The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Feb 22, 2021 at 9:23 PM
    #2421
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    ah i thought someone said they picked them up from SP. I'm aware of ShittCo. I pinged the guy around the same Roaming Lost had on his truck. if they were at SP makes that easy but looks like ill have to wait. they tend to sell out quick.
    justrussell likes this.
  2. Feb 22, 2021 at 9:24 PM
    #2422
    nudavinci64
    Robert
    gotcha bummer. Didn't realize he had some for the X1 ready to go.
  3. Feb 22, 2021 at 9:26 PM
    #2423
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    FWIW my thoughts are below:
    Depending on the tent material, 303 fabric guard is better than seam sealer. It’s basically ceramic coating for tents. It gets absorbed by the tent and causes water to bead and run right off. Seam sealer tends to get brittle and crack over time.
    Roofnest offers an anticondensation pad that goes below the sleeping pad.
    Leaking at the bolt rope is interesting. AT mitigates this by having a flap that goes over the extrusion and bolt rope. Not sure if SP has this or not. More importantly, has anyone picked up the phone and called SP to hear their thoughts on the matter?
    frenchee likes this.
  4. Feb 22, 2021 at 9:42 PM
    #2424
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    months ago I was told that there is a “gutter” built into the extrusions. My first immediate thought was that it was going to freeze up and not allow draining the first time I would camp in barely freezing temps. Also, I think something else mentioned was “it’s made in Portland, it will work in the rain”.
    I hope it’s a small defect that is easily rectified. The SP is a good product adding more options to the market that I may own one day.
  5. Feb 22, 2021 at 9:58 PM
    #2425
    nudavinci64
    Robert
    I may have mentioned some of that since when talking with Spencer he noted they designed it to be used in the PNW. Hopefully, a quick remedy since many of us assumed it was going to withstand some decent rain. Now as my install date is coming up I hope it doesn't rain.
    JasonLee[QUOTED] likes this.
  6. Feb 22, 2021 at 10:02 PM
    #2426
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    They can let her sit in the parking lot for a couple days and perform an inspection lol
  7. Feb 23, 2021 at 6:05 AM
    #2427
    ripRavioli
    ripRavioli Well-Known Member
    Evan
    SLC
    2017 Tacoma Access cab 4cyl 4x4
    hahaha i had to do it! if youre in the SLC area youre welcome to check it out whenever!
    econwatch[QUOTED] likes this.
  8. Feb 23, 2021 at 6:25 AM
    #2428
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    There is a state campground at the base of the bridge on the WA side where Hwy 97 crosses the Columbia to meets I84. Nice walk along the river shore, admire the bridge. Good spot for a nights rest. Nothing spectacular.
    Synergy001[QUOTED][OP] and whup like this.
  9. Feb 23, 2021 at 9:08 AM
    #2429
    gnardoggie
    gnardoggie Well-Known Member
    until the train rolls through :)
  10. Feb 23, 2021 at 10:22 AM
    #2430
    gnardoggie
    I did some test fitting of the fireplace last evening, and I'm not sure it will work the way I'd like. It seems like I will have to cut the chimney by around 8" to get it to flush mount on the outside of the door. The install docs say that you can remove that much, but I believe for a vertical/ceiling exit. I'm speaking with them today to understand if losing that 8" will impact how the heater works.
    I'm not willing to give up just yet, but I might have to start thinking about pivoting to a diesel setup if I can't get the placement in the right spot, sadly.
  11. Feb 23, 2021 at 10:35 AM
    #2431
    frenchee
    Oceanside CA Area
    Nice!!
    Keep us updated. Not familiar so can't really contribute.
  12. Feb 23, 2021 at 10:36 AM
    #2432
    gnardoggie
    Me neither ha! Sort of wading into uncharted territory here.
  13. Feb 23, 2021 at 2:07 PM
    #2433
    Synergy001
    Synergy001 [OP] IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    That’s not rain that’s the PNW sunshine lol!
  14. Feb 24, 2021 at 2:03 AM
    #2434
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Go a bit further west of Biggs Junction and can camp for free at the Celilo Park (boat ramp).
    Celilo Park
    https://maps.app.goo.gl/jGgQmkQEg78WqozP7
    VE7OSR[QUOTED] likes this.
  15. Feb 24, 2021 at 10:59 AM
    #2435
    dabbinuguay
    dabbinuguay Well-Known Member
    PDX, Oregon
    2017 Tacoma TRD OR DCSB
    So hypothetically, if you had to choose between a white and dark gray SP, which would you think would be easier to sell in a few years?
    I'm heavily leaning towards white, and that's what I ordered. There may be time to switch, and if so, kids are making strong push for dark grey.
    My dogs will occasionally ride in the back, assuming I can find an acceptable venting solution, which is why I'm strongly biased towards white.
    (My truck is silver)
  16. Feb 24, 2021 at 11:09 AM
    #2436
    gnardoggie
    dark gray might show dirt less and work with more truck colors.
    dabbinuguay likes this.
  17. Feb 24, 2021 at 11:44 AM
    #2437
    Beboman
    Beboman Member
    Bryan
    2020, Ford Ranger
    I have a white Ford Ranger. I'm starting to think I'll go with one of the Gray choices.... I'm worried black will cook the camper, I'mm not sure I want an all white rig.
  18. Feb 24, 2021 at 4:10 PM
    #2438
    Rocket Metal
    Rocket Metal Member
    Redondo Beach - Socal
    2010 Access Cab, 4x4 OR, black.
    Super Pacific X-1, ADS shocks/coilovers, Heavy Dakars, JBA UCA
    Time to come out of the woodwork. I paid my 50% deposit yesterday for a 2010 ACLB X-1. Truck is black, and I went with a White Canopy, Tan tent, and Black rails. Couldn't find a white on black combo so we'll see how it turns out.
    Of note: Cindy reached out to also check if I was able to front 75% of the remaining balance, to help them out with current cashflow. That was not a problem for me, but just want to relay their situation to others.
    ChrclTaco, EnBoo, justrussell and 8 others like this.
  19. Feb 24, 2021 at 5:16 PM
    #2439
    frenchee
    Oceanside CA Area
    That’s gonna be a dope combo.
  20. Feb 24, 2021 at 10:59 PM
    #2440
    EnBoo
    EnBoo Well-Known Member
    Nathan
    Denver, CO
    2018 DCSB Quicksand Sellout
    Is yours going to be done early? 6-8 weeks out pushes your timeline forward quite a bit
