The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Jul 11, 2021 at 7:30 PM
    #3981
    Rocket Metal
    Rocket Metal Member
    Redondo Beach - Socal
    2010 Access Cab, 4x4 OR, black.
    Super Pacific X-1, ADS shocks/coilovers, Heavy Dakars, JBA UCA
    I have not measured the weight, but will research that soon and take it to some scales to get a number. But when SP told me the Access Cab camper weighed in at 360 lbs it was a bit of a shock :eek:. Front & rear aftermarket bumpers, the camper, gear, and people seems like it would get over GVWR really quickly. Driving back fully loaded, the truck felt like a boat, but that may be me being used to the no (RTT + Shell) for the past few months. This is overall a good exercise as its super easy to just say "throw whatever we need in the bed". Now its time to be a bit more mindful of what is being brought. The tentative plan is to get rid of rear seats, trimming general camp gear, and probably removing sway bars in the future as well.
  2. Jul 11, 2021 at 7:39 PM
    #3982
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Don't forget the overall weight of a stock DBC is more than a ACC, before you put anything in/on them.
  3. Jul 11, 2021 at 7:57 PM
    #3983
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I've kinda just accepted the fatness... But yes.. we have always tried to keep it on the light side when loaded with our gear as well.. it just all has a permanent home now more or less. Bumpers and everything else is just the name of the game.
  4. Jul 11, 2021 at 9:26 PM
    #3984
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    that sounds like your shocks and leaf springs aren’t up to the task.
    My 300lb OtherBrandCamperMadeOfAluminum, 50lb fridge, 100lb bike rack, 60lbs of bikes, water, et al… my truck handles great.
    That was before I put on leaf springs that could handle the load yesterday. I was using an add a leaf before.
    justrussell likes this.
  5. Jul 12, 2021 at 11:45 AM
    #3985
    urshur
    urshur Well-Known Member
    2020 TRDOR ACLB
    Reviving your question from the dead; did you ever find a good answer to this? I've seen someone on the SP Facebook group that looks like they've figured out a couple different options that interface nicely with the T track, but not sure where to look for them.
  6. Jul 12, 2021 at 12:02 PM
    #3986
    EnBoo
    EnBoo Well-Known Member
    Nathan
    Denver, CO
    2018 DCSB Quicksand Sellout
    I think the best one is from Roofnest.
    https://roofnest.com/product/ladder/
    The Falcon 8.5 would probably be the best. I asked SP and they didn't have anything to say.
    Justin said "check some forums"
  7. Jul 12, 2021 at 3:13 PM
    #3987
    urshur
    2020 TRDOR ACLB
    Well, here we are I guess.
    Per the FB group, this one was from CVT in Bend
    And this one is from Wanderlust Overland, although I imagine they're just re-sold models from somewhere like Roofnest.
  8. Jul 12, 2021 at 3:38 PM
    #3988
    JasonLee
    15 TRD OffRoad
    I wouldn't trust anything plastic to hold up a ladder after it's been in the sun for a few months in Colorado… The top solution from CVT looks best out of the two.
    TravelinJohn likes this.
  9. Jul 12, 2021 at 3:46 PM
    #3989
    urshur
    2020 TRDOR ACLB
    I agree. I couldn't quite tell if I thought that bracket was plastic or milled aluminum, but if it is in fact plastic...probably a pass from me.
  10. Jul 13, 2021 at 8:06 AM
    #3990
    gnardoggie
    gnardoggie Well-Known Member
    I was thinking of getting some brackets to go from the bedrail to 80/20 made that are either one piece or can use the specific bed-rail t nuts. I'm having issues keeping my 80/20 locked to the rail given vibrations, etc, but I'm using just some jerry-rigged 1/4-20 t nuts and I think the specific rail ones would be way more secure.
    Then I realized I can prob accomplish this with some L-bent aluminum and a few holes...unless you're really bored and want to get tricky with it:)
  11. Jul 13, 2021 at 8:34 AM
    #3991
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Got ya. Some strapping like you said sounds like the easiest solution. At least to test the theory anyways. Or.. would just better T Nuts work? Like better fitting for the 80/20
  12. Jul 13, 2021 at 8:36 AM
    #3992
    gnardoggie
    The T nuts fit fine into the 80/20, but I'm also using similar 80/20 ones in the bedrail since my L brackets are made for 80/20 (the hole size is limiting me to using smaller t-nuts in the bedrail so the only just fit well when tightened). If I had a bracket with a large hole for the bedrail t-nuts, then smaller holes to attach to 80/20 I'd be in good shape.
    BUT- a bracket with an integrated t-nut that you slide in and only then just bolt to the 80/20 would be pretty sick.
  13. Jul 13, 2021 at 10:53 AM
    #3993
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I got ya. Draw up some rough sketches and I can mess with it..
  14. Jul 14, 2021 at 9:23 AM
    #3994
    tacomeg
    tacomeg Well-Known Member
    Megan
    Vancouver, WA
    2008 Tacoma DCLB TRD Sport
  15. Jul 14, 2021 at 9:37 AM
    #3995
    urshur
    2020 TRDOR ACLB
    I was waffling between those two options. They seem pretty comparable to me given the fairly limited pictures and information out there.
  16. Jul 14, 2021 at 9:39 AM
    #3996
    tacomeg
    Megan
    Vancouver, WA
    Same here. I was thinking I'd go with the cheaper options, although I think the black one looks nicer with my truck.
  17. Jul 14, 2021 at 9:41 AM
    #3997
    urshur
    2020 TRDOR ACLB
    That's just about the same conclusion that I reached. I can't imagine that they're that functionally different. The brackets look pretty much identical to me.
  18. Jul 14, 2021 at 2:13 PM
    #3998
    snakemetz
    snakemetz Member
    Jake
    2018 Tacoma Sr5
    Does anybody know of a site/forum where folks would be selling their Super Pacific builds? One nice thing that GFC has is a great forum on their own website where a section of it is people selling their builds for whatever reason. A lot can happen in 7 months wait time
  19. Jul 14, 2021 at 4:07 PM
    #3999
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Here. I got lucky doing the same thing and found someone selling their spot. as for used Units.. good luck. might be too new still for anyone to part ways with.
    frenchee likes this.
  20. Jul 14, 2021 at 4:38 PM
    #4000
    Synergy001
    Synergy001 [OP] IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    If you have FB there was a couple of people selling their spots recently if they haven’t been sold yet.
    snakemetz[QUOTED] and frenchee like this.
