The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Feb 21, 2021 at 8:43 PM
    #2381
    tacowiz
    tacowiz Well-Known Member
    Wing
    Central Valley
    2021 Tacoma OR DCLB Army Green
    PrinsuDesignsStudio Cascadia Vehicle Tents Method Wheels (704) Falken WildPeaks
    Anyone have a accurate weight for their camper? TIA
  2. Feb 21, 2021 at 9:43 PM
    #2382
    justrussell
    justrussell Well-Known Member
    Russell
    Sacramento
    I posted it here back in December I think. I believe it was 376lbs
    tacowiz[QUOTED] likes this.
  3. Feb 21, 2021 at 10:19 PM
    #2383
    dabbinuguay
    dabbinuguay Well-Known Member
    PDX, Oregon
    2017 Tacoma TRD OR DCSB
    Terrific.
    I'm still 6-8 weeks from install, will keep that in mind when it's time to wire it up. Thanks!
    justrussell[QUOTED] likes this.
  4. Feb 22, 2021 at 4:58 AM
    #2384
    mac_2_nite
    mac_2_nite Well-Known Member
    Mac
    SoCal
    2017 DCLB Sport 4x4
    My OCD hates that you have this friend. Make me friends with her too!!
  5. Feb 22, 2021 at 9:19 AM
    #2385
    rjvincent1
    rjvincent1 Well-Known Member
    This was my solution in a GFC. Boat fan as you mention with 3M Dual Lock to fasten. This fan moves a lot of air with minimal amp draw. GFC had a hole drilled with a grommet through the front panel for wire routing. Worked well but hole could have been larger.
    BokerTov and justrussell like this.
  6. Feb 22, 2021 at 9:22 AM
    #2386
    gnardoggie
    gnardoggie Well-Known Member
    That's funny! I found your post on the GFC board and ordered the same thing as a result. Thanks for the idea!
  7. Feb 22, 2021 at 10:20 AM
    #2387
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Tent and shell sold!!
    Gotta remove the bed soon and reinforce. Looks sweet naked though. Bought the truck with shell 4 years ago now ?
  8. Feb 22, 2021 at 10:31 AM
    #2388
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Quick! Box that frame in while it's "easy"! I just drove the White Rim Trail and let's say I'm considering boxing the stiffer 2nd gen frame after that...
  9. Feb 22, 2021 at 12:51 PM
    #2389
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    I've been in pretty heavy rain the last couple days and having problems with condensation too. And water leaching in via the seams and cord used to mount the tent fabric. My sleeping pad was half soaked on the bottom. Currently it's drying in the back seat with heater on. Water also seems to pour off the overhang into back seat when back door is open. None of this should be a problem once I get back to sunny weather, but kind of annoying right now. I'll be looking into one of those fans once I get home, thx
    justrussell and Fast1 like this.
  10. Feb 22, 2021 at 12:55 PM
    #2390
    gnardoggie
    The sleeping bag issue is most likely from contacting the wedge with your feet while you're sleeping, as the moisture will accumulate on the colder surfaces (roof panel, aluminum etc). I would try to open all of your battens next time in the rain and see if that helps at all - air circulation will also keep the moisture at bay.
    justrussell likes this.
  11. Feb 22, 2021 at 1:49 PM
    #2391
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    If I read it correctly he said his sleeping pad not sleeping bag.. whereby water was absorbed under it.
    mac_2_nite and frenchee like this.
  12. Feb 22, 2021 at 2:04 PM
    #2392
    gnardoggie
    fair - i read it too fast. the pad is most likely getting wet from being in contact with the aluminum extrusion around the bottom edge of the sleeping area. In cold weather, the condensation will form on the coldest parts, and in this case it's the metal. the best ways to combat this would still be with proper airflow (windows open, fan etc)
    condensation is a pretty common winter issue - here are some tips that work for RVs (and would translate to our campers too)
    https://rvshare.com/blog/condensation-in-your-rv/
    I'm also looking into a waterproof mattress cover that might help avoid the saturation and just move me to wiping things down.
    frenchee and justrussell like this.
  13. Feb 22, 2021 at 2:15 PM
    #2393
    Fast1
    Minneapolis, MN
    You don't have to explain condensation to me. I've done market research on tents for several manufactures during the 90s while hiking in the mountains in all types of climates.
    From 25 years of backpacking in the mountains and in cold weather, typically condensation comes from you, while breathing and exhaling. Having ventilation helps minimize the moisture collecting on surfaces.
    As I read his post, the water that is saturating the bottom of his sleeping pad is coming in from the leaching in the seams and cord used to mount the tent fabric, not condensation.
    He reported heavy rain not sub freezing temperatures. He describes a classic issue whereby water is entering when raining due to leaks in the structure and soaking the bottom surfaces or what is on the floor of the tent.
    mac_2_nite likes this.
  14. Feb 22, 2021 at 2:21 PM
    #2394
    gnardoggie
    I'm not sure I agree in his scenario, but of course photos would help anyone make this point further. I will say his experience mirrors mine from my cold camping this weekend, so maybe it's simply coincidental. Condensation can also form during rain events too, as you mentioned.
  15. Feb 22, 2021 at 2:27 PM
    #2395
    Fast1
    Minneapolis, MN
    What are you talking about? I never said condensation came form during rain events.
    Do you typically have problems with your reading comprehension or what?
    mac_2_nite and fatfurious2 like this.
  16. Feb 22, 2021 at 2:37 PM
    #2396
    gnardoggie
    https://sectionhiker.com/backpackin...ining, your chance,pond, but many times worse.
    I presumed you've experienced condensation from rain during your 25yr of experience and market research, as it's rather common especially in the PNW. Apologies for maybe giving you too much credit.
    Ultimately if there's an issue with the construction of the product it would be helpful for all of us to see why. Beyond that it's a few actual owners of the product comparing experiences for the insight of others, while making some assumptions.
    justrussell and frenchee like this.
  17. Feb 22, 2021 at 2:40 PM
    #2397
    JasonLee
    15 TRD OffRoad
    I was worried about the tent in rainy and frozen conditions.
    For the water leeching in, you can apply AquaSeal / SeamGrip to the inside to seal the holes in the material/threading from allowing water inside.
    For condensation, that’s a topic that plagues all of us without high BTU heaters and deserves its entire sub forum.
    KRUD, ChrclTaco and gnardoggie like this.
  18. Feb 22, 2021 at 2:54 PM
    #2398
    dabbinuguay
    PDX, Oregon
    Condensation is a fact of life, just gotta deal with it.
    Water leaking through extrusion joints and keder rail would be a major bummer.
  19. Feb 22, 2021 at 2:55 PM
    #2399
    Fast1
    Minneapolis, MN
    Wrong.. you can't even remember what you, yourself posted. Here is a refresher for you.
    So is it reading comprehension or your presumptions that keep you attempting to cover your a$$
    for your BS posts.
    Done on this subject. You know where you can go.. I don't have the time to teach you how to read and comprehend simple subjects.
  20. Feb 22, 2021 at 3:03 PM
    #2400
    gnardoggie
    No need. I hope you enjoy your camper! Mine's been sick so far.
    dabbinuguay and justrussell like this.
