The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Apr 16, 2021 at 5:15 AM
    #3101
    86Scotty
    86Scotty Well-Known Member
    Eric
    2012 Tundra Crewmax
    lots
    That's a bummer that it hits your latch. I would cut it forward of the latch for the horizontal piece and under the latch for the vertical, then reverse the corner piece making a square notch but keeping your same dimensions. Does that make sense?
    You would only need two additional corner pieces to achieve this.
    evdog likes this.
  2. Apr 16, 2021 at 7:33 AM
    #3102
    ScenicCityOverland
    ScenicCityOverland Well-Known Member
    Alex
    2015 Inferno Orange Tacoma TRD Pro
    AWD OWNZ U, whup, sr5vic and 7 others like this.
  3. Apr 16, 2021 at 8:11 AM
    #3103
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
  4. Apr 16, 2021 at 8:12 AM
    #3104
    ScenicCityOverland
    Alex
    Thanks!! That was what stunned me the most when I picked it up is all the features I didn't about.
    Counting down the days huh?
  5. Apr 16, 2021 at 9:27 AM
    #3105
    gnardoggie
    gnardoggie Well-Known Member
    I've got the 4ft ARB awning sitting around that I might mount off of the back. The only thing I haven't figured out is if it will make using the latches/stuffing the tent a pain. Right now I've got a 6ft CVT on the right side and have to work around it to make sure i get everything stuffed in. Sadly, it also won't match my CVT (grey vs black cover ugh).
    I used it on my topper system, but only really deployed it like 5-10x out of 100+ nights camping. Nice to have in the rain, but totally useless in the snow.
    I figured if it's shitty enough outside I'll just cook inside the camper vs deploying a rear awning. A 270 is nice, but you can't partially deploy (from what I understand), and thus you need to spend a bunch more time and have more space to get it working.
    Coop68[QUOTED] likes this.
  6. Apr 16, 2021 at 9:46 AM
    #3106
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    As I understand it, the problem with mounting an awning on the rear is the protrusion of the tent latches. I very much want the option of mounting something like a 4’ or 6’ (moving it from side to rear when parked) and adding a bug net “room” or even a full room. When I get mine next week I’m also getting two brackets, and I’m going to see if there’s a way to extend the brackets to clear the latches. I’ll post updates.
    Coop68 likes this.
  7. Apr 16, 2021 at 9:55 AM
    #3107
    gnardoggie
    There are a few different mounting points/heights on the brackets, you might be able to configure the awning low enough to clear (and adjust your rear door opening amount so that it doesn't hit).
    I will say that moving the awning from side to rear is going to be more hassle than it's worth. Maybe you can modify some of the quick disconnect brackets that some of the other companies are making to help with that?
  8. Apr 16, 2021 at 9:57 AM
    #3108
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm still not even close to getting a SP.. but things like this (the rear awning) are things I'm trying to think about ahead of time and prep for. I ultimately want to do the same.. add a 4-5ft awning off the back for shade/rain while looking, etc. but also possibly utilize it as a room like you mentioned @RangeRick.
    If the clearance with the latches and everything is an issue, and requires some engineering and manufacturing of a special mount, etc.. I was going to come up with and make one for myself. at that point.. I'd make extras for others as well if it turns into a bigger thing..
    Coop68 and dabbinuguay like this.
  9. Apr 16, 2021 at 10:53 AM
    #3109
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    Thanks. Yup, makes sense. I'll see what I come up with. If I have to cut pieces I may just shorten the whole thing. I'm going to try not to order anything more. Want to get back out on the road!
    86Scotty[QUOTED] likes this.
  10. Apr 16, 2021 at 11:24 AM
    #3110
    86Scotty
    Eric
    2012 Tundra Crewmax
    lots
    There is a great awning thread that's been going on Expedition Portal for awhile. I'm linking the specific post that has about every common 270 or otherwise unique awning out there, including link so site, price, weight, etc. It's a great post to bookmark if you are an awning junkie like myself. The whole thread is good if you have 6 or 8 hours.
    https://expeditionportal.com/forum/threads/new-270-awning-available.208254/post-2883603
  11. Apr 16, 2021 at 2:57 PM
    #3111
    itsZEUStime
    itsZEUStime Active Member
    Paul
    2019 Tundra SR5
    If you're looking for solar panels for your newly minted SPC, Home Depot has some great deals today.
    I'm looking for flexible panels, so if anyone has a hookup for those let me know!
  12. Apr 16, 2021 at 4:22 PM
    #3112
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Check out the renogy. Prob best bang for the buck
    86Scotty and justrussell like this.
  13. Apr 16, 2021 at 5:25 PM
    #3113
    mac_2_nite
    mac_2_nite Well-Known Member
    Mac
    SoCal
    2017 DCLB Sport 4x4
    My X-1 is finally “plug and play”, got the rear view camera on the driver side pillar with a disconnect right inside the wire gland, and the Anderson Powerpole connectors by Powerwerx on the passenger side:
    8E1CB5CC-B091-404A-9726-728CA968D346.jpg FCDC886E-E03F-495C-A779-2DCB18899911.jpg
    bfife, Synergy001[OP], roy326 and 5 others like this.
  14. Apr 16, 2021 at 10:19 PM
    #3114
    evdog
    San Diego
    2019 DCLB TRD OR
    That's what I ended up going with, 2 100W panels. There is room on the top of the X1 for 4 panels if I want to expand. Amazon has them for next day delivery.
    The other flex panels I saw were Rich Solar and Newpowa. Not much for reviews about those, but Renogy is well regarded and their panels have some nice features.
  15. Apr 17, 2021 at 6:24 AM
    #3115
    86Scotty
    Eric
    2012 Tundra Crewmax
    lots
    Most excellent video, even showing some great drone footage of the Chattanooga area!
    I noticed one thing in your video which SP could improve, ONE! They should add a hand strap hanging from the center top of the tent at the back, not attached to the tent but hanging inside the frame where it closes inside the tent and doesn't hang out when closed. Needs to be black. This would allow you to grab and pull down without pulling on tent canvas as shown in the video. The logic for this is that camp breakdown always involves dirty hands and pop up canvas is a bitch to clean. I'm gonna be the guy who accidentally grabs that pretty gray tent canvas right after I load up my sooty BBQ grill or greasy MTB.
  16. Apr 17, 2021 at 9:44 AM
    #3116
    mac_2_nite
    Mac
    SoCal
    2017 DCLB Sport 4x4
    Selling my all black X-1 soon (3rd Gen LB) if anyone out there is interested...
    bfife, Satch123 and Synergy001[OP] like this.
  17. Apr 17, 2021 at 9:53 AM
    #3117
    roy326
    roy326 Well-Known Member
    Roy
    Southern California
    2020 Tundra/V8 4Rnner/GX460. I do miss my tacoma
    since it has t slots, there it would be easy to add one of those jeep grab bar strap, but I’m not tall enough to reach that high. Think you’d need something hanging down
  18. Apr 17, 2021 at 9:53 AM
    #3118
    roy326
    Roy
    Southern California
    I’m curious to see how muc this sells for ... good luck and I’m sure it will go fast
    mac_2_nite[QUOTED] likes this.
  19. Apr 17, 2021 at 9:57 AM
    #3119
    nudavinci64
    Robert
    That was quick. Personal or new option?
  20. Apr 17, 2021 at 10:00 AM
    #3120
    mac_2_nite
    Mac
    SoCal
    2017 DCLB Sport 4x4
    I’ll be getting another one for whatever truck I get next for sure. I love the SP, I just need more space for a family of 3 + dog
    86Scotty, Coop68 and justrussell like this.
