The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Jul 1, 2021 at 9:13 AM
    #3941
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    I have found that the top closes much better if I deflate the mattress. Also, as I have said, if I follow ExPed instructions and open the inflate valve, stick the little dongle in to create a wider intake opening, open the exhaust valve and pinch it a little so that air can come in, then the mattress self-inflates to 90% in about an hour. At bedtime I close the exhaust valve, add 10-15 pumps from the hand pump, and I'm set. I'm 225 lbs. so I like it firm enough to keep me from bottoming out too hard. FWIW.
    whup likes this.
  2. Jul 1, 2021 at 11:32 AM
    #3942
    JMyerz
    JMyerz Member
    Justin
    Tacoma
    None
    I'll do the same thing as Rick does with the Exped mattress an hour before we sleep or when we get to camp, only difference is I attach the little hand pump and instead of squeezing it I simply blow into it 4-5 large breaths and its full inflated.
    86Scotty likes this.
  3. Jul 1, 2021 at 11:35 AM
    #3943
    gnardoggie
    gnardoggie Well-Known Member
    Might want to consider the moisture in your air when blowing in. I know for insulated backpacking pads they generally say not do to that as it can get mildewy inside over time, but I don't know how much that is actually a problem.
    econwatch and Mark77 like this.
  4. Jul 1, 2021 at 11:37 AM
    #3944
    JMyerz
    JMyerz Member
    Justin
    Tacoma
    None
    I thought about that and the pump has foam in it so I assumed it would catch most of the moisture, either way very valid point and something to be aware of.
  5. Jul 1, 2021 at 4:23 PM
    #3945
    tacomeg
    tacomeg Well-Known Member
    Megan
    Vancouver, WA
    2008 Tacoma DCLB TRD Sport
    I believe these ones will work. The socket head screws that Gzila sent are 1/4"-20 I think. Does anyone know if that is correct?
    https://www.fastenal.com/products/details/0961703
    Also have some of these 15 series M8 t-nuts from Fastenal, but M8 wouldn't work with the GZila brackets, so waiting on the above to arrive.
  6. Jul 2, 2021 at 6:20 AM
    #3946
    RangeRick
    Rick
    The socket head screws from Gzila are 1/4-20. Please keep us posted on how the new ones work. Thanks.
  7. Jul 3, 2021 at 5:59 PM
    #3947
    RangeRick
    Rick
    For the Gzila fly poles I filed down the short side of the bolt and they fit perfectly. See photo.27075957-5E19-4C7A-ABCC-10D99A30FF3A.jpg9E95625E-9DE0-43B8-970C-4034F5BDE52E.jpg
    frenchee likes this.
  8. Jul 5, 2021 at 10:17 AM
    #3948
    Taco_gloom
    Taco_gloom Member
    2020 TRD OFFRD
    It’s nice to have a drop down to clean the glass or pass things through, but in my last canopy that window leaked like crazy—I’m okay with have a solid window if it means no leaks
    Synergy001[OP] likes this.
  9. Jul 5, 2021 at 10:33 AM
    #3949
    Clwrz
    Clwrz Well-Known Member
    San Diego, CA
    2007 Silver Double Cab Tacoma TRD Sport
    The pass through was a huge bummer to lose in the camper. I would always use that to load up wood and what not in the camper shell. Hope they come up with a replacement window with a slider.
  10. Jul 5, 2021 at 5:04 PM
    #3950
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Yah that was a lot of the reasoning but I never had issues but def a source for a potential leak.
    exactly I used it for similar things. Also nice if you have a dog back there. Mainly I used it for similar moving items. Not the end of the world but would be nice to have it.
  11. Jul 7, 2021 at 7:57 AM
    #3951
    whup
    whup Well-Known Member
    CO
    Spotted my 1st SP in the wild - Cortez, CO
    Mark77, econwatch and ChrclTaco like this.
  12. Jul 7, 2021 at 8:29 AM
    #3952
    roy326
    roy326 Well-Known Member
    Roy
    Southern California
    2020 Tundra/V8 4Rnner/GX460. I do miss my tacoma
    I just got my email and they said it’s ready by Monday! I’ll make a trip up there at the end of the month. Any good spots to check out from So Cal ?
    86Scotty, EnBoo, Coop68 and 2 others like this.
  13. Jul 7, 2021 at 8:33 AM
    #3953
    Synergy001
    Synergy001 [OP] IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    Yeah I had the same leaking issue on my drop down window as well. It rains 9 months out of the year here in the PNW so it is bound to happen. If you live in a dry state then it shouldn’t be much of a problem.
    Mark77 likes this.
  14. Jul 7, 2021 at 9:32 AM
    #3954
    econwatch
    econwatch Well-Known Member
    Utardia/Kanook Eh
    Naranja 7545
    Was just curiously looking about for a solution to lift the camper if needed for storage or maintenance.
    Have seen one of the other campers have built-in attachment points to make it a bit easier.
    For a one person job on the SP would you buy a couple camper lift jacks and rig up some wooden supports to hold it up while you drive out underneath?
    Mark77 likes this.
  15. Jul 7, 2021 at 9:36 AM
    #3955
    nudavinci64
    Robert
    I don't see why not. I saw another set for lifting jeep shells. As long as it supports 4-500lbs it should support. Just to give it extra support.
    econwatch[QUOTED] likes this.
  16. Jul 7, 2021 at 9:51 AM
    #3956
    MountainRecipe
    MountainRecipe Well-Known Member
    Cody
    I used to use these on my slide in A liner truck camper, it was about 600lbs. Always made me nervous and uneasy because of only using two points but I never had any scares and they were surprisingly pretty stable. They would easily be able to lift the super pacific but it relies on a balanced center of gravity. Might be hard to achieve due to the overhang and geometry. I’d much prefer 3-4 points contact.
  17. Jul 7, 2021 at 10:12 AM
    #3957
    nudavinci64
    Robert
    Exactly what I was thinking. Almost forgot about the front would throw that off.
  18. Jul 7, 2021 at 10:20 AM
    #3958
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Y'all have an extrusion with a slot along the top of the main body. Put in a few t-nuts on each side with a bolt head or ring and hang it from the rafters and drive away.
    nudavinci64 and Mark77 like this.
  19. Jul 7, 2021 at 10:52 AM
    #3959
    nudavinci64
    Robert
    I was thinking along those lines but no rafters for me so would have to get creative.
  20. Jul 7, 2021 at 10:54 AM
    #3960
    econwatch
    Utardia/Kanook Eh
    Naranja 7545
    I like the idea of rafters, they would be a nice accessory to have for my SP.
    The off-balance from the overhang for an underneath-install is a consideration though. Getting a support under there would seem to be the idea.
