The *Official Photography Thread*
Discussion in 'Photography' started by THXEY, Nov 30, 2010.
  1. Mar 15, 2014 at 7:23 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Yeah, I was confused because I don't know film super well and the lines on the darker second photo kind of threw me off as a "digital pattern" yet they looked so much like film ha looks good to me!
  2. Mar 15, 2014 at 7:33 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya, and Tri-X was not typically quite that grainy.
    The 400 ASA color films of the late 70s were, but the B&W film was always much finer unless the ASA was "pushed" in processing (I used some 1600 ASA to shoot Hale-Bopp and had the lab push it to 3200).
  3. Mar 15, 2014 at 8:27 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
  4. Mar 15, 2014 at 9:10 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Shooting barrel racing indoors is a nightmare. I got my butt kicked.
  5. Mar 15, 2014 at 9:12 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    That's one thing that will kick your but just because. Amazing to watch!
  6. Mar 15, 2014 at 9:54 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    And outdoors isn't much better. Shadows, backgrounds-the conspire against the photographer.
  7. Mar 15, 2014 at 11:32 PM
    No Mod McFly
    No Mod McFly Well-Known Member
    Houston, Texas
    13' T-Force edition SR5 Double cab 4wd
    T-Force Edition, and thats all the wife is letting me do...
    It was bright (as expected). PP in LR5. Lots of clarity and low highlights, high in the shadows. Bump in sharpening and noise reduction. masking wasnt effective to keep the whole thing in focus. Not as clean as I would like. Im waiting for the sky to clear here (Just had a cyclone rip by) so I can try again with the mirror locked and on concrete
    Thanks
    Took me some time to learn which extenders to get. Since my camera focus at center up to F8 and my lens was 2.8 (400mm) I can effectively add both the 2.0X and 1.4X and still have AF. Not that it matters since it needs very little adjustment at that distance anyways. Pretty much at infinity
    With Canon- you can only stack the II extenders and not the III. So I bought the 1.4 III before knowing this but fortunately, the 2.0 II can work as long as its behind the lens and then the 1.4 followed last by the camera.
    Its easy-
    • When exporting- click on edit watermark in the drop down at the watermark section.
    • Click on the watermark title you wish to edit/ change in top left
    • Once you change your settings, click back on the upper drop down menu that lists your watermark title
    • At the bottom- click on the "Update Preset"- bam done :)
  8. Mar 15, 2014 at 11:34 PM
    No Mod McFly
    Houston, Texas
    Very clean shot!
  9. Mar 15, 2014 at 11:42 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    My lens is quite a bit tighter... and f/10 with one extender.
    I tried just going to infinity and it wasn't quite there.
    Going to try again in the morning, but won't be stacking two TCs.
    But.... my Tamron 200-500 with both of my TCs stacked, I could not go all the way into 500 without the moon being taller than the frame.
    Two TCs could be fun if I can dial the focus in.
  10. Mar 16, 2014 at 2:12 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    went to an auto show tonight....to try to play with indoor lighting settings with the camera.
    convention center lighting sucks ass but the cars were sweet
  11. Mar 16, 2014 at 7:15 AM
    jeremy1ns
    jeremy1ns Gamecock Tacos
    Jeremy
    Greenwood, SC
    2010 TRD Sport BR
    None yet, but its about to get rolling.
    Great shots man! what settings did you use for the 2 cityscapes?
  12. Mar 16, 2014 at 8:25 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Thanks!
  13. Mar 16, 2014 at 9:37 AM
    OneWheelDrive
    OneWheelDrive Well-Known Member
    Peter
    San Diego/Encinitas
    2012 DBL Cab LB TRD Sport
    Thanks!
    The softer photo with the pilings in the foreground was 25mm F8.0 10 seconds iso 100
    The photo with the long light reflections was 40mm F8.0 13 seconds iso 200
    It took over two hours to get the two shots without airplanes coming in over the city. It would have been easy to edit the light trails out of the sky, but the reflection of the landing lights in the bay wrecked every other shot.
    The biggest challenge with the E-M1 I'm facing is heavy graining and noise above 15 second exposure times. There is a "noise reduction" function that takes an equally long exposure after each shot and does a very good job of eliminating the noise for the longer exposure shots but it takes twice as long to take each shot. Higher iso settings also lend more manageable noise, but didn't offer the longer exposure times I was looking for given the bright moonlit night. The learning continues!
  14. Mar 16, 2014 at 9:44 AM
    OneWheelDrive
    Peter
    San Diego/Encinitas
    Here's one more I could have submitted for the challenge, but took it yesterday after I had already submitted! After I took this shot the biker came over to my buddy's RV where we were tailgating and had a PBR with us :)
  15. Mar 16, 2014 at 5:25 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    That's a killer shot Peter!
    Went snowshoing today and got this.
    8 by sconniehailer, on Flickr
  16. Mar 16, 2014 at 5:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    nice Marc!
  17. Mar 16, 2014 at 6:34 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Lots of great pictures showing up here!
    A few from this weekend.
  18. Mar 16, 2014 at 7:53 PM
    medic2230
    Murph
    Bama! Roll Tide
    I love this pic! The lighting is perfect in it!
  19. Mar 16, 2014 at 7:55 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Quick question.....
    Just picked up my D7000 with 50mm 1.8 lens. Love it!
    But when I put my 18-55mm kit lens on, it won't auto focus. My 55-200mm lens does autofocus, which is weird. Any ideas on why this isn't autofocusing?
  20. Mar 16, 2014 at 8:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    your AF switch on the lens is on? i know that sounds dumb..but...
