    jeremy1ns Gamecock Tacos
    Jeremy
    Greenwood, SC
    2010 TRD Sport BR
    None yet, but its about to get rolling.
    Gonna get tons of snow pictures today.
  17. Feb 11, 2014 at 10:00 AM
    jeremy1ns
    Jeremy
    Greenwood, SC
    2010 TRD Sport BR
    iPhone but still love this pic
  18. Feb 11, 2014 at 10:19 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    The default setting in Lightroom is 75, which is good enough for posting images on the web.
    You can read about how Lightroom handles the quality slider and see some examples of how the different quality settings affects the final image below:
    http://regex.info/blog/lightroom-goodies/jpeg-quality
    Basically, setting the quality to 100 significantly increases the size of the file on disk for a negligible increase in quality. I would only use that for printing but even then I would prefer to send a TIFF or PNG to the photo lab.
  19. Feb 11, 2014 at 11:04 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I'd have to check but I believe I set mine to 80, if not 85. Didn't see much improvement (except photos I print) at 100.
    Also, some photos I took of my grandmother are being shown at the school's art gallery here with some other photographers work. I printed those after exporting it on 80 and then opening and doing some final touches in PS in the lab here at school so it had been saved as a Jpeg 2-3 times before being printed at 8.5x11 and 13x19 (with some slight cropping) and the quality is still more than 300ppi and looks great from real close up. I'm a RAW shooter and try to get the best quality possibly out of my camera but sometimes I think we worry about it too much haha I see no difference, even in prints, from changing my export quality and all that. Might be just my untrained eye though.
  20. Feb 11, 2014 at 11:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea as you said probably untrained..not saying my eyes are trained..ha...but like for audio, i bet all of you are perfectly happy with mp3s........
    mp3s suck ass so bad its not even funny. But i have trained ears. most don't.
    so good point.
    i know id never print a jpeg, id only do a non destructive format mostly cause of my audio roots and i know it does make a difference...even if its small.
